Old 01-05-2012, 03:14 PM   #706
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,968
The brown gunk is gasket sealer from the engine assembly at the factory. Some oil screens come out nearly clogged with the stuff, like yours, and some come out with almost none at all. That's why it's a good idea to check and clean that item.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 01-06-2012, 11:35 AM   #707
Ken
Ken's Avatar
Oddometer: 58,262
I just made a call on one (2011). Should I buy it
I want to make a slow trip to Montreal this summer.
"God made hobos to make other men yearn." -Steinbeck
The modern liberal is the stupidest human being to have ever lived!
Ken is offline   Reply With Quote
Old 01-06-2012, 10:45 PM   #708
DirtyADV
DirtyADV's Avatar
Oddometer: 2,324
Found more while searching for rollers with a magnet (can be seen down in the hole):
Hmm can see some brown gunk
Opened the filter to see quite a bit of metal shavings, expected it, would almost have hoped for more, can only count 17 out of the 19 rollers (1 is missing in the picture).
Means I probably have some left in there somewhere, have installed a magnetic drain plug and plan to fill it with the cheapest motorcycle oil I can find start it up a little and do a very quick oil change after that:
Some metal shavings there
Also put a cap on the tank for the decalifornication, hope this is enough:
Plugging the extra tank outlet
Hope the parts ordered arrive in time so I can get it back together before heading back home to Sweden!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 01-08-2012, 07:00 PM   #709
BDXMPL
The Sheriff
BDXMPL's Avatar
Oddometer: 1,014
Question Running out of ideas...
My buddies '06 is making god awful noises. They started all of a sudden. One day it was fine, the next, it sounds like hammers in a blender. It has 8K on it.
Sounds just like this:
So far we've checked the doo-hickey, valves, KACR, clutch basket, piston, rings, wrist pin, and small end. All were in spec, and showed little sign of wear. Crank does not seem "loose".
I'm thinking it might be the mains, but I'm wondering if you guys could think of anything else it might be, before I split the cases.
Any ideas?
Hunter
Then the world exploded, and my head fell off.
BDXMPL screwed with this post 01-09-2012 at 05:39 PM Reason: nothing to see here, move along...
BDXMPL is offline   Reply With Quote
Old 01-08-2012, 10:04 PM   #710
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,807
That sounds awful.
You have already checked everything that I would check and more.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 01-09-2012, 05:42 AM   #711
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,837
It seems you have checked most of the "mechanical" parts. Sounds a bit like a dead, or partial spark cylinder on the video where as it's not firing completely and "slapping" in the cylinder. Have you checked the coil and related systems?
Just a thought.
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 01-09-2012, 06:51 AM   #712
willys OP
willys's Avatar
Oddometer: 2,904
What is your idle rpm speed set at? If too low they do sound rough. But as soon as you pick up the revs it sounds normal from where I am sitting.....? If you allow it to idle below 1100rpm then it sounds like it's slapping the piston and having difficulty firing so to speak. As you rev it even slowly it sounded fine. It was hard to hear it completely over your loud pipe...? Try and refilm it with the camera further away from the exhaust. How does it sound when it's trying to start? Tape it as it starts and idles at the correct 1100 or 1200 rpms then slowly up to 3000, no need to go higher as it sounded fine once reved....hope this helps
willys is offline   Reply With Quote
Old 01-09-2012, 08:52 AM   #713
norton(kel)
vintage
norton(kel)'s Avatar
Oddometer: 1,210
Sounds like youv'e got it stripped pretty far already. Put a 705 kit in it and call it good
norton(kel) is offline   Reply With Quote
Old 01-09-2012, 01:40 PM   #714
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,492
Foot Peg Question
There are less expensive foot pegs listed on fleabay that list fitting the Kawasaki KLR650 1987-2005.
My KLR is 2006. Is there a difference between 2005 & 2006 that would cause these pegs to NOT fit?
IDRIDR screwed with this post 01-09-2012 at 03:14 PM
IDRIDR is offline   Reply With Quote
Old 01-09-2012, 03:04 PM   #715
Whitebread117
I do what I want
Oddometer: 456
Originally Posted by IDRIDR View Post
There are less expensive foot pegs listed on fleabay that list fit: Kawasaki KLR650 1987-2005.
No difference in pegs 87-07 as far as I know. If they are the 19.99 ebay china specials I have them and like them. They've held up fine (including a few airborne "flying pig" maneuvers) with no problems other than some light surface rust on the cleats where my boots have worn the paint away. Mine sits outside 24/7 so rust is inevitable.
Whitebread117 is offline   Reply With Quote
Old 01-09-2012, 05:51 PM   #716
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,971
Well worth it. I've got many thousands of hard miles on mine.
Mine didn't come with springs though...
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 01-12-2012, 09:48 PM   #717
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,807
New springs for stock shocks
I recall a post somewhere about a company that will install stiffer springs on stock rear KLR shocks but I can't remember the name of the company. The stock shocks are optimized for a 160 pound rider and I tip the scales at about 250 before breakfast!
-Winston Churchill
Old 01-13-2012, 01:29 AM   #718
Ranger Rob
Out and about...
Ranger Rob's Avatar
Oddometer: 352
Laugh Maybe a convert..
Hi guys,
I'm more than likely going to purchase a 2008 KLR650 to use as a daily commuter.
The bike has had same owner since new and has had oil changes every 6000km apparently.
The odometer reads 61000km and the bike looks to be in very good condition.
1/ What should i be looking out for as far as wear goes.
2/ How much / how hard is it to do an overhaul of these motors?
3/ How much would an overhaul be?
I don't know anything at all about these bikes other than the fact that they are like a DR650 for the road!!!!
I would appreciate your knowledge, comments and assistance.
Regards,
Rob
"Everybody dies but not everyone lives"
Ranger Rob is offline   Reply With Quote
Old 01-13-2012, 02:33 AM   #719
kojack
My Hardley is a POS
kojack's Avatar
Oddometer: 970
That is top gun. They make a bunch of different springs for the klr.
Sent from my ARCHOS 80G9 using Tapatalk
kojack is offline   Reply With Quote
Old 01-13-2012, 02:43 AM   #720
kojack
My Hardley is a POS
kojack's Avatar
Oddometer: 970
Originally Posted by Ranger Rob View Post
Hi guys,
Regards,
Rob
The 08 up burn some oil at high speeds. Meaning high rpm. The klr will go anywhere the Dr will. Anywhere. Plus its way more comfortable, has alot more range and 100% more wind protection. The only thing you NEED to do is change the doo spring. Or the complete doo hickey. The motor is dmn near indestructable once that is done. Unless you flog the crap out of it at which point nothing lasts. I have 7000 on my 08. I'm upgrading suspension to take the weight of the extra gear and wife on the back. I'm using the new progressive shock wth rap, progressive springs and ricors up front with motowizard preload adjusters to dial it all in. The motor is getting the 705 with hotcams etc finally too. A little extra ooomph for the big hills here in east coast of Canada. I would not trade the klr for anything beside the ktm 990 r, but after all the mods I have done, I'm still only 1/2 the cost of a new ktm. If that.
Times are GMT -7.   It's 12:10 AM.
