Old 01-13-2012, 02:50 AM   #721
Ranger Rob
Out and about...
Ranger Rob's Avatar
Oddometer: 352
Thanks Kojack
Thanks Kojack.
The bike has done a lot of KM but i'm hoping with a little love that it will keep going for a while.
I'm a KTM man, so what the hell is a "doo" spring and a "doohickey".
How much of a fix is that, and is it applicable for a 2008 model (purchased in 2007)
"Everybody dies but not everyone lives"
Ranger Rob is offline   Reply With Quote
Old 01-13-2012, 05:05 AM   #722
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 1,194
Originally Posted by Ranger Rob View Post
Thanks Kojack.
What it is: http://youtu.be/26oSOrvv_e8
Where you get it: http://www.eagle-m-e.com/productlist.htm
'04 Wee Strom
'89 KLR 650 (sold)
I write books!
http://www.amazon.com/David-Wittling...ntt_dp_epwbk_0
ddavidv is offline   Reply With Quote
Old 01-13-2012, 05:19 PM   #723
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,167
.. as I have an '06 I didn't pay close attention to it, but I believe the oil issue is a non-issue after 2008 (2009+) for the new bikes (Kawasaki changed the rings during the initial builds or something like that) ..
.. at least until you flog it into submission .. and then you can go with the new 688 (the 685 kit is being replaced I believe) or the 705 kit ..
.. great bikes .. love mine ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.."
RevBill's SmugMug Shenanigans
My '06 KLR
RevBill is offline   Reply With Quote
Old 01-13-2012, 05:30 PM   #724
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
Originally Posted by kojack View Post
That is top gun. They make a bunch of different springs for the klr.
Sent from my ARCHOS 80G9 using Tapatalk
Yep, here's the website: http://www.topgunmotorcycles.com/KLR...lrsprings.html
I'm about 190# and tried the yellow spring, but soon found the white 7.4kg spring was just
right for me..
CycleDoc59 is offline   Reply With Quote
Old 01-13-2012, 05:41 PM   #725
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
Originally Posted by BDXMPL View Post
My buddies '06 is making god awful noises. They started all of a sudden. One day it was fine, the next, it sounds like hammers in a blender. It has 8K on it.
Sounds just like this:
So far we've checked the doo-hickey, valves, KACR, clutch basket, piston, rings, wrist pin, and small end. All were in spec, and showed little sign of wear. Crank does not seem "loose".
I'm thinking it might be the mains, but I'm wondering if you guys could think of anything else it might be, before I split the cases.
Any ideas?
Hunter
When I had a 4 cyl bike come in making similar noise at low rpm, it turned out to be a bad
rod bearing. When I pulled off the head, one piston top was very clean, as was the head at that
cylinder. At low speed the the piston was smacking the head, and as rpm rose, there
was enough pressure in the cylinder to prevent the piston from contacting the head...
Old 01-13-2012, 06:46 PM   #726
Ranger Rob
Out and about...
Ranger Rob's Avatar
Oddometer: 352
Thanks.
Thanks guys for the links, advice and general help.
I feel like a KLR mechanic already and i don't even own one yet!
Rob
Old 01-14-2012, 04:26 PM   #727
DirtyADV
DirtyADV's Avatar
Oddometer: 2,328
Rob
If you go for the new "doo" and the torsion spring make sure to still install the old lever to hold the needle bearing in place, I DIDN´T and the resulted in an unnecessary bearing failure! (go back a page or 2 to see the result)
And NOW this lever is going in place
Found another needle just laying there:
Hmm a needle just laying there
And found where all the metal shavings ended up, on the pickup, and another half needle there also, this explains why there was so little shavings in the filter:
A lot of shavings on the pickup and half a pin
Have started putting it back together and almost forgot the strainer:
Almost forgot the strainer
Can not fully find all pieces from the bearing, but have at least 18 of the 19 needles and some bits and pieces, hopefully its enough that I won't have any future problems!
What I could find from the bearing
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 01-14-2012, 04:31 PM   #728
tommu56
tommu56's Avatar
Oddometer: 1,375
Originally Posted by ausfahrt View Post
I recall a post somewhere about a company that will install stiffer springs on stock rear KLR shocks but I can't remember the name of the company. The stock shocks are optimized for a 160 pound rider and I tip the scales at about 250 before breakfast!
I haven't got that far yet but am looking at a set up by these guys as I am a little heaver than you.
sasquatch
tom
tommu56 is offline   Reply With Quote
Old 01-14-2012, 04:34 PM   #729
Ken
Ken's Avatar
Oddometer: 58,429
I am the proud owner of a 2011 black/gray KLR
"God made hobos to make other men yearn." -Steinbeck
The modern liberal is the stupidest human being to have ever lived!
Ken is offline   Reply With Quote
Old 01-14-2012, 05:31 PM   #730
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,844
Congrats!..........................pics please
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 01-14-2012, 05:45 PM   #731
nakedwaterskier
nakedwaterskier's Avatar
Oddometer: 263
The 2008 had oil consumption and fire issues. Late 2008 the oil ring was redesigned to eliminate the oil consumption problem. The routing/protection of the battery/starter cables caused shorts/fires/burned wires.
I wouldn't buy an 08 unless it was a very late 08 or it had factory recalls done or a big bore kit. Running a high oil consumption engine--you are just asking for problems. Insulating the battery/starter cables is no biggie.
AS FAR AS ENGINE NOISE...MY 04 VIBRATED THEN BLEW AT 35K MILES BECAUSE I SPUN A BALANCER SHAFT BEARING despite doing the doohickey properly a long time ago. The counterweights are HEAVY!
nakedwaterskier is offline   Reply With Quote
Old 01-14-2012, 08:23 PM   #732
Bobby C
Oddometer: 21
I have an 09 I bought new in Aug.of 2010 that burned a ridiculious amount of oil the first 4500 miles or so. I now have 9200 miles and have no problems. Maybe the engine has a drinking problem only during the break-in until it matures. I hope I don't see a relapse.
Bobby C is offline   Reply With Quote
Old 01-14-2012, 09:24 PM   #733
Bobby C
Oddometer: 21
I am on a very tight budget and have been considering the ammo cans for some time now.
Has anyone out there done this mod? I have a tutorial on the job saved on my favorites but what I really want to know is what options do I have as far as price is concerned for a mounting system.
The cheaper the better!
Keep in mind that I don't know how nor do I have the means to weld.
Thanks in advance!
Old 01-15-2012, 09:20 AM   #734
willys OP
willys's Avatar
Oddometer: 2,904
If you can't weld or don't want to, you are screwed IMHO in means to build a solid rear pannier that won't vibrate loose while on an adventure IMHO. Save up the coin and buy either a good secondhand unit or buy the strongest on the market, a PackRat system. $250 iirc. Sorry. Also look for mermite boxes instead of those heavy ammo cans.....mermites are super light and do require a bit of work but you won't be sorry. I have a set and they are almost indestructable.
willys is offline   Reply With Quote
Old 01-15-2012, 09:32 AM   #735
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,979
I agree they are a good option (lightweight and caverous), but they are destructable. They are oversized tin cans, afterall. I was sorry to see mine permanently retired last summer.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Times are GMT -7.   It's 02:04 PM.
