01-21-2012, 07:41 PM
#781 | |
Irreverent Reverend
Oddometer: 2,078
Yep ..
.. my '06 does the same thing .. fear not .. it's over there on the right side ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.." RevBill's SmugMug Shenanigans My '06 KLR |
01-24-2012, 08:59 AM
#782 |
Oddometer: 2,758
I have a fully modded 685, etc etc, I get 365kms before having to switch to reserve, now not knowing the exact conversion to miles, 300miles sound not too far off but better than me.....no? And yes....the fuel is hanging around on the right side.....lol You could modify the petcock IF you really wanted to, but it only changes the amount you have in reserve. I prefer to keep as much in reserve for those just in case situations when I forget to top her up and have to relyon the reserve to get me to the nearest gas station.
But many do adjust their petcocks ......the hieght of the screen by cutting down the brass tube so the screen drinks more before reserve.
01-24-2012, 09:32 AM
#783 | |
Rowboat Captain
Oddometer: 50,164
"God made hobos to make other men yearn." -Steinbeck |
01-24-2012, 10:38 AM
#784 |
I look lived in.....
Oddometer: 275
@willys-your 365kms=226miles
socalghostrider has 300miles on the bike, and got 177 miles on the last tank to reserve, which seems low. Unless he was really hammering it??
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson Punk Rock Changed My Life- The Minutemen |
01-24-2012, 02:59 PM
#785 |
JP
Oddometer: 123
Just purchased a new 2011 KLR650, pick it up this Saturday.... I guess I've joined the club...
Getting ready to set it up for an Alaskan tour this summer...
BMW R1100RT drz400s KLR650 |
01-24-2012, 03:11 PM
#786 | |
Irreverent Reverend
Oddometer: 2,078
Yessir ..
.. but I have another plan too .. there's a guy who did a really kewl mod using an in-tank aviation fuel filter and some fuel line to mod his petcock and fuel use/intake .. with his mod the fuel is used from the right side first and then flipping to reserve gets the fuel out of the left .. makes full use of the tank .. .. I have the parts .. just have not done the mod yet .. I need to get that done .. been on my mind lately .. and I doubt I'm going to spend the $500+ bucks for that new 10 gallon fuel tank from IMS ..
01-24-2012, 03:13 PM
#787 | |
Irreverent Reverend
Oddometer: 2,078
.. that ride is on my "bucket list" .. it will happen before I turn 60 .. dangit .. lol ..
01-24-2012, 03:52 PM
#788 |
JP
Oddometer: 123
By the way what is the DOO? Is that the same thing and the DOOHickey? I think I will try and seach the site. I asked the Parts Guy at the Kawasaki dealer and he said that it was much a do about nothing????
01-24-2012, 04:32 PM
#789 |
Rowboat Captain
Oddometer: 50,164
+1
01-24-2012, 04:33 PM
#790 | |
Wrench Rider
Oddometer: 712
http://www.eaglemike.com/Complete-le...ing-clkwts.htm #2 an adequate rear shock spring, available here: http://www.topgunmotorcycles.com/KLR...lrsprings.html #3 a Sargent seat (no, not a crappy Corbin), here: http://www.revzilla.com/motorcycle/s...klr650-91-seat |
01-24-2012, 04:40 PM
#791 |
Oddometer: 172
I installed a Happy Trails center stand on the old girl tonight and stripped one of the footpeg mounts, argh! Anyone know a fairly simple fix? I have heard about Heli-Coils and am thinking that sounds like the way to go. Any experiences? What size would I need?
1992 Kawasaki Zephyr 750 2000 KL250 Super Sherpa - Sold 2002 KLR650 - Sold 2006 SV650 - Sold Deal's Gap dual sportin' http://www.advrider.com/forums/showthread.php?t=626653 The Toad Goeth East http://advrider.com/forums/showthread.php?t=729961 |
01-24-2012, 04:55 PM
#792 |
Oddometer: 2,758
It's a blind nut behind the mounting plate. The best way is to cut it loose and get that stripped nut out and spot a new one in. Not easy at all. The metal is very thin so heli coiling a fix may work, if the nut doesn't break off inside. It will if you put too much torque onto it. Yes ask me how I know. Yes I ended up cutting and welding. Sorry. If you do cut it loose try and cut the closest end open and get at it that way. I'm not sure if there is enough room to get a new nut and the old one in there.
The thing I would try first is to redrill and tap one size up and keep your fingers crossed. That is what I did but had bad luck and the nut came loose. Hope this helps
01-25-2012, 02:08 PM
#793 |
Oddometer: 27
Not that I am recommending this as repairing it is probably the best option, but I stripped mine about 20,000 KM's ago and have never had a problem. Mine does grap a little, but very little. I blue loctite the other one and red loctite the stipped on. It has never gotten loose or fallen out. Have not had a problem to date. Stood up on the pegs many times and I am not a small guy and I also have a centre stand attached to it that I use almost always. As long as the bolt stays in, it will be fine since the load on the bolt is down towards the ground, not out. I check it every so often just to make sure. Just my 2 cents so take it for what it is worth.
01-25-2012, 02:25 PM
#794 |
Oddometer: 172
I agree Canuck, probably little danger of it falling out, but the center stand does add some load to it. Because it is stripped i can't tighten it down. Had I caught it sooner I probably would have loc-tited the crap out of it and let it go, but now it is in need of repair. Found the Heli-coil I needed on Amazon for around 25.00, not too bad.
01-25-2012, 04:45 PM
#795 |
Oddometer: 13
Next thumper?
I have been researching lately and have come up with this one.Its an 06 with 655miles on the clock.Wants 4k for it.Understand the doohickey fix,what else do I need to know about this kawi?Have an 06 xr650l in the garage but want another more suited for the longer hauls,in a dual purpose configuration.
