Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 05-18-2012, 03:02 PM   #1741
IpponDuro OP
Now with Camel Toe
IpponDuro's Avatar
Oddometer: 1,005
Probably within 20 miles of SR20, but east of Washington Pass, and Loup Loup Pass.
IpponDuro is offline   Reply With Quote
Old 05-18-2012, 03:35 PM   #1742
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,783
Ruby Hill?
Never been there. Just a guess.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 05-18-2012, 03:57 PM   #1743
IpponDuro OP
Now with Camel Toe
IpponDuro's Avatar
Oddometer: 1,005
Originally Posted by DRONE View Post
Ruby Hill?
Ruby Hill it is:
And the mine in the picture was The Fourth of July Mine.
I reccomend a ride over the hill
Post another one DRONE
Old 05-19-2012, 11:25 AM   #1744
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,783
Uscgs benchmark
Here's a little different challenge.
Where is this? To win, you have to explain to all of us how to look up the location of a benchmark when all you have is a picture of it. Because I don't know. In fact, I don't know where this benchmark is exactly. I know the date I took it and where I was riding on that day. But I don't remember where I saw this. So . . . educate us!
WUMPA
Sidecardogs.com
Old 05-19-2012, 11:59 AM   #1745
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
http://maps.google.com/maps?hl=en&sa...-8&sa=N&tab=wl
http://www.geocaching.com/mark/neare...on=-115.419722
http://www.geocaching.com/mark/details.aspx?PID=RY0439
http://www.geocaching.com/mark/datas...spx?PID=RY0439
https://www.google.com/search?tbs=sb...w&ved=0CBUQ9Q8
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch screwed with this post 05-19-2012 at 12:08 PM
Nut Clutch is offline   Reply With Quote
Old 05-19-2012, 12:23 PM   #1746
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Even better, if you know the State, go here:
http://www.geocaching.com/mark/nearest.aspx
Input the designation as E 216. (the space is required). Input the State.
This only works if the benchmark is in that geocaching database.
Old 05-19-2012, 12:27 PM   #1747
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,270
Good job Sherlock Holmes! I think he remembers where he took that pic now.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 05-19-2012, 04:46 PM   #1748
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,783
Thanks, Steve.
Geocaching, huh? I would guess that database is only gonna get bigger.
You're up.
WUMPA
Sidecardogs.com
Old 05-20-2012, 11:41 AM   #1749
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,462
You can also look up the NGS datasheet with the station name and state.
http://www.ngs.noaa.gov/cgi-bin/ds_desig.prl
If you want to go benchmark hunting, besides geocaching search engine you can search from ngs here:
http://www.ngs.noaa.gov/cgi-bin/datasheet.prl
The NGS Data Sheet
See file dsdata.txt for more information about the datasheet.
DATABASE = NGSIDB , PROGRAM = datasheet95, VERSION = 7.88.2 1 National Geodetic Survey, Retrieval Date = MAY 20, 2012 RY0439 ************************************************** ********************* RY0439 DESIGNATION - E 216 RY0439 PID - RY0439 RY0439 STATE/COUNTY- ID/IDAHO RY0439 COUNTRY - US RY0439 USGS QUAD - SNOWY SUMMIT (1994) RY0439 RY0439 *CURRENT SURVEY CONTROL RY0439 __________________________________________________ ____________________ RY0439* NAD 83(1986) POSITION- 46 26 45. (N) 115 30 16. (W) SCALED RY0439* NAVD 88 ORTHO HEIGHT - 1919.058 (meters) 6296.11 (feet) ADJUSTED RY0439 __________________________________________________ ____________________ RY0439 GEOID HEIGHT - -15.95 (meters) GEOID09 RY0439 DYNAMIC HEIGHT - 1918.420 (meters) 6294.02 (feet) COMP RY0439 MODELED GRAVITY - 980,212.3 (mgal) NAVD 88 RY0439 RY0439 VERT ORDER - FIRST CLASS II RY0439 RY0439.The horizontal coordinates were scaled from a topographic map and have RY0439.an estimated accuracy of +/- 6 seconds. RY0439. RY0439.The orthometric height was determined by differential leveling and RY0439.adjusted in June 1991. RY0439 RY0439.WARNING-Repeat measurements at this control monument indicate possible RY0439.vertical movement. RY0439 RY0439.The dynamic height is computed by dividing the NAVD 88 RY0439.geopotential number by the normal gravity value computed on the RY0439.Geodetic Reference System of 1980 (GRS 80) ellipsoid at 45 RY0439.degrees latitude (g = 980.6199 gals.). RY0439 RY0439.The modeled gravity was interpolated from observed gravity values. RY0439 RY0439; North East Units Estimated Accuracy RY0439;SPC ID W - 531,020. 818,870. MT (+/- 180 meters Scaled) RY0439 RY0439 SUPERSEDED SURVEY CONTROL RY0439 RY0439 NGVD 29 (??/??/92) 1917.729 (m) 6291.75 (f) ADJ UNCH 1 2 RY0439 RY0439.Superseded values are not recommended for survey control. RY0439.NGS no longer adjusts projects to the NAD 27 or NGVD 29 datums. RY0439.See file dsdata.txt to determine how the superseded data were derived. RY0439 RY0439_U.S. NATIONAL GRID SPATIAL ADDRESS: 11TPM148446(NAD 83) RY0439 RY0439_MARKER: DB = BENCH MARK DISK RY0439_SETTING: 7 = SET IN TOP OF CONCRETE MONUMENT RY0439_SP_SET: SET IN TOP OF CONCRETE MONUMENT RY0439_STAMPING: E 216 1935 RY0439_STABILITY: C = MAY HOLD, BUT OF TYPE COMMONLY SUBJECT TO RY0439+STABILITY: SURFACE MOTION RY0439 RY0439 HISTORY - Date Condition Report By RY0439 HISTORY - 1935 MONUMENTED CGS RY0439 HISTORY - 1950 GOOD CGS RY0439 RY0439 STATION DESCRIPTION RY0439 RY0439'DESCRIBED BY COAST AND GEODETIC SURVEY 1950 RY0439'11.1 MI W FROM SHERMAN SADDLE. RY0439'11.1 MILES WEST ALONG THE LOLO TRAIL ROAD FROM SHERMAN SADDLE, 28.9 RY0439'MILES SOUTHEAST OF PIERCE, IDAHO, 0.65 MILE NORTHEAST OF THE JUNCTION RY0439'OF A DIRT ROAD LEADING NORTH TO THE OLD ROCKY RIDGE LOOKOUT, AT A RY0439'SADDLE IN ROCKY RIDGE, 61 FEET NORTHEAST OF THE CENTER LINE OF THE RY0439'ROAD, 45.7 FEET NORTHEAST OF A LONE 15-INCH WHITE FIR TREE MARKED WITH RY0439'A WHITE PAINTED TRIANGULAR BLAZE AND GROWING ON THE NORTHEAST EDGE OF RY0439'THE ROAD, 21.2 FEET NORTH OF A 15-INCH STUMP MARKED BY THE WHITE RY0439'PAINTED LETTERS B M, 2.8 FEET NORTHWEST OF A WITNESS POST, ABOUT 7 RY0439'FEET HIGHER THAN THE ROAD, AND SET IN THE TOP OF A CONCRETE POST RY0439'PROJECTING 0.7 FOOT ABOVE THE GROUND. *** retrieval complete. Elapsed Time = 00:00:01
IDRIDR is offline   Reply With Quote
Old 05-23-2012, 02:39 PM   #1750
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Thanks, Steve.
You're up.
Ok. Sorry about the delay. Name the peak with the lookout on it.
Old 05-23-2012, 03:27 PM   #1751
650x
Oddometer: 1,149
Slate Peak Lookout
650x is online now   Reply With Quote
Old 05-23-2012, 03:37 PM   #1752
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Originally Posted by 650x View Post
Slate Peak Lookout
Yup. Your turn.
Old 05-23-2012, 06:18 PM   #1753
650x
Oddometer: 1,149
Name the road
Old 05-23-2012, 06:30 PM   #1754
tommybelvedere
Adv alacarte'
tommybelvedere's Avatar
Oddometer: 416
Is that Lower Imnaha rd or the rd to Dug Bar? Seen a lot of Bighorn Sheep up there last Aug?
tommybelvedere is offline   Reply With Quote
Old 05-23-2012, 06:38 PM   #1755
everycredit
everycredit's Avatar
Oddometer: 272
Name the road
Giggle
everycredit is offline   Reply With Quote
Times are GMT -7.   It's 06:06 AM.
