Old 11-27-2011, 06:37 AM   #1
john479 OP
john479's Avatar
Oddometer: 97
Running very hot after rebuild SL125
Hi, please excuse my ignorance, i'm on a learning curve here
After having a my cylinder rebored, a new piston, cam chain, guide and tensioner my 73 Honda SL125 fired up and sounded the best it has ever been.
The piston is now 56.5mm over the original 56mm and is a piston from a CB/CG/XL 125 with the slightly domed top which increases the compression from 8.0:1 to 9.0:1.
The cam chain felt much tighter when I put it on that the one that was one. (The tensioner is on the slackest that is goes) Is this normal?
After doing a few heat cycles (warming it up, just in the garden, and then letting it cool) I took it for a little ride. (Only around 1-2 miles I saw that the plug looked like it was getting very hot. There was also a tapping noise under acceleration, which sounds like the valves. I checked the clearance and adjusted them to 0.05mm when I was assembling.
The stock carb setting pilot screw is 1 1/2 to 1 3/4 turns out from closed and to get a brown plug it has to be 1 turn out. Gives you an idea of how hot it is.
Taking it easy I went out again today and its still the same. 2 times there was a horrible noise and a loss in power that felt like it was seizing up but can't be sure. I pulled the clutch in immediately and let is sit for a while to cool down. It started up fine both times and carried on fine.
What could be causing this kind of heat and tapping? Could they be linked?
Thanks very much if anyone can help.
John
EDIT
I have now done around 15 miles in total on it and its still the same
john479 screwed with this post 11-27-2011 at 08:59 AM
john479 is offline   Reply With Quote
Old 11-27-2011, 08:46 AM   #2
MrBob
Careening forward
MrBob's Avatar
Oddometer: 5,672
It isn't unusual for freshly rebuilt engines to run hotter, initially. There is greater friction as new parts seat, and with an overbore there is more surface area to cool. You can use a hand-held infrared thermometer to get actual measurements of engine temp.
The tapping noise under acceleration could be valves, but could also be bearing noise - not good. How about pinging? Are you using premium gas with your increased compression?
Are you certain that the timing is right on? Too advanced timing can also lead to heat issues.
A brown plug doesn't necessarily indicate high heat but a photo would be helpful. Better to run a little on the rich side during breakin to help with engine cooling (at least 1 1/2 turns of the adjustment screw).
Frequent oil changes are important right now and use a relatively light weight oil.
I don't know factory specs on this engine but are the tappets normally set that tight?
Hopefully, someone else will help you with your question on the cam chain tensioner.
KLX 400 dual sport
Tune in, turn on, drop out.
MrBob is offline   Reply With Quote
Old 11-27-2011, 09:18 AM   #3
SpeedyG942
Gas Man
SpeedyG942's Avatar
Oddometer: 443
Don't forget to check for an air leak between carb and cylinder- might be causing lean/hot condition.
SpeedyG942 is offline   Reply With Quote
Old 11-27-2011, 01:30 PM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 3,993
If it made a horrible noise AND felt like it was seizing up, it probably was. Is the oiling system functioning? Did you measure the piston ring end gaps to 100% VERIFY it was correct, rather than just relying on the machine shop to do it? When you say the plug looked hot, you mean the coloration was whitish? Can't rely on that, unleaded fuel doesn't really color a plug, certainly not in a short time. Did you shoot the cylinder head with a IR gun? The cylinder?
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 11-27-2011, 02:05 PM   #5
sporthog93
Sporthog93
sporthog93's Avatar
Oddometer: 760
did you check for oil to the top end after rebuild? Loosen the right rear head nut when engine is running and verify that oil is coming up the stud. The oil slinger (located on the right hand end of the crankshaft) can become clogged with metal particles reducing oil to the top end continued use will ruin the rockers, camshaft and the head. And the oil pump gears may need replaced on that type of engine. The gears get metal run through the pump ruining the gears and the pump housing.
Are we gonna ride or just dick around all day?
sporthog93 is offline   Reply With Quote
Old 11-27-2011, 02:13 PM   #6
john479 OP
john479's Avatar
Oddometer: 97
Are you certain that the timing is right on? Better to run a little on the rich side during breakin to help with engine cooling (at least 1 1/2 turns of the adjustment screw).
I use regular unleaded with a valve protector additive (as it should run on leaded fuel), which I have never had a problem before with. In the UK, I'm pretty sure its 95 octane.
I will double check the timing, but I am pretty sure it is right. I am running it very rich at the moment. Stock is 1/1/2 - 1 3/4 turns out from fully closed and I am running it at 1 turn out (further in is richer).
The manual says tappet clearance is 0.05mm so I'm assuming that is right.
Old 11-27-2011, 02:19 PM   #7
sporthog93
Sporthog93
sporthog93's Avatar
Oddometer: 760
valve clearance is .002 in intake and .003 inch exhaust.
Old 11-27-2011, 02:20 PM   #8
john479 OP
john479's Avatar
Oddometer: 97
Eek
I shall check that but should be ok
I didn't check the ring end gap , stupid me. The plug did look whitish, I will check the temp with my IR gun and will let you know.
I replaced the kickstart spring whilst I had the top end off which meant I had to split the bottom end. Whilst in there I gave everything a clean, the slinger and oil filter. I will do what you said to see if there is oil getting to the head but I have pretty sure it is.
When I put the new piston in it did feel much tighter than the old one and when I kicked it over I head much more rubbing that the old one but maybe that's just me. I haven't had to run in a bike before.
Thanks for the help.
Old 11-27-2011, 02:23 PM   #9
john479 OP
john479's Avatar
Oddometer: 97
Thanks sporthog, if my exhaust valve is set too tight can this cause the tapping?
If these measurements are right then I had better change it. In my manual it says both at 0.05mm (0.002 inches)
John
Old 11-27-2011, 09:10 PM   #10
MSrider
Rebel with a sixfiddy
MSrider's Avatar
Oddometer: 4,132
Go wider on the exhaust valve clearance than the intake. .002 and .003 sounds good. And be sure to run some type of lead substitute in the old SL. I used to use CD-2. A little dab'll do you.
KOKA
MSrider is offline   Reply With Quote
Old 11-28-2011, 01:41 AM   #11
john479 OP
john479's Avatar
Oddometer: 97
I have just thought of something, not sure if its right but hey. Would the rebore (+0.5mm +2cc) mean the main jet needs to be changed? Compression has also increased but I'm not sure by how much.
Old 11-28-2011, 07:53 AM   #12
MrBob
Careening forward
MrBob's Avatar
Oddometer: 5,672
ZDDP is what I use, and the Diesel Rotella has increased amounts of zinc and phosphorous added - sold at your friendly Walmart.
KLX 400 dual sport
Old 11-28-2011, 09:02 AM   #13
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,423
Sounds to me like the dude who bored it didn't give it enough clearance. My other sneaky suspicion is the piston is too high a dome for the valve train and it is hitting valves after it gets hot and expands.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it.
RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT
Sniper X is offline   Reply With Quote
Old 11-28-2011, 09:21 AM   #14
john479 OP
john479's Avatar
Oddometer: 97
You could be right about the dome being too high but it is just a standard piston for the larger 124cc bikes so I'm not sure if it would hit it. Also, the tapping noise starts from cold and doesn't change, it doesn't get worse as it warms up.
Old 11-28-2011, 10:13 AM   #15
cam14
Oddometer: 112
Just a guess, since you effectively have a larger displacement with a higher compression ratio, you stock jetting should be lean. Therefore increase the fuel supply (larger jets) to get the air/fuel ratio back in balance.
If the engine feels that it is starting to seize, then I would be very worried. If you can confirm you have good oil pressure, then my next guess would be the rings. If the ring gap was too tight, then as the motor warms up, the gaps will close 100% and expand larger than the bore. Hope that is not the case as it will require tearing the motor down and high chance of scoring the cylinder walls.
cam14 is offline   Reply With Quote
Times are GMT -7.   It's 08:48 AM.
