Old 09-04-2012, 01:09 AM   #1216
HoneyBunz
HoneyBunz's Avatar
Oddometer: 5,201
heh heh
HoneyBunz is offline   Reply With Quote
Old 09-04-2012, 05:28 AM   #1217
g容g
Canadian living in exile
g容g's Avatar
Oddometer: 6,593
Lotus F1 Team has confirmed that Jerome D'Ambrosio will replace Romain Grosjean in coming Italian GP.
Greg
Europe 2013 Europe 2012 Europe 2011 England 2010 Gaspe PQ 2008 Nova Scotia 2007
Try to see the world beyond your front door.
g容g is offline   Reply With Quote
Old 09-04-2012, 09:12 AM   #1218
g容g
g容g's Avatar
Oddometer: 6,593
interesting tweet about Hamilton's data.....
Note about Hamilton's data: When he lifts, he goes full throttle again while downshifting.
blown (in more ways than one...)
no wonder the team was upset
Greg
Old 09-04-2012, 11:10 AM   #1219
g容g
g容g's Avatar
Oddometer: 6,593
pretty good analysis of Hamilton's data
LINK
Well, that was an interesting thing for Hamilton to tweet
Things that I found interesting:
(Ill refer to everything by the distance around the lap, which is noted at the bottom. For example, Eau Rough is at 1200m or so)
1) Hamilton gains mostly under braking, rather than in the corners (300m, 2200m, 3000m, 6700m). I would have expected the cornering speeds to be noticeably different, but they are actually quite similar. Hamilton can just go that little bit deeper, and brake that much harder before the wheels lock, due to the extra downforce he was running. With each steep drop in the speed trace (second trace from the top), you can see that Hamilton is just a little later on the brakes.
2) Hamilton messed up the third corner in the Les Combes section (corner 9, 2600m). He has more downforce, so should be as fast or faster, but he must have had a moment there, as his speed drops mid-corner. Unfortunately, the data is obscured by what seems to be the steering trace. The slight correction of the steering seems to indicate that he understeered, as he only let up on the steering rather than going into opposite lock (either that, or he has superhuman reactions that corrected a slide so quickly that he didnt need to get to opposite lock to save it but I doubt it!). You can see that in that short downhill run to Bruxelles (2500-2900m), the speed traces are parallel, so he isnt losing time because of the wing it was just his poor exit from the corner that lost him at least a tenth or so, where he should have gained at least one or two tenths.
3) Hamilton destroys Button under braking for the final chicane only to lose most of that advantage by killing his corner exit (6900m). While he was able to brake much harder (note the higher brake pressure he can apply without locking up, thanks to the added downforce bottom trace, brake pressure overlaid with throttle position 6600m), he probably ran wide mid-chicane, ruining his line on the exit. Because of that, Button go the better exit and clawed back much of what he lost in the braking zone.
4) Through the easy-flat corners (Eau Rouge 1200m; Blanchimont 6200m), they both lose the same amount of speed. Had this been a few years ago where Eau Rouge was almost flat, the data would have been much more interesting. While Hamilton would have had more drag, he may have had as much as a 10-15 km/h advantage exiting Radillion or Blanchimont. At some point, Buttons speed would eclipse Hamiltons, but Hamilton could retain an advantage. Its counter-intuitive, but sometimes adding downforce increases your top speed down a straight, simply because you exited the previous corner that much faster what you lose from drag is more than outweighed by what you gain from increased exit speed. Thats why Le Mans cars are closer to medium downforce spec now, especially with the chicanes on the Mulsanne the corner exits are very important.
5) Neither driver can trail-brake as hard into Bruxelles (2900m), due to the downhill nature of the corner shifting the balance forward, making the rear of the car light and twitchy. The braking trace shows that as they turn in, they are braking with about half as much brake pressure as the entry to Pouhon (3800m); this could be partly due to the lower speeds and therefore lower downforce, but by watching the cars through that corner, some of it has to be because they are all quite twitchy on corner entry.
6) It is worth noting that at near top speeds, there is little-to-no brake modulation, as the car has so much downforce, giving the tires so much grip that arguably the best brakes in the world still cant lock the wheels. Note the braking into La Source (200m) they are mashing the brakes, and then gradually easing off the brake all the way to the apex of the corner, mostly because they are losing downforce (and therefore grip) as they slow down. To avoid locking up, they must ease off the brakes as the limit of the tires gets lower and lower with the decreasing speed.
7) Both drivers seem to be quite smooth a testament to the McLaren. If you look at the whole lap, looking specifically at the steering trace (third trace from the top), there are very few corrections that were made. Each steering input, Hamiltons correction in Les Combes aside, its all very deliberate and consistent no massive opposite lock moments chasing the car through the corner. Then looking at the throttle trace, I cant see anywhere where they had to lift to correct for any wheelspin clearly the McLarens are putting the power down quite well. It would be really interesting to compare to De La Rosas throttle trace, where I bet his steering and throttle inputs are far more erratic, for the simple reason that the HRT has less downforce, is probably twitchy in each corner, and is not able to put the power down nearly as well therefore poor Pedro has to wrestle the car at the limit, rather than Jenson being able to finesse the car through each of Spas lovely sweeping corners.
Hamilton posted the photo because he was blown away by the differences between a high downforce wing and a skinny wing, likely magnified by his disappointment of being so far off the pace. That was obvious to me (and probably anyone that understands the trade-off between downforce and drag), but it was the few other details that I found much more interesting.
Greg
Old 09-04-2012, 12:20 PM   #1220
Ace100
Expert Tomfoolerist
Ace100's Avatar
Oddometer: 432
Originally Posted by Ragin Rabbi View Post
Grosjean, 5 Retirments, four top five finishes.
Australia, wreck; Malaysia, spin; Monaco, wreck; Europe, alternator; Belgium, wreck.
So, to me this doesn't look like the work of an idiot, but rather the work of a rookie. He is currently eighth in the points.
Is it due to whom he took out that there is such a witch-hunt on? Grab your pitchforks and torches, the rookie took out Hamilton and Alonso through a rookie mistake!!! Burn him!!!!
Do we forget some of the spectacular (though not that frequent making them more spectacular) gaffs by Hamilton, Webber, and Vettel?
C'mon, get off his ass. It was a rookie mistake requiring only a freaking grid-spot penalty. Nothing more, nothing less. If it had been a Hamilton or Webber or Vettel or someone like that, it would have been five or eight or something grid-spots.
I agree with this. Grosjean has shown great potential along with typical rookie mistakes. Hell, Hamilton has done stupider stuff than Romain. I don't see him in the same light as Maldonado, who I think needs to be removed from F1.
Ace100 is offline   Reply With Quote
Old 09-04-2012, 01:21 PM   #1221
wxwax
Excited Member
wxwax's Avatar
Oddometer: 79,332
Originally Posted by HoneyBunz View Post
heh heh
That's a great example of what Domenicali was talking about. Drivers in the lower divisions who pull stunts like Maldonado's should be punished, to potty-train them before they ascend to the big league.
Sid.
It has been said that man is a rational animal. All my life I have been searching for evidence which could support this.
-- Bertrand Russell
To make an apple pie from scratch,
you must first invent the universe.
-- Carl Sagan
wxwax is online now   Reply With Quote
Old 09-05-2012, 07:13 AM   #1222
g容g
g容g's Avatar
Oddometer: 6,593
Kimi checking to see if Hamilton has tweeted pics of Scherzinger's tits...
either that... or he's playing angry birds**.
**姓ercury264
Greg
Old 09-05-2012, 09:57 AM   #1223
Ragin Rabbi
Semper Fidelis
Ragin Rabbi's Avatar
Oddometer: 5,090
Hamilton won't cAre about much anymore. Off to Mercedes.
Each according to their need, each according to their ability.
It takes a village to raise a child.
Go You Spurs!!
Ragin Rabbi is offline   Reply With Quote
Old 09-05-2012, 10:18 AM   #1224
wxwax
Excited Member
wxwax's Avatar
Oddometer: 79,332
I dunno, Ragin, if you read the BBC report it's basically Eddie Jordan speculating. He has no source and he's not a journalist.
I wonder why Hamilton would leave a very successful and prosperous McLaren operation for a Mercedes team that struggles on the track and has an uncertain future, with factory support apparently set to decrease net year?
Sid.
-- Bertrand Russell
-- Carl Sagan
Old 09-05-2012, 12:43 PM   #1225
g容g
g容g's Avatar
Oddometer: 6,593
maybe he's just testing the waters?
http://www.telegraph.co.uk/sport/mot...-Mercedes.html
Greg
Old 09-05-2012, 12:50 PM   #1226
wxwax
Excited Member
wxwax's Avatar
Oddometer: 79,332
Agents are troublemakers. See it all the time in soccer.
Sid.
-- Bertrand Russell
-- Carl Sagan
Old 09-05-2012, 12:53 PM   #1227
g容g
g容g's Avatar
Oddometer: 6,593
does he still use Benson (I mean his dad...) as an agent?
Greg
Old 09-05-2012, 01:49 PM   #1228
Ragin Rabbi
Semper Fidelis
Oddometer: 5,090
May have been speculation, but he had compelling reasons.
Go You Spurs!!
Old 09-05-2012, 04:49 PM   #1229
Irish1
Oddometer: 490
He fired his Dad a couple years ago.
Irish1 is offline   Reply With Quote
Old 09-06-2012, 12:27 PM   #1230
g容g
g容g's Avatar
Oddometer: 6,593
LOL
Greg
Times are GMT -7.   It's 09:45 PM.
