Old 12-21-2011, 03:17 PM   #16
sc-razor
sc-razor's Avatar
Oddometer: 3,776
I knew Wattner would be first
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 12-22-2011, 01:12 PM   #17
jesusgatos OP
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,393
Just posted in another thread on thumper talk, asking about FCR carbs and tank clearance. Want to run FCR's on these bikes, the newer-style FCR (not the slant-body), but what size? What's the consensus? Two of the bikes are pretty much stock, and one of them is fully-built (cam, big-bore kit, ported big-fin head, full exhaust, etc.). Used a Noss adapter when I put an FCR on my 650R and was really happy with it. So figured I'd order a few more for these bikes. They do make them for this application, right?
jesusgatos is offline   Reply With Quote
Old 12-22-2011, 01:17 PM   #18
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
paging cyclewizard...
Old 12-22-2011, 01:38 PM   #19
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Little bit of research dug up some good info on this subject (adapting FCR carb to XR650L).
This post by Research Rat on TT regarding different sizes:
Originally Posted by Research Rat View Post
I spoke with Sudco today re 39, 40, 41.
1. All fcr mx models have the same dimensions. IE no fuel volume capability difference.
2. 39, 40, 41 is the size of the internal venturi opening.
3. When Sudco dynoed different carbs on an xr650l, there are smallhp difference between 39, 40, or 41 mm sized models. "Negligable differences" was the term used.
4. The 39 will produce better down low reponse than 41, 41 will conversely produce better high end response than 39.
5. The Sudco contact remarked that he'd seen good results with using the 39 mm on xr650ls.
The Sudco contact recommended thinking less about engine size in relation to venturi size needed, rather than relationship between hp and venturi size. His rationale, crf450r with a 40 venturi opening, makes more HP than xr650l with the 41 venturi opening. I still don't understand this as 450 has 200 less cc's than the xrl and consequently would require a smaller overall combusatable mix.
All the above aside, our bikes need a measured amount of fuel/air, which is based on engine size. I think the 39 mm with rejetting can deliver the "right amount" but the question is can it deliver at the same rate of speed as what's needed. I'm not sure about that yet.
Thoughts?
-Scott
And a long thread about jetting that I haven't had time to read yet.
Old 12-22-2011, 02:39 PM   #20
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Yep Sudco makes a nos adapter for the FCR41 but it's to short in my book for a good fit on the air box side but will work with a little muscle.. they should have made it longer like I'm going to do...
I'm working on some aluminum billet intakes that can be ported to match the head porting at the monent.
I like the idea of the billet intakes over the hard rubber ones, once you grind out the rubber ones to fit the race ported heads there's not much material left over. Besides that the aluminum won't crack and smoke your new motor that you just spent a grand or so on.
Also the aluminum intake has a straighter shot going from the carb to the head and valves which will give you more POWER...
The big bend on the oem intake hurts performance.
I like the FCR45's over the 41's, it seems like the 41's run out of moe-joe in the upper revs and taller gears on the big block motors..for a 1mm or 2mm over high comp motor they work fine and I think they're the best carb out, almost like EFI they're so darn good.
This is no lie once you pump up a XRL with a cam some head porting and some comp the CV carb performs quite well..when you pump one up to a big block motor they do even better....
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 12-22-2011, 02:51 PM   #21
cyclewizard
Oddometer: 4,814
Love that tank......cool thread how did I miss it?
The man has some skills..
C-dub......
Old 12-22-2011, 03:57 PM   #22
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Quoting cycle wizard's reply to a PM I sent him about this for everyone else's' benefit:
Originally Posted by cyclewizard
There's no clearance issues with the FCR or 42 micky..
The fcr is a bit easier to take on and off than the micky but the micky is easier to ajust the pump and jet.
45's huh!?! wow. Would like to know more about these intakes that you're working on. Any idea when I might be able to get my hands on a few of those? And Lemme know if you need any help with CAD modeling or whatever. Oh, and would we still need to use a Noss adapter on the other side of using the stock air-boot?
Old 12-23-2011, 05:48 AM   #23
cyclewizard
Oddometer: 4,814
Yep you would still need the air box adapter but the new intake is going to be longer so it fits the air boot better.
I'll post a pic of a billet intake that I'm building for a national flat tracker, he's running one of my 750 motors..
It's a Knight frame twin shock so I'm making a straight intake for it that will fit his 48mm carb..
C-dub......
Old 12-23-2011, 05:56 AM   #24
cyclewizard
Oddometer: 4,814
To bad you couldn't relocate the rear shock I could build you a cross flow twin carb billet intake.
Two 32mm carbs with pod filters..
C-dub......
Old 01-03-2012, 03:13 PM   #25
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Please do post some pics. Would love to see what you're working on.
Old 01-03-2012, 03:22 PM   #26
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Made some more progress on the tank, and took a bunch of pictures with a new camera that I just bought, but I can't figure out where I put the damn things. So here are a few crappy cellphone pics instead. Started re-shaping the underside of the tank, and what these don't document too well is how I fit and shaped and cut the sheetmetal, tack-welded it into position, installed temporary supports, taped-off the interior volume, filled it with expanding foam, and then cut away the excess. The whole point of this was to, 1) maximize volume, and 2) make the tank a bit easier to reproduce.
Old 01-03-2012, 03:24 PM   #27
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Also spent a bit more time re-shaping the topside of the tank and it's looking a lot better. Funny how a few small changes can all add up to make such a big difference in the overall look and feel of something. Or maybe I've just spent too much time fondling this tank...
Old 01-03-2012, 04:11 PM   #28
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,856
Keep it coming Jesse!
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is offline   Reply With Quote
Old 01-04-2012, 09:03 PM   #29
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Very nice!
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 02-11-2012, 08:38 PM   #30
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Haven't had much time to work on this project lately, but spent this afternoon mocking-up the new subframe. It's pretty wonky, but just wanted to throw something together quick-like. Gonna make some small adjustments after I fit the rear fender, then make make a jig and I can weld-up the real subframes.
Times are GMT -7.   It's 07:47 PM.
