Old 07-16-2012, 01:46 PM   #61
jesusgatos OP
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Question: if we were to have these tanks roto-molded, would anybody want one? We're thinking that we might make kits available (would include things like the custom subframe, carbon/kevlar rear fenders, airboxes, custom seats, etc.). But that stuff is no big deal, because we're making these parts for ourselves anyway and they don't require much of an up-front investment in tooling. The tanks on the other hand, are going to be expensive to have rot-molded, so we'd love to know if there's any interest before we decide how to proceed. They would be available as part of a complete kit, as mentioned above, or could be purchased separately if anyone wanted to do their own thing with the rest of the bike (making their own subframe, seatpan, etc.). Not looking for any commitments, and we won't be taking any money before we have parts ready to ship. Just trying to gage interest...
jesusgatos is offline   Reply With Quote
Old 07-16-2012, 06:04 PM   #62
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Fit-up the new 41mm FCR carb and confirmed that there's plenty of clearance. Now that I know where the carb is I can add volume to the underside of the tank without worrying about interference. Also removed the intake boot from the airbox to see how it lined-up and what length adapter I should order from Noss. He makes them in .5 & 1.25" versions, and I think that I can get away with the shorter one. May or may not end up re-using the stock intake boot and air filter assembly. Would be just about perfect, except that the new subframe is a little bit narrower than the stock one, so with width of the air filter retaining thingy might be an issue.
Old 07-17-2012, 11:41 AM   #63
Dirt Addict
Oddometer: 17
Wow your build looks really promising. Depending on the $$$ I'd be interested in a complete kit. I recently picked up a 09 650L and plan on doing some longer distance rides on it. The scrambler set up looks so good .....
I think if oyu could come up with a ball park cost, it would help determine interest.....
keep the updates coming.....
Dirt Addict is offline   Reply With Quote
Old 07-17-2012, 10:19 PM   #64
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Started mocking-up the steering stabilizer mount today. That's not the actual mount, those tabs are just to locate the plate that I'm going to use to make a jig.
Old 07-19-2012, 04:33 PM   #65
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Finished making the jig to locate the steering stabilizer mount. Now I just have to make the actual mounting tabs.
Old 07-21-2012, 01:15 PM   #66
booter
Oddometer: 11
WoW! You got Skills!
"Brilliant! work & execution, my oldest brother created projects like yours, (recently deceased) he was an old Hot-Rodder, & bike builder. Your project bike reminds me of the Olde Schoole Brit-style scramblers (BSA cow trailers, Triumph Bullets, it even has an older Greeves Griffon-look)."
I have a '98XRL that I wanted to come out like an older Scrambler, I put on a Desert tank (I live in the upper-Desert), I had the front wheel laced into a 18" rim, for a +1"=Supermoto stance, it's easier for me to find/buy 18" dirt tires than to source 17" DS tires. I'm running 5.10 rear
X 3.25 front tires Kenda K270's, lot's of fire roads & Yosemite is only 1 hour away so I need a on/off road tire.
I can't wait to see your finished work-of-art bike! Good On You!
booter is offline   Reply With Quote
Old 07-22-2012, 03:16 PM   #67
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Thanks booter. Sorry to hear about your brother. Sounds like we're thinking along the same lines, as far as what we want to turn these bikes into. We've got an 18/18 wheelset for one of the bikes, we're going to run 19/17 on another, and 21/18 on the third.
Old 07-22-2012, 03:20 PM   #68
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Finished making a mock-up steering stabilizer mount for the extra frame. Will probably refine the design a little bit, but wanted to get a stabilizer mounted in the right location so I can make sure there's enough clearance under the tank. Had to tweak the coil mount slightly and mount the coil on the other side of the frame, but everything fits. Barely. Need to design the linkage, but that's easy. Going to focus on the tank. We're almost certainly going to have them roto-molded, and am anxious to get that process started.
Old 07-22-2012, 05:34 PM   #69
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by jesusgatos View Post
Finished making a mock-up steering stabilizer mount for the extra frame. Need to design the linkage, but that's easy.
I can't wait to see that. Seems an awkward spot for the stabilizer but what do know! More please...
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 07-22-2012, 08:18 PM   #70
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Originally Posted by Sourjon View Post
Seems an awkward spot for the stabilizer...
Not really. Just sort of the opposite of a Scotts low-mount setup. Maybe a little more awkward to adjust, but mounting the steering stabilizer on the chassis keeps the weight off the handlebars and it's much less vulnerable.
Old 07-22-2012, 08:21 PM   #71
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Started adding volume to the underside of the tank. Still a long way to go before it's done.
Old 07-23-2012, 07:10 AM   #72
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,851
This is a very cool thread, thanks for posting
I'm having visions for my XRL...keep up the good work and keep us posted on the kit idea
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 07-25-2012, 09:37 PM   #73
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Reshaping the bottom of the tank, cutting it up a little higher.
Found out that the manual decompression lever on the XR600's is something that I need to make clearance for. The mounts are different too, and haven't decided whether or not to incorporate both mounts into this tank.
Stock XR600 tank, gatosbros tank, clarke tank
Old 07-26-2012, 12:16 PM   #74
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,301
And you still ended up with less fuel than the stocker.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 07-26-2012, 02:46 PM   #75
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,384
Huh? Stock capacities are something like 2.8-3.1 gallons. This tank will carry at least .5 gallon more fuel, and I like the shape a lot more than any of the stock or aftermarket tanks.
Times are GMT -7.   It's 12:04 PM.
