Old 08-29-2012, 07:10 PM   #91
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,860
Originally Posted by jesusgatos View Post
Box full of carburetors showed-up today. Thanks Mike!
Lets review this a little more.
You have
2 weeks supply of carbs
or
1 a month plus a couple just in case of a break down
or
1 a year for 14 years
or 1 a day for 2 weeks or 14 day which ever you prefer.
Anyway you look at it,you'll never have a carb issue.Rebuild a few and swap out when a problem occurs.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 08-29-2012, 07:22 PM   #92
jesusgatos OP
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,414
Haha. Planning on building a few more of these bikes...
jesusgatos is offline   Reply With Quote
Old 09-04-2012, 07:09 PM   #93
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
So what does a box of FCRs cost?
Pablo83 is offline   Reply With Quote
Old 09-04-2012, 07:23 PM   #94
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
You hit the lotto!!!!!! damn what a find bros......
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 09-04-2012, 07:36 PM   #95
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,582
Looks like you are missing a few slides
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 09-05-2012, 07:13 PM   #96
STFU
Found
STFU's Avatar
Oddometer: 412
have any stock carbs you want to get rid of cheap?
Tiger 955i
450 EXC
STFU is offline   Reply With Quote
Old 09-05-2012, 08:27 PM   #97
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,414
If you can find another box, lemme know!
Not yet, but sure. Can let you know when I get to that point. Thing is, the one bike we've already torn down had a Mikuni on it that I sold a while ago, and the other two bikes are still complete/running. Might just swap-out for FCR's sooner than later though. Guess there's really no reason not to. Will have one 600 carb and one 650L carb.
Old 09-25-2012, 07:27 PM   #98
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,414
Designed these CRF conversion tripleclamps for the XR650R and now am trying to figure out what I need to change to make them fit the XR650L. Going to run late-model CRF forks on at least one of the bikes, but want to adapt XR650R forks to a few of the others.
Left to Right: XR650L, XR650R, CR500, CR/F
Old 09-26-2012, 06:25 AM   #99
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 826
I am sure there are a bunch of XRL owners who would be interested... I know I would be! Would be nice to have the steering stops, maybe even a spot on the triple clamp to attach the key switch...
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 03-29-2013, 12:43 PM   #100
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,414
The more I look at the gas tank, the more I've come to realize that I absolutely hate the way it looks. But it's so hard to throw away all the work you put into something like that, just kept working on it, and re-working it. Trying to save it. Even though it clearly wasn't working. So I'm done with it. But it's not all time wasted. Instead of starting over and hand-shaping another tank, I'm just going to have this one laser-scanned. That will give me the basic geometry of the underside of the tank and the areas I modified to increase the volume. From there I can re-shape the tank in Solidworks and that will be a lot faster/easier. Well, maybe not faster or easier, but I've been trying to improve my surface modeling skills and this will be good practice. The most difficult part of the whole process is going to be turning a CAD model into something tangible. Have got a friend with a CNC router and am thinking that we'll have a plug made out of wood. But I'm super busy with other projects right now and my friends are getting anxious. They want to ride their bikes. Wondering if maybe you guys can help me pick out some tanks to use in the meantime. Any suggestions?
Old 03-31-2013, 05:54 AM   #101
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,978
i'd just use a plastic stock or aftermarket tank if it was mine.
if you want a great look, a 60's or 70's yamaha 2-stroke tank looks slick but has little capacity
plugeye is offline   Reply With Quote
Old 03-31-2013, 07:00 AM   #102
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,105
+1
Carter Pewterschmidt is offline   Reply With Quote
Old 03-31-2013, 08:40 AM   #103
joexr
Oddometer: 3,773
The 70s Monoshock tanks would also have a wide enough tunnel to fit the frame/tank and still have clearance.
Old 03-31-2013, 12:54 PM   #104
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,414
Originally Posted by Carter Pewterschmidt View Post
+1
Thanks for the suggestions. Would love to see some pictures?
Old 03-31-2013, 03:45 PM   #105
joexr
Oddometer: 3,773
GO to the Yamaha page on Justgastanks.com and enlarge the pictures. The ITs and YZs with the triangle shaped swingarms had the shock under the gas tank , so the tunnel of the tanks are wide.
Times are GMT -7.   It's 11:13 AM.
