Old 12-08-2011, 04:13 PM   #31
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 570
Originally Posted by Baja Diego View Post
BINGO!!! that is in the works as we type reidinitaly
When will this be available?
MKJ is online now   Reply With Quote
Old 12-08-2011, 05:48 PM   #32
Guy Jinbaiquerre
Monorail Conductor
Guy Jinbaiquerre's Avatar
Oddometer: 1,222
Originally Posted by Baja Trent View Post
Hey Guys,
The pictures of our new squadron motorcycle light were taken on my personal 2008 RMZ450 and I must say I was absolutely shocked at how bright this light really is.
If anyone has any questions about the visibility of the light or technical questions please feel free to ask. Also this is the same Squadron 3"x3" that All German Motorsports is running on their trophy truck.
Trent,
I have the BD 4" Fuegos and I was wondering how the Squadron compares to the Fuego. Looks like you have both in that picture. Can you share your thoughts on the differences between them?
Thanks...
IBA # 42657
96 Honda XR250 Baja
09 BMW R1200GS Adventure ・ 09 KTM 990 SMT (sold) ・ 97 Honda X4 ・ 95 Kawasaki ZZR400 (sold)
Guy Jinbaiquerre is offline   Reply With Quote
Old 12-09-2011, 08:03 AM   #33
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,740
I received my new light yesterday.
It looks great!
I do have a couple questions for BajaTrent or Baja Diego...
There is not a shield in front of the light to protect it. Should I put a clear film on the lens to protect it from scratches?
The side panels are fabricated with holes, presumably for turn signals (nice touch), but the mounting plates are partially covers the holes. Do I have this assembled incorectly? If not, futrure runs should move the holes forward about 3/4 inch.
traveltoad screwed with this post 12-09-2011 at 08:12 AM
traveltoad is offline   Reply With Quote
Old 12-09-2011, 09:56 AM   #34
Baja Diego OP
Baja Diego's Avatar
Oddometer: 97
traveltoad yeee buddy let us know how the light preforms for you!!! We do not offer a rock shield for the light since its made of a hard Polycarbonatematerial. It can be replaced if it gets to scratched for $10.00. you do have it assembled correctly though
Diego
Baja Designs / Soltek Light Systems
www.bajadesigns.com
Baja Diego is offline   Reply With Quote
Old 12-09-2011, 09:57 AM   #35
Baja Diego OP
Baja Diego's Avatar
Oddometer: 97
We're hoping in 2-3 weeks
Diego
www.bajadesigns.com
Old 12-09-2011, 07:12 PM   #36
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
I love your Stuff Baja, my Stryker light is amazing. I've used it for a few Rally races and it's saved my A$$ many times. Looking forward to seeing what you come up with for the KTM/BERG.
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-12-2011, 03:08 PM   #37
harrell111
Scott
Oddometer: 2
Is there any chance we could get a little more clear of a picture of the light in use, and maybe something where we can tell the distance its lighting up? Im looking for a lighting system for a 24 hour race so distance is more important than usual trail ridding situations.
harrell111 is offline   Reply With Quote
Old 12-12-2011, 03:15 PM   #38
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,740
I will have mine hooked up in the next couple days... is there a specific distance of which you would like to see?
Old 12-12-2011, 03:22 PM   #39
harrell111
Scott
Oddometer: 2
hmm I would say 50-80 feet, its a highish speed race so Im hopping it will have enough light that running it I wouldn't be "out ridding my light" the whole time.
Old 12-14-2011, 08:13 PM   #40
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,740
Ok... I have only had time to get into the back yard with the lights so far. I will try to get some more this weekend, but this gives you an idea of the light.
All of these were taken one right after the other in about the same spot in my back yard with a Canon PowerShot G12 manually set to a 2000 ISO, 1/5 exposure time and and aperture f/2.8. With the settings held static it will give you an idea of the different amount of light. Both bikes sat on a charger to make sure the batteries were fully charged before the photos. Neither bike had me on it... so adjustments might look off with the SE and I have not even tried to adjust the Squadron yet although it looks very easy to do. The fence is about 60+feet away from the front of the light.
Suer Enduro low beam with aftermarket bulb (I think 60w):
Super Enduro high beam with aftermarket bulb (80w):
I know, I know, the stock Super Enduro head light sucks big time even with an aftermarket bulb.
Ktm 400 with Squadron Light (only one beam):
I'll try to get some photos with a bit more distance in the next few days.
Old 12-14-2011, 11:27 PM   #41
WHYNOWTHEN
where are the pedals?
WHYNOWTHEN's Avatar
Oddometer: 599
Wow
where does that road go?
WHYNOWTHEN is offline   Reply With Quote
Old 12-15-2011, 12:56 AM   #42
SuperBonBon
SuperBonBon's Avatar
Oddometer: 153
Low Beam Setup
Originally Posted by MJS View Post
PPS, this would be awesome with a PWM dimmer to run as a high/low setup.
Cheers,
Originally Posted by islano View Post
+1
Bright and Dim please!
Originally Posted by Yellow Pig View Post
When you get the light see if there is a way to make it passable for road use. ie tilting it down on the fly or running some tape on the lens to reduce head-on glare.
Trent and/or Diego,
+1 to what these guys said.
Is it possible to run 2 LED's at a time? If so, I could run 2 with a shield over them to make a passable street-use low beam (wired to low on the headlight switch), and then the other 2 (or all 4 of them together) as high beam. Going with this 2 + 2 setup would only use 22 watts at a time, and even with half of the light shown in Post #40 it would be as good or better than any halogen on the market. With a 2 light low, 4 beam high setup it would be as good or better than almost any 35watt HID on the market, with the ability to switch between high and low instantly and having none of the "hassles" of HID.
Best of all it's only 22 watts for the 2 + 2 setup. For us guys who are very short on stator power, that's a dream come true. I'd drop $350 on that setup in a heartbeat!
Build a man a fire and he'll be warm for a day. Set a man on fire and he'll be hot for the rest of his life.
SuperBonBon is offline   Reply With Quote
Old 12-15-2011, 07:42 PM   #43
tijuana
Farkling Around
tijuana's Avatar
Oddometer: 205
Make it "street legal" so it does not blind oncoming traffic, I'll take one. Is there a lens to focus the beam
2000 XR650R Dualsport
www.bajastarz.com
http://www.bikebandit.com Need parts or gear? Call me at 1-888-339-3888 ext 343
tijuana is offline   Reply With Quote
Old 12-18-2011, 05:27 PM   #44
MOTARDJUNKIE
MOTARDJUNKIE's Avatar
Oddometer: 163
Holy Shit! Anyone want to buy a Trail tech X2 halogen off road with about 10 hours on it?
Originally Posted by Oscar
Adventure begins when your plan goes to shit.
MOTARDJUNKIE is offline   Reply With Quote
Old 12-18-2011, 09:43 PM   #45
rs42sport
rs42sport's Avatar
Oddometer: 133
Thumb
WoW, i wonder if these are brighter than Clearwater Kristas
2004 honda silverwing 600
2004 Honda VTX 1300c sold at 25250miles
2006 Honda Shadow Spirit 750 traded at 9800miles
2009 Burgman 400 traded at 9424 miles
2007 Kymco People S 250-traded at 7860 miles
rs42sport is offline   Reply With Quote
Times are GMT -7.   It's 12:53 PM.
