Old 01-25-2012, 06:24 PM   #121
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,992
Just did a loop around the neighborhood now that it is finally dark and all I can say is that the light is fantastic!
Old 01-25-2012, 07:55 PM   #122
BuilderScott
BuilderScott's Avatar
Oddometer: 661
Looks good Dan!
Would this mount up in the stock mask of the 510 ok? That looks stock on the 310 here, no?
BuilderScott screwed with this post 01-25-2012 at 08:15 PM
BuilderScott is offline   Reply With Quote
Old 01-25-2012, 09:32 PM   #123
MJS
MJS's Avatar
Oddometer: 1,492
Originally Posted by BuilderScott View Post
Looks good Dan!
I can't say for sure. If you look at the pictures of the back of the mask you can see two screws, one on each side of the light. There is one other screw at the bottom center. If your stock mask has these screws or the mounting boss on the sides then the Squadron may mount to your stock mask. I know there is a difference in the mask on my 2010 310 and my buddy's 510. Mine had the stock 35/35 watt H4 lamp, my buddy's has the 6235 lamp. The headlight shapes are also different.
"You can follow me, but it's gonna hurt"
MJS is offline   Reply With Quote
Old 01-25-2012, 09:36 PM   #124
Yellow Pig
Yellow Pig's Avatar
Oddometer: 5,992
From the piccs thw 310 & the 510 masks look identical, might just be a charging system difference in the lamp they run.
Old 01-26-2012, 11:05 AM   #125
Baja Designs
Baja Designs
Baja Designs's Avatar
Oddometer: 374
Originally Posted by Yellow Pig View Post
Hey Gordon, I noticed that most of the squadrons pictured so far have the aluminum mount that surronds the light w/ holes, while mine is solid.
Is this a case of pre/post production versions?
Looks good Dan!
Hey guys,
That's awesome Dan we are glad to hear it, sorry it took so long for me to reply. What you have is actually post- production I am glad you are happy with it, but for any reason if you want the pre-production feel free to give me a call and I will have it sent to you. But the one you have is how they all are from now on.
Builder Scott, we will have the mount for the stock mask on your 510 in about 4 weeks, sorry for the inconvenience, but I will keep you posted on the status. If you have any questions just let me know.
Thanks,
Gordon BD
Baja Designs is offline   Reply With Quote
Old 01-26-2012, 11:51 AM   #126
Lonestar2112
Crash test dummy
Lonestar2112's Avatar
Oddometer: 5,205
BD,
I would love something like that for my '05 XR650L, I would have to be careful to not blind too many drivers.
Love your guys stuff. I had an old XR400 that had a baja kit. After years of abuse and being dropped, the turn signals finally quit working. I called your help line they dialed me right in, advised of the differences between the old kit and the new kit. I am happy to say that it was all plug and play. easy peasy.
Where am I?
"I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks
F*CK Cancer
Lonestar2112 is offline   Reply With Quote
Old 01-26-2012, 12:07 PM   #127
Baja Designs
Baja Designs
Oddometer: 374
Hey Lonestar,
That's awesome we are glad to hear it, for your XR650 the best option would be the Polisport shell that Yellow PIG has above, but I believe that you would have to do a Stator rewind in order to run the Squadron properly. What are you running right now?
Thanks,
Gordon BD
Old 01-26-2012, 12:22 PM   #128
Lonestar2112
Crash test dummy
Oddometer: 5,205
Originally Posted by Baja Designs View Post
Hey Lonestar,
Thanks,
Gordon BD
Currently nstalled is a stock stator, I have a high output one waiting to go in, I believe that it is rated for 260 watts. I will go back and look at what Yellow is running.
Where am I?
F*CK Cancer
Old 01-26-2012, 01:33 PM   #129
Baja Designs
Baja Designs
Oddometer: 374
Hey Bob I Just sent you a PM, but with that 260w stator you will have more than enough power, the Squadron pulls 44w and any other lighting(taillights) should not stress your stator.
Thanks,
Gordon BD
Old 01-26-2012, 02:12 PM   #130
Lonestar2112
Crash test dummy
Oddometer: 5,205
Gordon,
Thanks. I am going to wait until the dimmer is available and then it is time to rock. Hopefully before this n00b does DV in March.
Where am I?
F*CK Cancer
Old 01-26-2012, 02:16 PM   #131
tijuana
Farkling Around
tijuana's Avatar
Oddometer: 149
I will take one with a dimmer switch also.
2000 XR650R Dualsport
www.bajastarz.com
http://www.bikebandit.com Need parts or gear? Call me at 1-888-339-3888 ext 343
tijuana is offline   Reply With Quote
Old 01-26-2012, 02:21 PM   #132
Baja Designs
Baja Designs
Oddometer: 374
Alright perfect guys I will keep you updated.
Thanks,
Gordon BD
Old 01-26-2012, 06:33 PM   #133
BuilderScott
Oddometer: 661
Originally Posted by Lonestar2112 View Post
Gordon,
+1
Old 01-27-2012, 10:20 AM   #134
Baja Designs
Baja Designs
Oddometer: 374
Sounds good.
BD
Old 02-06-2012, 10:18 AM   #135
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,106
Any news on a retrofit kit for your older headlight masks? Will the dimmer plug directly into a standard H4 plug allowing you to leave your stock wiring unmodified?
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Times are GMT -7.   It's 01:20 AM.
