Old 11-30-2011, 05:11 PM   #1
Mr. Cob OP
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 9,381
Thumb "Gertrude" is finished, thanks Jay...........
Howdy All,
It has been a LONG slog to get my GS hacked, I started sending parts, the final drive and drive-shaft to "Bruno" up in Canada back in April of this year ( 2011 ); Bruno got sick and it took months for him to get the parts back to me so that I could reassemble the bike and deliver it to Jay so he could work his magic. Jay got the bike in July, scheduling problems prevented him from getting it done until late August, then the problem of the paint scheme on the tub caused further delays so I received the finished rig about a week ago.
I have been riding the rig off and on over the last week when the weather was semi-decent; I am VERY happy with the way it finally turned out. The only thing left to do is replace the front shock, I am going to have the Olines shock now on the rig rebuilt using a main shaft that is about 2 maybe 2.5 inches longer and with a stiffer spring. As it is now the rig sits and handles well but the front end because of the steering mod sits lower then I like and this becomes noticeable under hard braking with a passenger in the hack.
Here's Jay with the bike the day I dropped it off at his shop back in July.
This is a sketch I made of how I wanted the paint on the tub to look, because the tub and the gas tank are so different in size and shape this is the best design I could come up with to make them compliment each other.
Here Jay is standing out side of his shop in the RAIN the day I picked the rig up, here you can see the new hack paint pattern, I think it turned out quite well.
YES, I know the rig is dirty, I ride my bikes and rigs I don't spend a lot of time washing and polishing, this is probably about as clean as you'll ever see it. As you look at the photos you'll notice baked on mud and calcium chloride that I couldn't get off from the trip up to Purdue Bay back in July of 2001. Here's bunch of photos taken from different angles.
Detail of the external fuel filter and the sidecar brake master cylinder. I choose to go with ONE brake pedal working the rear wheel of the bike and the disk on the sidecar. As this rig will NOT be used in hard off road riding I didn't feel the need to have a separate sidecar brake pedal.
Detail of the adjustable proportioning valve used to dial the sidecar brake in so that it works with the ABS. I have tried a couple of panic stops and this works very well, the rig stops straight, the hack wheel doesn't lock up and pull the rig to the right.
Detail of the heavy duty sub-frame and skid plate. The skid plate is EASY to remove for oil and filter changes. Note how Jay custom built the sub-frame to incorporate the Tour-A-Tech crash bars.
Showing the mounting struts from the front. Note the tow-tie down hooks on the front and rear of the sidecar frame.
Showing the mounting struts from the rear.
Thanks Jay for building my rig, thanks for putting up with my no so sociable "Cob" self when things went wrong, THANKS for making it right.
Dave, aka "Mr. Cob"
My photos, http://mr-cob.smugmug.com/ Join Smugmug, use this coupon ( https://secure.smugmug.com/signup?Coupon=geyYbNZwLLrl6 )
Mr. Cob is offline   Reply With Quote
Old 11-30-2011, 06:30 PM   #2
brstar
brstar's Avatar
Oddometer: 451
Thumb Cool Jigger.
Cobs cool jigger. I hope you get to wear the wheels out. Cheers Bruce: clap
brstar is offline   Reply With Quote
Old 11-30-2011, 07:44 PM   #3
windmill
windmill's Avatar
Oddometer: 4,084
Very nice Dave,
Now you have a rig you have to wash and wax.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 11-30-2011, 07:49 PM   #4
Motoblag
Replacing skill with will
Motoblag's Avatar
Oddometer: 389
Lookin' sharp, Cob!
Any details on that proportioning valve, such as a part number? Looking at doing a similar setup on my outfit.
Motoblag is offline   Reply With Quote
Old 11-30-2011, 07:49 PM   #5
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,381
Originally Posted by windmill View Post
Very nice Dave,
Howdy Barry,
Go stand in the corner for speaking such blasphemy............
Dave, aka "Mr. Cob"
Old 11-30-2011, 07:52 PM   #6
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,381
Originally Posted by Motoblag View Post
Lookin' sharp, Cob!
Howdy Motoblag,
I don't have a clue what brand the valve is or its part number is, contact Jay I am sure he can fix you up with everything that is needed.
Dave, aka "Mr. Cob"
Old 11-30-2011, 07:53 PM   #7
_cy_
Oddometer: 6,268
neat o....
_cy_ is online now   Reply With Quote
Old 11-30-2011, 08:13 PM   #8
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,785
Super! Love the paint! I'm envying that brake proportioning valve.
As a fellow 1150GS-DMC guy, your rig is pretty familiar to me. About the longer front shock--are you sure you want top do this? Why not just beef up the spring to reduce dive and leave the length alone? I ask this because of the tendency for the front wheel to get too light in left handers especially when accelerating out of a turn. If you make the front shock longer, won't the rig tend to sit back on its haunches more than desirable?
WUMPA
Sidecardogs.com
DRONE is online now   Reply With Quote
Old 11-30-2011, 08:34 PM   #9
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,381
Howdy Drone,
I have the HUGE 10.9 gallon fuel tank on my rig, when I fill the tank and sit on the rig it drops and drops a lot more in the front. I am thinking that making the front shock 2-2.5 inches longer will raise the front of the rig about an inch and a half, I can then crank some more pre-load into the rear shock which will level it out when the tank is full, a rider and a passenger are on the rig. After adding the large fuel tank, the bike sat level when I had the 21 inch front wheel-tire on it, with the stock 19 inch front wheel-tire it sat lower in the front. Now with the steering mod it really sits low when topped up with gas and a loaded sidecar.
Dave, aka "Mr. Cob"
Old 11-30-2011, 08:41 PM   #10
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 5,972
ah....
finally she is back with you
and the paint... LOOKS PERFECT
glad for the thread
congrats, once again
can't wait to see her get all dirty this winter.. even though you aren't sure you're going to let her
Greg
'11 R1200 GS Adventure with a DMC M72DX Sidecar
'14 R1200 GS & '14 R nineT (march, 2014)
Live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is offline   Reply With Quote
Old 11-30-2011, 08:46 PM   #11
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,381
Originally Posted by ClearwaterBMW View Post
ah....
glad for the thread
Howdy Greg,
I'll be riding the rig this winter, I just WON'T be abusing it.
Dave, aka "Mr. Cob"
Old 11-30-2011, 09:19 PM   #12
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,050
Dave, beautiful looking outfit
Jay does great work.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 11-30-2011, 09:24 PM   #13
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 2,005
Looking good!
Hey Dave, looks like you got it right. I'm planning on catching up to you on the road at least once this coming summer. Maybe in Coeur d'Alene if you're coming this way?? You'll always have a place to stay here in Spokane on your way through town.....
Still working on rebuilding the Bings for my '82 hack. Yes, you, Roger, and Tony really, really got me hooked! Fiona will be up and running by the time the snow melts this spring.
Dale, the Old Fart
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X is offline   Reply With Quote
Old 11-30-2011, 11:52 PM   #14
Agent Wayward
Oddometer: 375
Lookin' sharp, Cob!
It's a Wilwood proportioning valve, used widely by specialist car builders, kit cars, etc. We use them over here in the UK.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Agent Wayward is offline   Reply With Quote
Old 12-01-2011, 02:06 AM   #15
NitroMax
NitroMax's Avatar
Oddometer: 677
Very nice rig, congrats !!
@ Motoblag, the brand is Wilwood ( like ageent Wayward says ), don't know the partsnumber, but here are few on their website CLICK
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Times are GMT -7.   It's 06:28 PM.
