Old 12-03-2011, 09:37 AM   #1
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
My spin on the KLR Ammo Can Pannier
Hey all,
Thought I'd share my variation of the ammo can pannier for our bikes. Since I have completed subframe strengthening, I started looking at the most common options and each time came up with the same conclusion that besides weight concern, I could make my own so I started looking at other home made options.
I have a pretty good general mechanical knowledge and decided to start working the the 20mm military surplus ammo can. I also did not want the typical complete removal of the lid rather a hinge system to allow one lock on one side and removal of most of the handle/supports. Check it out...
2 - Stock ammo cans shipped to my door for $79
Nearly complete prototype for my 09', Spent about $25 in hardware faulting trial and error more like $15 total needed and paint. stripped almost all the extra metal reinforcements to shave weight and generalize the look
Added a latch lock and used a jig saw and dremel to open one of the slots
Setup a beefy support brace for the custom hinge setup
Notice the whole support bracket is GONE, Used some steel brackets to create a sturdy exterior hinge setup. Used a rivet gun for everything to avoid nuts and bolts that could catch or be removed
I am planning on coating the exterior with bed liner and under coating the inside but have something cool up my sleeve I will post once its done ?;>]--
Keep your $0.02 if it ain't going towards the bill
Dubl-A screwed with this post 12-03-2011 at 09:49 AM
Dubl-A is offline   Reply With Quote
Old 12-03-2011, 10:57 AM   #2
willys
willys's Avatar
Oddometer: 2,904
They do look very good, but, real heavy too. Have you searched out mermite cans??? They are larger and extremely light in comparisn....just saying, sorry.
willys is offline   Reply With Quote
Old 12-03-2011, 04:21 PM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
Dubl-A I think you're doing an awesome job on those cans!
It will be nice to see them when they are finished and all mounted up.
GreaseMonkey is offline   Reply With Quote
Old 12-03-2011, 04:53 PM   #4
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Thanks man, I had actually looked at the mermite cans but really did not like them visually. I guess a form -vs- function thing
Old 12-03-2011, 04:55 PM   #5
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Thanks Grease, I should have some pics up this week (what a funny animation lol)
Old 12-03-2011, 06:23 PM   #6
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Plus removing the interior insulation is a PITA.
JamesG is offline   Reply With Quote
Old 12-04-2011, 02:40 PM   #7
willys
willys's Avatar
Oddometer: 2,904
Yes it is, but the rewards are great....lol
I agree the look of the smooth cans does look nice and they are by far stronger as well. I used to use them when I was Off-Roading in Jeeps.....loved them!
Old 12-04-2011, 02:48 PM   #8
Speedo66
Transient
Oddometer: 6,815
Sportsmans Guide has the 20mm ammo cans for $20 each.
http://www.sportsmansguide.com/net/s...%20cans&eMode=
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 screwed with this post 12-05-2011 at 06:33 AM
Speedo66 is offline   Reply With Quote
Old 12-04-2011, 11:22 PM   #9
Artful
Mid-life crisis time
Oddometer: 33
How much weight did you get off the 16+ lb starting weight on 20mm can?
I looked for Mermite cans but none at SAR gunshow or at local surplus stores - Ebay prices were redicledorf for them.
I picked up a couple of 60mm Mortar cans (think very very tall 50 cal cans) 'cuz they only weigh like 7+ lbs each.
What kind of Rack are you making/using to mount your 20mm cans on? And what attachment method did you decide to go with?
Artful screwed with this post 12-05-2011 at 09:08 AM
Artful is offline   Reply With Quote
Old 12-05-2011, 06:34 AM   #10
willys
willys's Avatar
Oddometer: 2,904
IMHO, the PackRat racks are by far the best and strongest racks on the market by far. Not too far price wise either. I bought them 5 years ago and have had zero issues with them and have even come off at 80 on the Dempster and they saved my skin and bike. Not to mention the mermites only were scratched afterwards. Nothing was bent or tweeked either! Amazing. Plus I tow a single wheeled trailer with them too! Like I said the strongest racks on the market, imho......
I just use 5 1/4 20 bolts to hold my cans on with. Yes not easily removeable for overnight in a motel if that is your need, but they don't come off or vibrate loose.....
Hope this helps
Old 12-05-2011, 11:20 AM   #11
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
I did not weight them when I received them only heard they were 20lbs. I would guess I removed at least 2-3 pounds of metal so Im hoping its around 15-18lbs.
Im planning on the Packrat rack 225 shipped Im having a hard time justifying anything else.
I'll post up picks when Im done with the exterior
Old 12-05-2011, 11:22 AM   #12
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Hope this helps
Thanks Willys, Im glad to hear it.
Old 12-05-2011, 12:24 PM   #13
beergut
Thumper
beergut's Avatar
Oddometer: 413
Cant wait to see them finished. Im planning to do the same system on my '08!
My KLR
beergut is offline   Reply With Quote
Old 12-05-2011, 12:32 PM   #14
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,209
Somebody needs to get our military to use aluminum ammocans, asap.
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 12-05-2011, 01:50 PM   #15
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
They sure wouldnt be cheap nor readily available
Times are GMT -7.   It's 05:28 AM.
