11-15-2012, 07:14 AM
#1171 |
Oddometer: 135
I finally got a chance to test out the excellent second hand equipment I was able to buy from Avner, there was some mention of rerouting the throttle cable after installing the ROX raisers, Which I needed to do, when I turned fully to the right the engine would rev slightly, I made it to work fine in this lovely 32degree temps. I had a look at the cables, and figured I could handle the cable routing issue, Im glad I did, It took me all of ten min. With a 14mm wrench, 4mm Allen wrench.
Very easy!
Have Fun!
Brian VitSports6 screwed with this post 11-15-2012 at 11:47 AM Reason: Crap!!! Wrong inmate, sorry Avner |
11-15-2012, 09:34 AM
#1172 | |
Oddometer: 332
Curious where did reroute the throttle cable? I'm having the same issue, can you take a quick pic so I can attempt myself over the weekend. Thanks.. |
11-15-2012, 09:36 AM
#1173 | |
Not noob anymore
Oddometer: 116
Gas problem fixed?
I was curious to know what was the resolution for the bad gas you got for the bike during Sandy. |
11-15-2012, 09:48 AM
#1174 |
Oddometer: 135
I Moved the cable from the front side of the ignition switch to behind it, it's a little difficult to take a pic, but I will give it a try.
Have Fun!
Brian |
11-15-2012, 09:50 AM
#1175 | |
Oddometer: 332
Bike is good...
Overall, the bike really hasn't given me any problems at all. I've been very happy w/ my purchase and all the add ons have made it even a better bike off road. I just got bark busters as the BMW hand guards are crap (hence a new clutch lever). Hope all is good and have fun on you 800... |
11-15-2012, 09:51 AM
#1176 |
Oddometer: 332
11-15-2012, 10:08 AM
#1177 |
Oddometer: 135
Here is what I can get, I hope they help.
RHS, Black cable is the throttle, Routed behind the ing. switch. ![]() I moved the Clutch cable out of the way to get a better pic, it holds the throttle cable in place between the two banjo bolts. ![]() ![]() Clutch cable in its normal spot. ![]() I hope that helps, Best of luck!
Have Fun!
Brian |
11-15-2012, 10:10 AM
#1178 |
Oddometer: 135
I did this after I got to work this morning, So I haven't driven it yet, But the throttle seems to go back to return as it should.
I will be sure to post up if I have any issues or other thoughts.
Have Fun!
Brian |
11-15-2012, 10:13 AM
#1179 |
Oddometer: 332
11-15-2012, 11:29 AM
#1180 |
U lie&yo'breff stank
what is the point of routing the cable behind the ignition switch ?
also i was wondering: on the throttle, there is a small black cable attached to it. it is not the throttle cable. i have no idea what it is. .. what is it?
11-15-2012, 11:44 AM
#1181 | |
Oddometer: 135
The black wire on the throttle it's self is the hand warmer wire, I guess that's what you are seeing.
Have Fun!
Brian |
11-15-2012, 10:03 PM
#1182 |
Oddometer: 12
The bike was definately running hot but I had put that down to some hard riding and increased temperature around this time of year. I actually thought I had a oil leak as there was a drop or two of oil under the bike when parked over night. turns out it wasnt oil. must have been antifreeze in the coolant that made me think it was oil. Anyway, good thing i sent it in for a checkup or im sure i could have caused more problems. |
11-16-2012, 04:17 AM
#1183 | |
Not noob anymore
Oddometer: 116
Enjoy! |
11-18-2012, 05:58 PM
#1184 | |
11-19-2012, 05:08 PM
#1185 |
jdog
Oddometer: 6
Nice LEDS OZI, can you give us a little more info pls.
"My Sertao Bike mods are Steering damper ; Fork protectors ; TT lower mud guard front ; TT bash plate ; LED spot lights with steering ; TT bar risers and extended ABS cable ; bark busters ; Dunlop 606 front and rear ; enlarged air intake ; led brake light ; carbon GPs mount for zumo 660 ; Gaintloop tank bag ; smaller front sprocket for more usable 2nd gear (2 teeth smaller 14 - 16 for road section there and back)"
![]() Hey Ozi, I see you have a nice LED setup on your Sertao, I was going to PM you about it for more info but figured others on here will also be interested. So what are the lights? Where did you get the bracket from? and of course how do you have it wired?. Actually it is the bracket mounting that I am most interested in. From what I can see it looks like you have bolted an alum plate onto the top of the beak. I would love some more info on how you did this. I would like to put a pair of LEDs on my bike but can only find the TT conventional filament bulb units with decent looking brackets. Clamping to the forks is something I would rather avoid. Cheers. J. |
