Old 12-14-2011, 03:23 PM   #31
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 625
Originally Posted by Johnf3 View Post
The bushings and the seals are identical between the closed chamber and open chamber WP forks. So, yes the kit I referenced will work. Like I said, the kit is designed for WP CC forks, so it has a few extra small seals meant to rebuild the cartridge seal that the open chamber forks on the Adventure do not have. There may be a SKF kit that KTM sells for open chamber, but I do not know the part number if there is one.
You will have 2 extra seals left over (the small damping rod purple seals) otherwise its the same. Its a great price for what you get! There was a major B/O on these a while back, some dealers are still having issue's getting them.
Konflict Motorsports & Suspension Services
www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 12-14-2011, 03:25 PM   #32
Johnf3
Oddometer: 990
Originally Posted by McVick View Post
I also found it difficult to tighten the cartridge back into the bottom of the fork leg.
It threaded into the piston rod just fine but getting it as tight as necessary is a bit of a trick.
The WP manual says to bend the piston rod a bit by pushing it to the side and holding it while you tighten the cartridge but even doing that I am concerned it is not as tight as it should be. Spec is 25nm but I do not have my torque wrench with me.
Brian
An easy trick is to slide the fork spring in and then invert the fork so the compression valve is facing up at you. Put your 19mm socket on the compression valve and press down as you tighten the valve body. The spring pressure from the fork spring will keep enough force on everything so it tightens right up. Don't overtighten your compression valve!
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 12-14-2011, 04:22 PM   #33
Peanuts
Peanuts's Avatar
Oddometer: 1,032
Originally Posted by UngaWunga View Post
Bam! thanks
http://www.ktm-parts.com/R14020.html
Hmm... while those are listed as a kit for SXS WP 48mm, all the rebuild kits listed for 950/990 advs have different (lower) numbers. Is that number correct? Just want to double check. I have to tear down my forks this winter because one of the adjusters is stuck, might as well replace seals while I'm in there. Thanks.
No need to touch the seals to sort out an adjuster. In fact no need to remove the cartridge. Base valve unscrews out the bottom. Cap unscrews off the top, then hold the cartridge with a 8mm or slimmer wrench, then undo the cap off the cartridge by undoing via the preload hex.
Make sure the ally tube in the centre of the cartridge is almost flush as its a common mistake to assemble the cap onto the cartridge when the ally tube is not correctly seated. Also make sure the black plastic needle in the cap fits into the ally tube as your place the cap onto the cartridge.
Peanuts is offline   Reply With Quote
Old 12-14-2011, 04:34 PM   #34
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 5,506
Thanks for the tips.
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 12-14-2011, 05:38 PM   #35
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,668
Wow,
that's a good deal for just about a complete service kit.
Not really, check this out.....
http://www.thousandoaksyamaha.com/fi...tnumber=R14020
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
Originally Posted by Beefeater Steve View Post
✧The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
KTMSER is offline   Reply With Quote
Old 10-03-2012, 11:43 AM   #36
SikDMAX
Oddometer: 687
Bumping this up.... having a bitch of a time getting the last bushing to seat putting the inner tube back on the outer - even tried heating as the recommend for removal. Any ideas?
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA
SikDMAX is offline   Reply With Quote
Old 10-03-2012, 12:27 PM   #37
Johnf3
Oddometer: 990
I always use my seal driver to tap the bushing into place before I tap the fork seal into place. It just takes a few light taps, very light taps. If yours is not going together easily something else is wrong. You sure your bushing is the correct one?
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Times are GMT -7.   It's 01:43 PM.
