Old 12-17-2011, 10:38 AM   #1
roohunt OP
roohunt's Avatar
Oddometer: 11
Enginering Antics Custom part lathe, mill etc.
Hoping to start a new thread dedicated to home made custom parts .
focous on lathe mill tig operations
So post your pics and specs and a valid reason for being.
this is a custom manifold mount on a xl 500 motor to suit mukuni carb .
using angle table on faceplate.
roohunt screwed with this post 12-31-2011 at 03:04 AM
roohunt is offline   Reply With Quote
Old 12-17-2011, 10:50 AM   #2
roohunt OP
roohunt's Avatar
Oddometer: 11
bst 40 needle .5 x 6mm thread
custom made bst 40 needle.
Old 12-17-2011, 11:06 AM   #3
roohunt OP
roohunt's Avatar
Oddometer: 11
klr hub to suit husky rear.
cush drive conversion.
custon axle (smaller dia)spacers for swingarm disc, bearings
Turned the husky 610 into a super smoth enduro machine with extra service life for the transmision.
very easy conversion if you have a decent lathe . wheels are cheep too.
roohunt screwed with this post 12-31-2011 at 03:08 AM
Old 12-17-2011, 11:23 AM   #4
DaveRMS
DaveRMS's Avatar
Oddometer: 1,150
Made these triples for my CB400F project...
And these hub modifications and adapters for the same...
Dave
DaveRMS is offline   Reply With Quote
Old 12-18-2011, 02:36 PM   #5
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 1,960
VStrom & XR650L Goodies
2nd bearing for the DL1000 rear sprocket carrier as means to eliminate sprocket twisting under acceleration -
Eliminating the infamous DL1000 "clutch chudder" using the "Sharealike" approach -
Mounting a larger Africa Twin front rotor and a DL1000 caliper on an XR650L to improve braking without needing to go the 320mm supermoto route -
Life is WAY more fun w/ a small mill and lathe (and a bunch of other tools). It was either do this sort of stuff or hang out at the local bar with a beer in one hand and a pool cue in the other... which isn't a bad way to go either.
LexLeroy screwed with this post 12-21-2011 at 06:37 AM
LexLeroy is offline   Reply With Quote
Old 12-18-2011, 03:39 PM   #6
DaveRMS
DaveRMS's Avatar
Oddometer: 1,150
Nice work LexLeroy. Like the extra bearing idea.
Dave
Old 12-18-2011, 04:37 PM   #7
Lambo
Lambo's Avatar
Oddometer: 607
Nice work
Lexleroy,
Nice job!
Bob
Support Mental Health or I'll Kill you.
Ironically, Chuck Norris’ hidden talent is invisibility.
Lambo is offline   Reply With Quote
Old 12-18-2011, 04:57 PM   #8
Hondarider
Hero of the Stupid
Hondarider's Avatar
Oddometer: 680
Just finally found a few square feet to park my toys. Still working on getting my power situation squared away and then I hope to start turning perfectly good hunks of metal into chips on the floor.
Hondarider is offline   Reply With Quote
Old 12-21-2011, 05:40 AM   #9
mike-s
2 squeaky wheels
Oddometer: 609
This is going to be an interesting thread to follow.
mike-s is offline   Reply With Quote
Old 12-21-2011, 04:56 PM   #10
davesupreme
grand poobah
Oddometer: 1,466
nice..... i've been dreaming about doing this for my ZRX. it's a total pain trying to tune the pilots on 4 carbs, would be way easier w/FCR style aftermarket needles....
davesupreme is offline   Reply With Quote
Old 12-23-2011, 09:32 AM   #11
Brad Felmey
Brad Felmey's Avatar
Oddometer: 4,996
Indeedy. Subscribed.
Brad Felmey is offline   Reply With Quote
Old 12-24-2011, 02:36 PM   #12
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,567
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 12-24-2011, 05:40 PM   #13
cyclewizard
cyclewizard's Avatar
Oddometer: 4,811
Custom made Con Rods..
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 12-24-2011, 05:45 PM   #14
cyclewizard
Oddometer: 4,811
Custom made piston for my 727xrr..
C-dub......
Old 12-24-2011, 05:53 PM   #15
cyclewizard
Oddometer: 4,811
Custom made race crank..
C-dub......
Times are GMT -7.   It's 12:05 PM.
