12-04-2012, 06:10 PM
#46 | |
WFO for 41 years
Oddometer: 4,012
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
12-04-2012, 06:32 PM
#47 |
Oddometer: 937
12-04-2012, 08:18 PM
#48 |
Oddometer: 18
I was going to go that route, but then figured with a puller on the way, I'd just wait. If I end up baking it, do you recommend a certain temp? For how long?
It's just the right hand side of the case, with the crank. Oil pump is still attached. I have an old baking sheet in my shop I can put the case in. Maybe baste it with a nice little 5W-30? Ha! Thanks, Scott |
12-05-2012, 06:52 AM
#49 | |
Oddometer: 937
Remove the oil pump as you might as well replace the gasket anyhow. I put mine in the oven at 250 but the crank and bearing fell out before that point, the pinion tool was a waste of money for me, could not hold up to the pressure. Make sure you post pics of the parts in the oven if the wife or girlfriend sees them. |
12-05-2012, 12:16 PM
#50 |
Oddometer: 18
I'll try the oven. Just curious: did you do the sludge trap with bearing and pinion in place, or did you remove them after the crank was out of the case?
Thanks! |
12-05-2012, 01:13 PM
#51 |
Oddometer: 18
20 minutes at 250 didn't do anything. Even with a few gentle taps with a dead blow hammer.
Think I should try longer? ![]()
12-05-2012, 02:24 PM
#52 |
Oddometer: 734
by putting the whole thing in the oven it all expands at the same rate. This method works for just the crankcase prior to dropping the bearing ( which you put in the fridge before hand) in on assembly.
I'd use a heat gun around the bearing housing. I take it you fitting new bearings after using a hammer on them. The puller fits over the pinion gear and pulls off without heat....well it should do. On the 650s the three gears have dots that line up for the cam timing with one keyway on each, although I have ones with 3 keyways that require dial guages to set up... Earlier models have a timed cam breather but I'm not sure on the 750's. Have fun with your Triumph. |
12-05-2012, 03:58 PM
#53 |
Oddometer: 18
Well the puller came today and after a little bit of wrestling, I got it over the gear and without too much effort, the gear came off! Meanwhile the crank is still firmly stuck in the bearing, so I'm not done yet.
12-05-2012, 05:17 PM
#54 |
WFO for 41 years
Oddometer: 4,012
Chant with me.... heat gun, heat gun...
12-05-2012, 05:23 PM
#55 | |
WFO for 41 years
Oddometer: 4,012
12-05-2012, 05:41 PM
#56 | |
WFO for 41 years
Oddometer: 4,012
12-05-2012, 05:43 PM
#57 | |
WFO for 41 years
Oddometer: 4,012
12-05-2012, 05:46 PM
#58 |
Oddometer: 18
I've got a heat gun (electric type) so I can use that tomorrow. I'm just happy to have the pinion off in one piece.
12-05-2012, 06:05 PM
#59 |
WFO for 41 years
Oddometer: 4,012
Is it a for-real HeatMaster industrial gun? You may still need a bit of judiciously applied propane torch in the general area around the bearing. Good luck!
12-05-2012, 08:04 PM
#60 |
Oddometer: 18
I don't know if it's HeatMaster, but it's an industrial heat gun. I'll try that before anything else. It gets plenty hot.
I really appreciate all the help! I've gone through the manuals, watched all the videos, but when it doesn't do what it's supposd to, it's nice to have a group who've lived through it. Thanks. |
