Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 01-06-2012, 04:28 PM   #121
stuartdivebum
assume first
stuartdivebum's Avatar
Oddometer: 91
Older 1911s
Feeding is an almost pistol by pistol basis on older govt issue 1911s, some will feed HPs and some wont, mine likes every thing but light loads and wadcutter. Now as for SWC ammo if you are talking about wadcutter then special Light load recoil springs are needed as most SWC is lightly loaded powder wise and would have trouble cycling thru any semi auto not set up for them. It would be Much easier to just get a .22 conversion kit.
Living proof that medical science has taken natural selection out of the equation.
2002 ZRX1200R
2001 ST1100 TCS ABS
stuartdivebum is offline   Reply With Quote
Old 01-07-2012, 09:05 PM   #122
McNeal
Oddometer: 1,738
My semi-wad cutter loads aren't light loads. I load 5.2g of 231 and my load book indicates I can make major power factor by bumping that up to 5.7g. I also run stock springs in my 1911 so that's another indication the loads aren't light.
Your comment about light loads might be the cause for comments that I remember hearing years ago. Someone had problems shooting these loads and blamed the gun instead of understanding the real problem.
McNeal is offline   Reply With Quote
Old 01-08-2012, 10:06 AM   #123
stuartdivebum
assume first
Oddometer: 91
On SWC, because of the bullet’s shape, terminal performance is less than stellar. Im not sure why they would be loaded up to full house spec as their design purpose is simply to make tidy holes in paper plus the problems of lead fouling. Ive taken florida wild hogs with the 230gr FMJ hardball and they just go down like puppets with the strings cut. This is my EDC I built from a Springer frame and series 80 slide. Very reliable, very accurate. It was built fairly close to M45 MEU SOC spec (used SS frame) Just under a grand Invested as I did the work myself.
2002 ZRX1200R
2001 ST1100 TCS ABS
stuartdivebum screwed with this post 01-11-2012 at 06:33 PM
Old 01-08-2012, 11:37 AM   #124
ttpete
Rectum Non Bustibus
Oddometer: 5,822
On SWC, because of the bullet’s shape, terminal performance is less than stellar. Im not sure why they would be loaded up to full house spec as their design purpose is simply to make tidy holes in paper plus the problems of lead fouling. Ive taken florida wild hogs with the 230gr FMJ hardball and they just go down like puppets with the strings cut. This is my EDC I built from a Springer frame and series 80 slide. Very reliable, very accurate. It was built fairly close to M45 MEUSCOC spec (used SS frame) Just under a grand Invested as I did the work myself.
If the 200 SWC is loaded to the proper velocity for 25 and 50 yard target shooting, it won't lead as long as the alloy's hard enough and a good lube is used. I've shot many thousands of rounds of it.
15 BMW RnineT
09 Kaw Versys
Old 01-08-2012, 01:37 PM   #125
stuartdivebum
assume first
Oddometer: 91
No disagreement from me
2002 ZRX1200R
2001 ST1100 TCS ABS
Old 01-08-2012, 06:15 PM   #126
McNeal
Oddometer: 1,738
I've been using Oregon Trail Laser Cast bullets for at least 10 years now. My load data claims my reloads should be in the 800fps range and a major power factor can be achieved which will push the lead at just over 900fps. Someday I'll get a chrono and see what I actually get out of these loads, but they have worked well for me.
Never had a spot of trouble with leading either.
Old 01-09-2012, 04:37 PM   #127
mustang
Lurker Extraordinaire
mustang's Avatar
Oddometer: 635
for the ops price range he can get two of these ............
mustang is offline   Reply With Quote
Old 01-09-2012, 04:45 PM   #128
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Yup.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 01-09-2012, 06:21 PM   #129
catang5oh
Blithering Idiot
catang5oh's Avatar
Oddometer: 598
Originally Posted by EvilGenius View Post
Yup.
That's what I am talking about!
Central_Alabama_Tag_Map
09 KLR650 (The Red One)
06 GSXR600
08 Ninja250(Hers)
99 Venture
05 CRF230
catang5oh is offline   Reply With Quote
Old 01-10-2012, 08:01 AM   #130
VTvfr
VTvfr's Avatar
Oddometer: 432
I've been looking at those as well.
Is it worth getting the standard version for $450 and then building it in to a better performer or buying the match version at $800?
Chad
'07 990 Adv
'07 250 XC-W
(plated)
'03 600RR
(track duty only now)
'94 VFR750 (sold)
VTvfr is offline   Reply With Quote
Old 01-10-2012, 08:31 AM   #131
stuartdivebum
assume first
Oddometer: 91
My thought would be the tactical version, better sights, extended thumb safety, ramped for HPs, lowered and flared ejection port, beavertail safety(even tho its a bit large and swoopy for my taste). You can always change a few things to fit your tastes but you wont have to change much.
2002 ZRX1200R
2001 ST1100 TCS ABS
Old 01-10-2012, 08:37 AM   #132
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
My thought would be the tactical version, better sights, extended thumb safety, ramped for HPs, lowered and flared ejection port, beavertail safety(even tho its a bit large and swoopy for my taste)Better trigger too. You can always change a few things to fit your tastes but you wont have to change much.
+1
With the tac you get a bunch of mods most people end up doing already on it for about $50-$100 more.
Then change as needed.
Old 01-10-2012, 08:45 AM   #133
mustang
mustang's Avatar
Oddometer: 635
I don't think it needs add-ons the tacticals are pretty damn good shooters !
it will shoot the 9 ring and center out of a 7 inch target at 25 yards right out of the box
mine was $500 and only thing I did was lose the plastic grips . like mentioned it shoots anything I feed it , I love this gun
Old 01-10-2012, 09:18 AM   #134
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Get the Tactical version for $35.00 more than the GI and you will never look back. Here's mine now.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 01-10-2012, 10:30 AM   #135
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
+1
Put 1000rds of cheap ammo through mine and it's been perfect everytime.
Also plenty more accurate than I am.
Thread Tools
Times are GMT -7.   It's 10:48 PM.
