Old 04-13-2013, 10:20 AM   #511
flyingjib
flyingjib's Avatar
Oddometer: 25
Originally Posted by GB View Post
Don't cut off the ring connectors; attach them to the battery. Then run the red wire to your fuse block and attach to the positive side. This powers the MM relay when the power is turned on. It couldn't be simpler. The supplied switch is now energized and the red LED should glow.
Thanks GB, much appreciated. Just to clarify: Attach the red and black ring connectors to the battery and the single red from the switch to the fuse block? That sounds too simple.
Earl
Always keep an edge on your knife, son.
flyingjib is offline   Reply With Quote
Old 04-13-2013, 01:01 PM   #512
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Earl
Earl,
Red and Black ring terminals to battery and lone red wire to any switched power source. If the fuse block is switched (only provides power when the key is on), then that will work.
thanks,
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 04-13-2013, 01:07 PM   #513
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Originally Posted by humvee View Post
Finally warmed up enough to spend a few hours in the garage so I installed my lights and took them for a ride. What a great product at a great price.
How worried should I be about getting the on/off switch wet? It doesn't look particularly waterproof, compared to the rest of the kit.
The switch will stand up to the elements.
I wouldnt take it underwater (looks like your KLR might be capable of it ), but it will hold up. There are silicone sprays available that can help to seal it if your expecting to get really wet. They can be messy so if you go that route be careful of overspray.
thanks for the feedback and review.
Wish it would warm up a some here... we got blowing snow at the moment
Thanks,
-Brian
Old 04-13-2013, 02:43 PM   #514
flyingjib
flyingjib's Avatar
Oddometer: 25
Originally Posted by The Toad View Post
Earl,
thanks,
-Brian
Thanks for the confirmation Brian. Simple enough. I'm slow but will post some pics when complete. I'm working on a couple of other additions to the Wee at the same time.
Earl
Old 04-14-2013, 12:11 AM   #515
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,090
Order sent for a set MM10s
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is online now   Reply With Quote
Old 04-15-2013, 11:31 AM   #516
rizzo1968
Oddometer: 10
Ideas
Love the lights any ideas where i could mount these on a 2001 honda xr 650L. I have couple of ideas...just like to see other options...Thanks
rizzo1968 is offline   Reply With Quote
Old 04-16-2013, 05:29 AM   #517
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,815
Nice to sea the connectors & on/off switch upgraded, the cheesey OLD home depot connectors were a joke as well as the switch.
RIDE ON!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Old 04-16-2013, 08:37 AM   #518
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
I have a set mounted fender height on my DRZ that work really well for me. Just removed the side reflectors and bolted them up. They are small enough to not interfere with steering at full lock. Not sure if thats an option for you or not on the XR? The MM10's are light enough to bolt on to just about anywhere. Before you settle on a permanent home double check that the surface is rigid enough to avoid heavy vibration at speed or over rough stuff.
When its not obvious where to install them, creativity goes a long way.
thanks,
-Brian
Old 04-16-2013, 08:49 AM   #519
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Tiger 800
We have put together a hardware kit to mount the MM10's on the Tiger 800 very near where the OEM Aux lights would be.
It makes for a simple and clean (near factory look) install.
These hardware kits are rust proof and make it easy to install the light kit using exsisting mounting points on the Tiger 800 (also available for the 08- 10 Kawaski Versys).
We are working on more and hope to have more bike specific mounts available soon.
thanks,
-Brian
Old 04-17-2013, 02:53 PM   #520
fluff34567
fluff34567's Avatar
Oddometer: 1,077
do you have any comparison long range shots of your different models or agaimst other manufacturers ?
something out in the open without street lighting ?
fluff34567 is offline   Reply With Quote
Old 04-17-2013, 04:55 PM   #521
Flyboy52219
Flyboy52219's Avatar
Oddometer: 69
thanks,
-Brian
Brian - will this work on the Tiger 800 XC? If so I will be placing and order for them. They look great.
Flyboy52219 is offline   Reply With Quote
Old 04-21-2013, 10:40 AM   #522
geauXplor
gō-ikˈsplôr
geauXplor's Avatar
Oddometer: 319
Mm8
Brian, any idea when you will have MM8's in stock? Thanks.
Robert
“Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.” - Mark Twain
geauXplor is offline   Reply With Quote
Old 04-23-2013, 02:38 PM   #523
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
The hardware kit will work equally well on the XC.
thanks,
-Brian
Old 04-23-2013, 02:40 PM   #524
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
We do not.
We were working on this last year, but just not enough time in the day. At this point its safe to say we will let our reputation and feedback speak for the MM10's.
thanks,
-Brian
Old 04-23-2013, 02:42 PM   #525
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Sorry we do not have a good ETA for the MM8 light kit. We do have some that were on demo bikes that may be coming off soon. If so, I will offer them up here for a discounted price.
thanks,
-Brian
Times are GMT -7.   It's 06:27 PM.
