Old 03-25-2012, 08:14 AM   #166
P B G
Oddometer: 9,781
Originally Posted by WacoDirtryder View Post
Every thing they sell is junk.
Relatively yes.
Their screwdrivers arent Wiha, Their tool-chests aren't waterloo. Heatguns aren't master.
But your comment is worthless. Many of their items are good enough to be worth the low price.
I would argue that if not for low price tools there are many people out there who wouldn't have tools at all.
Old 03-25-2012, 08:27 AM   #167
Warney
Warney's Avatar
Oddometer: 442
I seriously pondered the HF US General 4-drawer Service Cart @ $99 but opted for the heavier built Harbor Freight US General 5-drawer Service Cart (available @ $159), coupon in latest Motor Trend magazine. That is an excellent tool cart, better than anything priced within several hunderd dollars of it.
HF Driveway Alarm, bought it on sale, works ok. Appears you could use multiple sensors if they are on the same frequency. Still experimenting with it but so far so good.
My HF rule is never buy anything without a coupon. Pick up the free Centech VOM or whatever other freebie they are offering while you are there. Slickdeals always has coupons available for printing.
Warney is offline   Reply With Quote
Old 03-25-2012, 02:37 PM   #168
barko1
barko1
barko1's Avatar
Oddometer: 2,512
Tool chest does a great job for me, hydraulic bike lift is great, heat gun is used a lot, plenty of their stuff is just fine. I stay away from the more complicated or electronic and you do have to watch their constantly changing prices.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi
barko1 is offline   Reply With Quote
Old 03-25-2012, 03:14 PM   #169
P B G
Oddometer: 9,781
Even then, I have some ok luck with their electrical stuff, I have a cordless vibrating tool I use a few times a week.
Old 03-25-2012, 08:05 PM   #170
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 353
Ummmm......
When you can get it away from your wife right?
Dusty_Bottoms is offline   Reply With Quote
Old 03-25-2012, 08:14 PM   #171
barko1
barko1
barko1's Avatar
Oddometer: 2,512
Don't think I'll be wanting to borrow it
Old 03-25-2012, 08:18 PM   #172
frog
frog's Avatar
Oddometer: 2,624
I've had a 3 inch cut off air tool for 8 years. Paid $8. And six of that 8 I was a diesel tech using very often. But your right everything they sell is junk. Btw I still have it and use it. Works great.
Sent from my Galaxy Nexus using Tapatalk
Thank you MX1WEST, Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
Moving??? Two Man Movers
frog is online now   Reply With Quote
Old 03-25-2012, 09:02 PM   #173
P B G
Oddometer: 9,781
My gf would not even catch the inuendo. but Bravo.
Old 03-25-2012, 09:28 PM   #174
JSharp
Oddometer: 214
Send a message via Yahoo to JSharp
A few things that others have mentioned that I've had good luck with -
The 20 ton press. A few shims and it's been great. Mine has become part of the neighborhood tool collective since no one else seems to have a press. It's not a Dake but it was under $150 on sale with a coupon.
The auto darkening welding helmet. No complaints.
The orange dead blow hammers are fine.
The $5 battery minders. I have 3 of them. The voltage is accurate enough to keep small batteries up in cold weather and I haven't had one fail yet. I didn't take any of them apart but I assumed they were just a simple 3 terminal regulator circuit.
The step drills. They're great for thin sheet or wood or plastic. I wouldn't try them on real steel.
The 6" digital calipers. I have good Mitutoyo calipers both here and at work. But I bought a set of the HF cheapies to leave in the garage and a few sets more for people at work so they'll stop borrowing my good Mit's.
Now some things I haven't seen mentioned -
3/4" socket set.
I have the older one in the red metal case. It's been fine for working on my old tractor.
2 ton shop crane.
We've pulled multiple engines with this and I use it all the time to pick up the front of my mower to remove the deck.
4" angle grinder.
Under $20 on sale with a coupon. If you have a large enough compressor to run it you'll throw your 4" electric grinder away.
3" cutoff tool
It beats dragging a torch out for small stuff.
Split leather work gloves.
These go on sale for about $2 a pair. Hard to find any leather gloves that cheap and they hold up ok.
1/2 a success for their $30 swingarm stand
I got one of these for under $20 on sale with a coupon to modify so I'd have a fork stand. The bends are cooked as hell and the adjustments are so sloppy it's embarrassing. But I cut a couple of inches off of it and made some pin adapters to replace the swingarm pads and it works fine on my Ninja forks. A friend of my kid's uses one unmodified on his Busa.
I'm sure there are more if I think about it.
Now for some failures -
Ever have a c-clamp snap in 1/2 with just hand pressure used to tighten it?
How can you make an air chuck for tire valves that can't fill tires but still leaks?
How about a rafter square that isn't square?
2011 Ninja 1000
JSharp screwed with this post 03-25-2012 at 09:35 PM
JSharp is online now   Reply With Quote
Old 03-26-2012, 10:27 AM   #175
Alton
Oddometer: 288
PASS on the hose reel:
It isn't 100% perfect, but for the price it works SO much better than my brother's $50 retractable reel from HD.
Alton is offline   Reply With Quote
Old 03-26-2012, 01:53 PM   #176
barko1
barko1
barko1's Avatar
Oddometer: 2,512
By saying pass I thought you meant skip it. I bought one on sale not long ago and is has been fine. Better than just floppin the hose around, well that's not so bad ut I like the reel.
Old 03-27-2012, 07:53 AM   #177
Alton
Oddometer: 288
I went through the first page and thought we were doing PASS/FAIL.
Old 03-27-2012, 08:22 AM   #178
wcohl
Oddometer: 122
I've had mixed results.
The bad
Their $3 electrical multi meter failked 2 times, was replaced twice and then refunded my money. Bought a Radio Shack meter.
I've split several impact sockets 19mm and smaller, the big ones are holding up. I replaced the broken ones with individaul Craftsman brand sockets.
Cut-off wheel with plastic housing had so much interanl drag, I had to sping the wheel by hand to get is started. The one with a metal housing works fine.
Metric wrench set bought to carry in my car. One of the wrenchs was not metric. IRC, the 17mm was labeled 5/8 or the closest SAE equivalent. Work OKs in an emergency.
The good
Jack stands work well
$20 pneumatic stapler for T50 staples works great. Mucj better than the name brand electric staplers I bought at Lowes
Metal housed cut-off wheel works great.
Torx head sockets work great
ATV lift stand works great
Free LED flashlights work great, normall cost $3 or less without coupon.
Internal ID/pilot bearing puller works great
YMMV
wcohl is offline   Reply With Quote
Old 03-29-2012, 12:31 PM   #179
2Stamp
2Stamp's Avatar
Oddometer: 170
I broke my Torque wrench from them last week tightening up a 74lb nut. Surprised me.
_______________________________
2011 F800GS
2006 450EXC
2001 F650GS (Sold)
2008 WR250R (Sold)
2Stamp is offline   Reply With Quote
Old 03-29-2012, 01:04 PM   #180
MrPulldown
MrPulldown's Avatar
Oddometer: 1,249
Just returned an item at Hf. I never return stuff there.
The self priming siphon hose. It is a copy of a super siphon. The thing jsut does not work. If it was a couple of bucks I would have kept it, but it was 8. Might hvae been becuase the hose had some kinks in it. But It would not start I spihon. Tired several times, with the sorce fluid as high as the hose would allow me to go.
I even stuck a stick in the hose in order to straighten it out, and left it for several days. It jsut won't flow.
Just bought a real super siphon. Let's see if it does better.
94 DR 350 SE
MrPulldown is online now   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
