Old 03-30-2012, 09:38 PM   #181
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,915
Originally Posted by WacoDirtryder View Post
Every thing they sell is junk.
Wow, useful input!
Jim
Old 04-04-2012, 07:28 AM   #182
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,915
All my Torx sockets and wrenches have been great, and inexpensive.
Pass.
Pin punches were aweful. Soft tips that deformed if used on anything harder than card board.
FAIL!
Jim
PS Click on the photos for a link to the tools.
Old 04-04-2012, 10:45 AM   #183
Tweaker
Oddometer: 8,177
Originally Posted by JSharp View Post
How about a rafter square that isn't square?
Yea, I picked through and compared a bunch on the racks one day and couldn't figure out which one was right.
Tweaker is offline   Reply With Quote
Old 04-05-2012, 02:31 PM   #184
Gamble
b00b
Oddometer: 7
I have the large (not the XL) harbor freight tool box and top box. I give it an A+++. Awesome. Not as good as the $10k snap on, but I only paid around $700-$800 for both. Comes with liners and ball bearing drawers.
HF Chop saw. I give it a B. Works good, but the clamp broke on me. So it won't hold the piece of work in there steady.
HF horizontal/vertical bandsaw. I give it an A.
The blade that came with it wasn't bad actually. I probably made a good 40+ cuts. The thin that sucks is the stand. It's USELESS. Plus you can use the 20% off coupon on this thing!!
HF Colored sockets. A+
A few have chipped but overall great. Never broke one.
HF welding helmet. B+
Need a good welding helmet on the cheap. These work good. Good for mig and stick....don't use it for tig.
HF 90amp flux welder (blue one) B-
Not bad, does the job. Great for small jobs and learning how to weld without breaking the bank. The wire that comes with it is junk.
HF Tubing notcher. C+
Well it notches tubes..but not straight. Had to shim out the side which took 5 minutes and some metal. I think I got a bad one because the sleeve inside broke free and moves, but it still notches well. Don't expect to put a cage or anything together before you shim out the part that holds the tube. Look on youtube a guy showed how to do it.
HF welding cart. B
The little blue car it decent. No handle to push it around so I made one, downside is that it flexs because the metal they used to make this is really thin. Overall not bad.
HF belt/disc sander. B+
Belt sander and 6" disc sander. Bought it and asked the cashier if it came with sandpaper and she said no so i had to get some. Guess what, it came with sandpaper. Directions suck. The piecd that you rest your wood/metal on can switch from each sander. The body seems to be cast (home depot ryobi looks to be aluminum). The long belt will move side to side if you push too hard on what your sanding. Overall it's really nice and I use it on a daily basis!
HF 18" hand brake B+
For bending sheet metal and alumium. Works well. A few different dies wouldn't hurt but it only comes with 1. I recommend you get 2 or 3 c-clamps to hold the die down while you use it. Handles are not casted in, so you just slide them in and out when you need them. I think it works good, would be better if I knew what I was doing :p
HF Unibits A+
Why spend $48 at the store for 1 unibit when you can get 3 sizes for $12.99. I have had these for a long time and only 1 of them is slightly dull but still works great
HF Sandblast cabinet (the $119 one) B
You need to calk or seal up the edges. Last owner did it for me. The light is meh, a brighter one would work better.
HF doens't sell replacment gloves or covers for the glass. So if it rips or anything your SOL
Gamble is offline   Reply With Quote
Old 04-05-2012, 02:35 PM   #185
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,915
Thanks Gamble, great reviews! Useful input on some I haven't had.
I agree on the Unibits, I only wish they had larger sizes.
Jim
Old 04-05-2012, 07:54 PM   #186
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,607
Originally Posted by wacodirtryder View Post
every thing they sell is junk.
+1,000
Mutt'n the custard.
On the outside with my back turned.
B.Curvin is offline   Reply With Quote
Old 04-06-2012, 06:03 AM   #187
groundrules
groundrules's Avatar
Oddometer: 891
Originally Posted by B.Curvin View Post
+1,000
your opinion might also be expressed as +$1,000.
groundrules is offline   Reply With Quote
Old 04-06-2012, 08:34 AM   #188
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,607
That may be. But when I buy a snap-on die grinder that's made in Murphy, NC an hour from my house I feel good about helping the folks that work there keep their jobs. If I help them keep their health insurance, it might just be my anti-inflammatories they'll be able to afford when they go to the doctor.
Mutt'n the custard.
Old 04-06-2012, 01:59 PM   #189
fbj913
fbj913's Avatar
Oddometer: 1,876
It has all worked fine for me!
Ride 365 LLC
Braaaap!
fbj913 is offline   Reply With Quote
Old 04-06-2012, 03:13 PM   #190
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,915
This thread is about rating tools you have actually used. This type of input is completely useless to anyone reading this thread, which you obviously did not!
From the first post:
"This thread is NOT about wheather or not you should buy things from China, or anywhere else. It IS about helping people decide the good values from the bad at Harbor Freight. Please do not waste our time with rants about HF and Chinese crap."
Jim
Old 04-08-2012, 08:43 AM   #191
frog
frog's Avatar
Oddometer: 2,642
Jim
+1000
Sent from my Galaxy Nexus using Tapatalk
Thank you MX1WEST, Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
Moving??? Two Man Movers
frog is online now   Reply With Quote
Old 04-08-2012, 06:44 PM   #192
LI LT Owner
Wrong Island, NY
LI LT Owner's Avatar
Oddometer: 1,244
Rifle Cabinet
Has anyone here tried this gun safe?
List price: $399
Sale: $350
25% of regular price = $299
25% of sale price= $262
Wife hates my current safe (a padlock cabinet taken home from school) and this one looks like it will fit nicely into a closet. Their reviews are solid.
Rob VB
2003 BMW K1200LT
2002 BMW R1150R
My Blog- Kickin' Tires and Telling Lies
LI LT Owner is offline   Reply With Quote
Old 04-08-2012, 06:49 PM   #193
fung
fung's Avatar
Oddometer: 283
I bought the $9.99 torque wrench and it started to come apart as I took it out of the box. I should have known better.
fung is offline   Reply With Quote
Old 04-08-2012, 07:42 PM   #194
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 1,340
True - never pick the torque wrench box that rattles!
The friendly folks'll be happy to give you more intact example.
Always wanted an inch-pound torque wrench, but didn't want to spend lot$ on one. I recently got the 1/4" torque wrench 2696 for $11.99 and have used it a couple of times with no problems.
(BONUS - comes in a red plastic fitted storage box) - PASS
HapHazard is offline   Reply With Quote
Old 04-09-2012, 06:19 AM   #195
Gary B.
Older than dirt...
Gary B.'s Avatar
Oddometer: 542
Been using this spray gun for several months now. No complaints.
http://www.harborfreight.com/hvlp-de...gun-46719.html
"Male menopause is a lot more fun than female menopause. With female menopause you gain weight and get hot flashes. Male menopause ? you get to date young girls and drive motorcycles."----- John Wayne
DR stands for "Daily Rider"
'06 Suzuki DR650SE
'06 Kawasaki Concours - 2up Cruiser
'99 Yamaha YZ400
'05 KTM 125SX-SOLD!!!
'90 KTM LC4-the bike's gone, but the memory remains, along with the oil spots on the floor
Gary B. is offline   Reply With Quote
Times are GMT -7.   It's 10:56 PM.
