Old 12-31-2011, 10:15 AM   #1
TedT OP
Oddometer: 43
Talking The s/trx250b9sf3 build thread
Well I've been meaning to get a thread going on this bike for awhile now. Some of the local inmates have seen the progress, slow as it is, and I figure it's time to let the project be seen by the interwebs at large.
First of all, what it is. The frame started life out as a yamaha srx 250 that was bought locally by someone who over the years beat it with what appears to be several large hammers until I got it a few years back. Now the stock motor ran, but poorly, and the electric starter had been removed and replaced with a piece of cardboard, if this tells you anything about the state of the bike. The clip-ons were bent, the tank had been caved in several times and generally the bike looked to be on its last legs.
Enter my father and I. We had a couple of old racing motors from my superkart days in the basement: A '95 CR 250, and this '85 ATC250R (which is identical to the TRX250R engine). We went with the ATC motor, because the CR vibrates to kingdom come and it lacks a sixth gear and lighting coil.
Now you can see where we're going with this. Out with the old 250, in with something a little (or a lot) faster. While I'm at it, why not update the suspension out of the Regan era and make it handle and stop a little better? Enter the Buell xb9s suspension and wheel setup. Why? Well the ZTL brake setup looks cool, and it was available. Plus, why not?
The rear swingarm has been an issue, one which I hope to solve with the use of a swingarm off of a CBR 600F3. Why the CBR? It has a chain drive, drives off the correct side, it's cheap, and they're plentiful. The stock Buell swingarm would have worked, but for the fact that it's a belt drive that drives off the right. So the first order of business is to get this swingarm on the frame and figure out the shock and rear axle/pivot bolt. Once I have parts in hand I'll know if I'm going to be making linkage setups or not. Then the back tire, motor mount, radiator mount, get the old DA system set up and running (I'm going to need to see what this motor is doing, it's a fully-built motor and I'm going from scratch on jetting/gearing), then wire in the lights, and it's done. Sounds simple, right?
The goal for this whole bike is to weigh as little as possible (I'm shooting for 250lbs as a target), handle well, and basically just be a little fun bike to ride around on.
I'll have pics up soon, once I find my camera and take a few of them.
TedT is offline   Reply With Quote
Old 01-01-2012, 12:09 PM   #2
TerraRoot
Oddometer: 61
well you had a day where are those pics? in my imagination this project sounds awesome.
TerraRoot is offline   Reply With Quote
Old 01-01-2012, 01:05 PM   #3
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,853
I iz waitin patiently.I swearz.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-01-2012, 08:36 PM   #4
jake28
Riding to the horizon.
jake28's Avatar
Oddometer: 391
Subscribed. Do great things.
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS
jake28 is offline   Reply With Quote
Old 01-01-2012, 08:59 PM   #5
TedT OP
Oddometer: 43
Got the camera and a few pics! Now my computer is making ominous noises. Let me see if I can get on another compy to upload them.
Old 01-01-2012, 09:49 PM   #6
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,442
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 01-02-2012, 03:56 PM   #7
TedT OP
Oddometer: 43
Okay so I'm going to give this a shot here to see what happens. Hopefully my computer stays running long enough!
This first shot is of the frame in the jig. It's an engine hoist, but it does the trick well and makes welding this frame up much easier. I've so far stuck to just reinforcing/finishing the welds that are currently on the frame, since I'm putting a lot more power in there I figure that I might need to also do some additional bracing to deal with it.
Here's a close-up of the work I've done so far:
Here are the footpeg mounts, lots of hours of hand-sanding and blasting later, they're looking good! I can't believe Yamaha would let a bracket like this go with such poor quality.
The tank. Previously filled in with so much bondo that paint would not adhere to it, and yes those are some serious holes in the bottom of it. The metal is too thin for welding, at least with a MIG setup. Might have to teach myself how to TIG or ??? to get this thing back into shape, since finding these tanks is next to impossible anymore.
So that's where I am as of right now. Going to go do some more work on the frame and hope that the swingarm arrives tomorrow so I can get that on and start work on the motor mounts.
Old 01-02-2012, 06:30 PM   #8
TedT OP
Oddometer: 43
Well I did a few more things here, only got a pic of the potential frame brace. I'm thinking that this will allow easy access to the motor, yet still stiffen the frame.
Now that's the main bar, or a scrap alternative for now, held up by a really long magnet. I'd also tie it in trellis-style to the bar just above it.
I also knocked a very large pile of rust out of the tank, and judging by the sounds in the tank, there is a lot more to take out. I'm starting to think that I better hope for an Ebay miracle.
Okay, enough of me. Time to leave the shop and head home.
Old 01-03-2012, 01:36 AM   #9
DRjoe
DRjoe's Avatar
Oddometer: 5,318
When you say you have finished the welds have you welded the gussets across the tubes?
I'm using my Phone so I can't see in the photos.
DRjoe is online now   Reply With Quote
Old 01-03-2012, 03:14 AM   #10
TedT OP
Oddometer: 43
Yeah, basically all I've done so far is to finish the welds across the tubes that were not done from the factory. I haven't started in on any major bracing or fixing the broken mount on the frame just yet because I'm still waiting on the swingarm to do the final engine placement. The way I saw it, a fully welded tube would give me a little more strength than one that was only welded enough to keep it from breaking off entirely.
Old 01-03-2012, 05:06 AM   #11
SwedeMix
SwedeMix's Avatar
Oddometer: 30
["Why? Well the ZTL brake setup looks cool, and it was available. Plus, why not?"]
Thatīs well put, I have nothing but respect for that kind of thinking! Itīs your bike, a kind of a master of your own destiny type deal, and I applaud whatever type of bikeīs being handbuilt
Iīve had my fair share of failed projects, finally coming to terms with not being capable (on my own at least) to pull off one of these huge builds. Therefore, I have even more respect for those who actually do, and make it look good too!
Good luck, keep the focus and dont forget why you started the build in the first place! (personal experience..)
Cheers
SwedeMix is offline   Reply With Quote
Old 01-03-2012, 11:38 AM   #12
jake28
jake28's Avatar
Oddometer: 391
I'm a huge fan of these projects and have a few in the garage right now. I'm no engineer, but I can't see what that length of flat bar is going to add to the frame. The frame doesn't flex across the span that you have filled. And it is heinously ugly which I would forgive if there weren't few great street builds out there.
I think you would be better off in performance and looks gusseting the frame at the steering head and pivot points. Adding flat bar across the frame just because you can isn't the answer.
Post a copy of the photo in this thread for some real expert insight.
Still a huge fan and looking forward to following this.
jake
Old 01-03-2012, 12:51 PM   #13
DRjoe
DRjoe's Avatar
Oddometer: 5,318
Oh
Um as far as I know the factory do that on purpose to stop cracking.
From my very limited knowledge on the subject I think what you have done is focused all the stress in to one point by welding across the tube which can lead to cracking across the tube.
There is a great thread on here called "some advice required" that you could ask about frame reinforcing, Your garuanteed to get a better explanation from there.
Old 01-03-2012, 02:58 PM   #14
TedT OP
Oddometer: 43
Thanks for the comments and advice so far, guys! As far as the brace situation, I'm not using that piece I put up there. I'm just attempting to get an idea of what will work where. I'm definitely going to be seeking out advice here, please do keep it coming. This is definitely new ground for me, things I haven't touched on in any aspect since my karting days. Most of my other builds have been relatively tame in comparison, but this time I figure it's time to go big.
The issue I'm trying to combat now rather than after I have the bike together is to eliminate the torque flex (the side-to-side rotational flex) that this motor upgrade will probably bring. The mounting system is going to take up a lot of it, but I'm trying to see if I can stiffen it up more. I'd hate to build it only to find out that I can't enjoy it like I want to be able to!
The steering head is well- braced stock, I'll get a photo of it here in a minute and upload it.
No swingarm yet today. Good time to get involved in some chassis theory though, and get to work on getting a new steering stem made for the Buell front end.
Old 01-03-2012, 05:33 PM   #15
garrett the nerd
Sprocket Protector
garrett the nerd's Avatar
Oddometer: 871
Hey buddy. In for the duration. I'll stop by the shop soon to offer some thoughtful nods and affirmations without actually knowing anything
Certain, swift, and severe.
garrett the nerd is offline   Reply With Quote
Times are GMT -7.   It's 04:52 AM.
