Old 01-04-2012, 09:04 PM   #1
Just Paul OP
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,099
Best Mod ever for quick, no mess oil changes for your 9*0
Hey KTM 990 Owners,
I was at my buddy Chris's house (Bikyto on ADV) and bitching about my messy 50 minute oil changes and how hard it can be to get the screw back into the sump with the metal bracket in the way when doing oil changes. He said O I fixed that and he showed me his and I was like wow you don't have to take the screw out anymore. (see Pic)
I was installing the Scotts Auto Chain Oiler at the time and taking my bike to Tim's (Quik on ADV) for help on a valve check so I already had the tanks off.. Sweet !
While the bike was at Tims he ground off the metal piece needed to make the part work and installed the device...
Now I don't spill any oil on the floor when draining my sump.. In the past I have ended up with a ton of oil on the ground that splashed off the metal piece and covered a 3 square foot area in my garage... No more..
This will require
removing crash bars
Removing the upper fairing
Left Tank
unclipping electrical connectors and fuel lines for 990 owners
taking a dremel and grinding away the material
assembing the parts and removing the oil plug and installing the new plug
connecting all the connectors back
and installing tank, upper fairing and crash bars.
Parts list is below and where to get them.. Just copy paste the part numbers into the search bar on Summitracing
Summitracing.com
Part Number Part Description QTY
EAR-9919DFGERL -6 AN TO 12MM-1.5 ADAPTER QTY-1
RUS-632050 PROFLEX HOSE #6-3 QTY-1
SUM-220630 -06 PLUG AN ALUMINUM QTY-1
SUM-220690 6AN HOSE END STRAIGHT QTY-2
Thanks again Chris for sharing this and Tim for doing the work..
Paul
BTW: I don't remove my crashbars or tanks when doing an oil change normally. I am aware of the cardboard funnel trick and the aluminum foil trick (I have 40k on my bike and have used both).. this is better in my opinion.
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 01-05-2012, 10:20 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,605
But its a good chance to give the bike a thorough wash and check over while the tanks are off !
I always totally remove that metal piece, then oil drains straight into a pan, no mess :)
Peanuts is offline   Reply With Quote
Old 01-05-2012, 10:35 AM   #3
Qwik
Adrenaline Addict
Oddometer: 6,704
If you do the Stud mod for the crashbars you cant remove that piece. This makes it easy to drain the oil and you arent going to make a mess doing it. And it looks good as well.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 01-05-2012, 10:57 AM   #4
ok64
Oddometer: 142
I plan to do this mod next time I change the oil.
Some alternatives here:
Oil drain valve
www.oildrainvalve.net/products/F109N-%3A-12mm%252d1.5.html
www.qwikvalve.com/F109N-12mm-1.5-w-nipple.html
http://fumotousa.com
These valves are all the same but sometimes the price differs.
Check out www.ADVSPOT.com, my site with lots of links to Adventure products and information. (I don't sell anything) Send me a PM if you have a link you want to add.
ok64 is offline   Reply With Quote
Old 01-05-2012, 11:18 AM   #5
Qwik
Adrenaline Addict
Oddometer: 6,704
I installed it when the bike had fresh oil and only lost a couple ounces. Got more on my hands than in the oilpan. I will be doing mine soon.
Old 01-05-2012, 11:25 AM   #6
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
I just finished installing my Fumoto valve and drain tube. I'm *almost* looking forward to the next oil change!
A life-altering mod for those of us who do our own work. Looks great!
viola-tor is offline   Reply With Quote
Old 01-05-2012, 04:05 PM   #7
Just Paul OP
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,099
Thx for the positive feedback.
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
Old 01-05-2012, 05:21 PM   #8
Unkgd
Oddometer: 344
Which Fumoto Valve
You wouldn't happen to know or remember the Fumoto valve number that you ordered by any chance? UPDATE - Disregard - It would help if I actually read the whole thread above. Somedays I am, shall we say, lost
I have the Fumoto valves on all my cars and truck - make life much simpler - and cleaner!
Unkgd screwed with this post 01-06-2012 at 08:27 AM Reason: Read the thread
Unkgd is offline   Reply With Quote
Old 01-05-2012, 06:14 PM   #9
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,074
OTW - I will go to the parts fiche and figure it out.
Just to let you know- I've got the Fumoto valve on my bike, have for a while. If I had to do it again, I'd do it Paul's/Chris's way, with the hose and plug. The Fumoto valve is a really tight fit in there (to operate the valve), and I think the hose plug would be more secure.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 01-05-2012, 07:41 PM   #10
Grayjet
Ride on!
Grayjet's Avatar
Oddometer: 434
A few questions
Say, I have a few stupid questions for those that have done the mod. Do you trim the 3 foot hose section down to something shorter? If so, what is the preferred method of cutting a steel braided hose? I have a Dremel and am not afraid to use it! Where do you guys route the hose?
Thanks,
Lance
'93 Honda XR650L
'09 KTM 990 Adventure
Putting miles on the tires!
Grayjet is offline   Reply With Quote
Old 01-05-2012, 08:09 PM   #11
Unkgd
Oddometer: 344
Abrasive cut off wheel
Lance,
Just got through making some AN12 hose oil cooler lines for my STI and used a peanut gridner with a 3 inch cut off wheel. Wrap the area to be cut with packing tape (or some other strong tape) - the cut off wheel makes a nice clean cut - but lots of debris in the hose. Blew it out and washed it out with solvent and paper plugs till it came out clean.
You might be able to do it with a dremel - but I think you will go through a least a couple of cut off wheels.RegardsRegards,
Bill
Thanks,
Lance
Old 01-05-2012, 08:12 PM   #12
Unkgd
Oddometer: 344
Thanks for the info
Old 01-05-2012, 08:18 PM   #13
Grayjet
Ride on!
Grayjet's Avatar
Oddometer: 434
Thanks, Bill!
Lance
Lance,
Bill
'93 Honda XR650L
Old 01-05-2012, 08:23 PM   #14
Qwik
Adrenaline Addict
Oddometer: 6,704
I cut it down to about a foot. The end of the hose sits under the motor.
Old 01-06-2012, 08:19 AM   #15
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,640
I've been using the Quikvalve and a length of plastic tubing. A very nice mod for sure!
Other than aesthetics, I can't see any advantage to using braided line for this. It's not like it is flowing fluid under pressure or is a critical line that needs the protection.
Does look pretty though!
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is online now   Reply With Quote
Times are GMT -7.   It's 04:44 PM.
