03-12-2012, 04:56 PM
#166 |
Unbunch yer panties!
Oddometer: 1,105
As requested, photos of the upper end of the hose:
![]() Wiring: Take two good snug turns around the hose, snug to the bottom of the Red part--the idea is that it cannot lenghten (by unscrewing) with the wire in place: ![]() Twist 'er up... ![]() Pull it up to the first blue nut and take a wrap each direction-make sure it's straight and along the flat of the red part: ![]() This does two things-keeps it from lenghtening (loosening, its gotta get longer if it gets loose), and gives you a visual check. Never -NEVER- wire anything that you PERSONALLY have not checked for tightness. If the vertical run here is slanted diagonally during a later inspection, this joint needs attention. Now twist the wire again and run it in a tightening direction behind the assembly to the anchor point in the aluminum tank bridge--as tightly as you can get it done. This secures the entire assembly from rotation. ![]() Tie it to the anchor-I used the bridge cause I could get to it, but whatever--it's just gotta run in a TIGHTENING direction... ![]() Part one done. ![]() It's probably reasonable to assume that since this pulls the whole hose in a tightening direction, the tank fitting cannot loosen without tightening against the next fitting in line, which shouldn't be possible if you got it tight before wiring. However, the tank fitting comes with a neat little wire groove, and with some care it can be secured as well: ![]() ![]() Note the the wire is slightly over-twisted at the corner of the fitting, so that the wire will grip the nut and not slip. Done! You can see that the hose end fitting (blue, attaches to the tank fitting) is unsecured here, but between the force of the wire wraps in the swivel groove below it and the fact that it's being pulled in a tightening direction against the tank fitting, I'm OK with it as it is. You could pretty easily drill it and wire it directly, but if you got everything as tight as it should be, the wire is mostly to show that YOU tightened it, YOU checked it, and NOBODY ELSE has messed with it since then anyway. It's surely more secure than without the wire. Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
03-12-2012, 05:24 PM
#167 |
oot & aboot
Oddometer: 25,818
Thanks for taking the time to details your safety wire technique Steve
![]() You are giving me bad flashbacks to the first time I safety wired a race bike (it was a 92CBR600F2) - everything was going fine until it came time to drill the banjo bolts for the brakes.... 30 drill bits later I completely understood why pre-drilled bolt kits sold for $300+ and were worth every penny
www.motogeek.com |
03-12-2012, 05:33 PM
#168 |
Oddometer: 1,105
Amen, brother, amen. I hear every word of that!
I'd just leave it alone, but experiences with unsupported levers and vibration just won't let me... Steve
07-08-2012, 12:57 PM
#169 |
ADV Wannabe
Oddometer: 186
Did my first oil change since adding this hose. Done in under 30 mins
Awesome!
08-23-2012, 07:40 AM
#170 |
Major Medical
Oddometer: 3,194
I finally installed the hose and now can't seem to find a way to route it so the stock skid plate doesn't hit it...
anybody have pics? ...or are you all using an aftermarket skid plate with more clearance
Mike Reinheitsgebot '07 990ADV '08 530EXCR '04 XR650L Bonsai Elephant - "Life without a 990 is no life at all!" |
12-26-2012, 12:48 PM
#171 |
crash test dummy!
Oddometer: 2,059
well, that was much to do about nothing. you guys got me all worked up thinking this first oil change was going to take hours....when i fact it took me less than 1hr and that includes doing the oil line mod and cutting the guard to fit.
now that i've added the oil line i bet it will take less than 20 minutes next time. just remove the front 2 bolts holding on the skid plate, swing it out of the way, then drain the oil and filters. no biggie at all. thanks for all the help. nothing like seeing some photo's to help put things into perspective. laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW. '12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
12-26-2012, 08:28 PM
#172 |
Two Wheeled Addict
Oddometer: 5,244
just noticed this but Most of us are running an aftermarket skid plate.. Nice thing with the hose is you can move it around to fit.
Speed bumps never seem to make me go any faster |
12-27-2012, 02:07 PM
#173 |
crash test dummy!
Oddometer: 2,059
has anyone thought about the consequences of removing, or possibilities of replacing the drain plug magnet? i've been thinking about this since doing this mod and i cant make up my mind.
anyone? thanks, laramie
12-27-2012, 02:34 PM
#174 |
Where fun goes to die....
Oddometer: 3,155
You can alays epoxy a powerful magnet to the case next to the drain plug. It would serve the same purpose. More or less.
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
12-27-2012, 03:51 PM
#175 | |
crash test dummy!
Oddometer: 2,059
problem being you would never actually get the metal out of the tank. the whole reason for these things is to catch the metal and not allow it to keep flowing through the engine. it also serves as a big red flag when things are about to go bad. case in point... ![]() granted this was on an LC4, but without that magnet the owner may have kept riding his bike straight into the ground... what we need is something on the top of the hose mod that can be pulled every couple oil changes, or even more if desired. the whole purpose of the oil tube mod is to just drain the oil cleanly and quickly. once it's out, no real problem or mess pulling the hose to check. anyone? laramie
12-27-2012, 04:09 PM
#176 |
AWD please!!
Oddometer: 3,866
You could epoxy a magent on top off the metal sump screen. That should be pulled at least every valve check.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
12-28-2012, 07:22 AM
#177 | |
crash test dummy!
Oddometer: 2,059
thanks, laramie
12-28-2012, 09:26 PM
#178 |
Two Wheeled Addict
Oddometer: 5,244
Get a small Strong magnet and secure it near the top of the hose. When you drain the oil remove the magnet and check the oil afterwards for metal.
12-30-2012, 06:06 AM
#179 | |
They call me......Ronski
Oddometer: 555
![]() ![]() ![]() I'm not sure it would pass Tech Inspection, though.
Ronski Enduro Racer & Google Earth Adventurer |
12-30-2012, 08:21 AM
#180 |
Oddometer: 1,105
I'd run it!
Steve
