Old 01-07-2012, 05:26 AM   #1
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,747
Concrete counter tops
I am building my own counter tops from concrete, I have the floors reinforced so you don't have to warn me etc, etc.
My problem is after I remove the sides of my form ' the size is 7 x 5 by two inches thick' so it can not be precast, the top edge will be crisp, any suggestions on how to smooth it out, a sidewalk finishing trowel with the round over effect will not work as that will an edge on the sides after complete.
So, outside of trying to accomplish this while wet, and not feeling good about trying to do it free hand with a grinder as I feel this will leave a rough uneven edge, anyone have any suggestions on how to round over the crisp edge that will be left removing the form?
The sides are easy, I know to vibrate the form etc, just researching the options for smoothing the top/side transition. I have poured three small practice pieces and even tried my router while the concrete was green, but that was a big fail : . I might try sandpaper and a belt sander, but an angle grinder and free hand has too much risk of a screwup.
Got any ideas for me?
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 01-07-2012, 05:52 AM   #2
KeithinSC
KeithinSC's Avatar
Oddometer: 1,553
What about profiling the form prior to pouring? You mentioned a router, if it is still functioning maybe you can shape some wood to the edge you need and tack them onto the form. Wax or oil the forms for an easy release.
Good luck, post up some pics of the successes (or failures?!)
KeithinSC is offline   Reply With Quote
Old 01-07-2012, 06:00 AM   #3
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,747
On my sample pour I did put an angle piece that will provide a 45 degree edge whe removed, so we will see ow that works.
I'll take lots of pics
Old 01-07-2012, 06:39 AM   #4
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Why a bare concrete? You could tile it and use bull nose edge tile to round the corners as part of the finish. It will both last longer and look better/finished.
JamesG is offline   Reply With Quote
Old 01-07-2012, 06:48 AM   #5
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,747
Then why bother with concrete at all?
I could tile anything.
The concrete counter will be oh so cool!
Old 01-07-2012, 07:05 AM   #6
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,747
Originally Posted by tirebiter;,
[COLOR=palegreen
The problem with using them on concrete tops is the more material you take off, the more aggregate gets exposed.[/COLOR]
If you can get your hands on silicon carbide sand paper, that works too.
Here's an example of hand pads. Keep'm wet, they'll wear out real quick if used dry.
http://www.contractorsdirect.com/Con...mond-Hand-Pads
Good tip thanks!
I just checked out the site you linked to, that looks like the ticket for my edges, using the hand pads will be perfect! And 4" grinder pads are the cheapest I've seen! $9.99 each!
Old 01-07-2012, 07:22 AM   #7
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,024
Subscribed. I'm very curious to see how this turns out. I remember seeing a This Old House episode where they hired someone to make concrete countertops, as I remember it seemed more complicated than you'd think. Take lots of pics!
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 01-07-2012, 08:21 AM   #8
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,289
What about making a trowel with the desired radius?
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 01-07-2012, 08:26 AM   #9
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
I guess if you like the taste of concrete...
Old 01-07-2012, 08:56 AM   #10
GH41
Oddometer: 822
Concrete bricks or pavers will work well for breaking the edges and they are cheap. I assume you are not using an agregate? Are you using fiber or wire mesh?? At 2" thick it WILL crack without reinforcement. What are you sealing it with? GH
GH41 is offline   Reply With Quote
Old 01-07-2012, 09:17 AM   #11
ragtoplvr
Oddometer: 6,430
You can go to a cooking equipment store and buy huge polypropylene cutting boards pretty cheap. Profile edge with router. cut off strip. Repeat. Tack into mold. Pour. Vibrate. cure and touch up with sandpaper. This keeps the aggregate away from the edge
Rod
ragtoplvr is offline   Reply With Quote
Old 01-07-2012, 09:39 AM   #12
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,954
Why not just go with granite ?
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 01-07-2012, 09:55 AM   #13
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,747
Why not just go with laminate.
I will be sealing it with Procrete products
Procrete radiance will be the finish surface
Will be reinforced with 1/2 inch rebar 12 inches spaced, ad an under surface of half inch plywood
Old 01-07-2012, 09:57 AM   #14
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,747
Rod
Nice tip, thanks
Old 01-07-2012, 09:58 AM   #15
P B G
Oddometer: 10,001
Do a search, they look good.
http://www.google.com/search?q=concr...=1920&bih=1073
I've seen many DIY concrete counter tops, reinforce your slab, make sure its all level, and for the corners, you can grind them or you can precontour. You can also use caulk in the corners to make them smoother so long as it sets up fully.
Times are GMT -7.   It's 04:11 PM.
