Old 01-30-2012, 08:01 PM   #61
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,725
Here's the pics! Started with the base
Mold made out of 3/4 inch melamine and 3 layers of 1/4 inch masonite for the curves
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 01-30-2012, 08:12 PM   #62
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,725
Two layers of 3/4 inch plywood cut to shape lined with 3 layers of 1/4 masonite
Sides of form are 3/4 inch masonite over the 3/8 plywood base, the base will stay permanently, the masonite underneath will be removed so no wood will show.
Rebar and wire mesh for extra strength on the 12" overhang
Time to add some concrete! Mash it into all corners and crevices with your hands
Looks pretty dry!
Add some nicely colored aggregate into the surface and hope they show up when polishing!
Doesn't look so dry anymore does it!
Cover and let it cure slowly!
Old 01-30-2012, 08:25 PM   #63
explr
Just Stooopid
explr's Avatar
Oddometer: 168
Nice!
Well done sir!
explr is offline   Reply With Quote
Old 01-31-2012, 06:19 AM   #64
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,725
Originally Posted by explr View Post
Well done sir!
Thanks Doug, look forward to riding with you again!
Old 01-31-2012, 06:59 AM   #65
mikeegee
Oddometer: 299
I have plans for concrete counter tops in my own house, and have seen reference made to the Quickrete countertop mix.
Was sent an article on www.familyhandyman.com that descrive using Quickrete Precision Grout or Sakcrete Construction Grout instead.
Anyone else heard of or tried this?
meh
mikeegee is offline   Reply With Quote
Old 01-31-2012, 08:18 AM   #66
bimmerd00d
Sr GIF @dministrator
Oddometer: 13
this is awesome, and completely relevant to my interests :) IN for finished product.
bimmerd00d is offline   Reply With Quote
Old 01-31-2012, 09:27 AM   #67
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,010
That's a lot of reinforcing.
How did you vibrate it to get rid of air pockets?
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 01-31-2012, 01:17 PM   #68
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,725
Heydave I felt better to over do the reinforcing than be sorry. Mike, I used quickcrete 5000
Old 01-31-2012, 01:26 PM   #69
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,725
Dave, local rental store. 85 bucks for a six bag mixer and concrete vibrator for 24 hours
Old 01-31-2012, 01:40 PM   #70
Dave in Wi
Dave in Wi's Avatar
Oddometer: 2,010
Can't wait to see the finished product. You may have planted a seed, my kitchen could use new countertops.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
Old 01-31-2012, 03:48 PM   #71
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
I use a sawzall with the blade removed around the exterior of the forms.
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 01-31-2012, 04:16 PM   #72
bobfab
bobfab's Avatar
Oddometer: 1,409
in for finished pics!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 01-31-2012, 05:47 PM   #73
the_gr8t_waldo
Oddometer: 2,107
from the pics, it looked as if the rebar/grid is close to the top surface(if not actually laying on it) what measures did you use to keep it off?--i couldn't see any provisions, althought i do miss stuff and hope i'm wrong! other wise it looks like you (and work mates) did a beautiful job
the_gr8t_waldo is offline   Reply With Quote
Old 02-01-2012, 07:51 AM   #74
Skinner OP
Mr.KTM
Skinner's Avatar
Oddometer: 5,725
It's two inches thick, all of the rebar and wire are at least one inch from the surface, hold down with screws into the underlayment.
Old 02-01-2012, 08:55 AM   #75
the_gr8t_waldo
Oddometer: 2,107
thank you..i had assumed(wrongly) that you were casting upside down.
Times are GMT -7.   It's 05:15 AM.
