Old 07-31-2013, 07:44 PM   #1
grizzzly OP
The Pre-Banned Version
grizzzly's Avatar
Oddometer: 3,312
Need help with a large cat diesel
I have a truck with a CAT 3116,
we got it on a steep rough road and it died. I am thinking that it ran out of fuel. Is there a way to “prime the fuel system”?
We pulled it to level ground and put some fuel in it, cranked it the first few attempts it would start but it wouldn’t catch just kinda loop but never get over 1000rpm (I am just guessing at that number)and then die. Now it just cranks, I hit it with a quick squirt of starting fluid and it would hit than die immediately. any ideas
All my experience wrenching is on gas engines
thanks chris
you actually expect people to take responsibility for their actions in today's society?!
grizzzly is online now   Reply With Quote
Old 07-31-2013, 07:58 PM   #2
usgser
Oddometer: 2,134
I would at very minimum fill the fuel filters completely with fuel. If you got her air bound you'll prolly will have break all the fuel lines and fill them with fuel.
usgser is offline   Reply With Quote
Old 07-31-2013, 08:04 PM   #3
c-more
Oddometer: 112
is there a bleed nipple at the end of the fuel rail to open and get diesel through? which would then mean that the injector’s would/should have fuel to them.
c-more is offline   Reply With Quote
Old 07-31-2013, 08:07 PM   #4
oldxr
oldxr's Avatar
Oddometer: 1,124
Sometimes the fuel filters have manual prime pumps on them.If your fuel shifted to the back of the tank you might want to put 10 gallons or so in it before working on it more.If you loosen a fitting at the injection pump and work the prime button on the filter( if it has 1) until you see fuel flowing then tighten the fitting and try to start with some starting fliud.When a diesel fuel system gets air in it it sucks.
oldxr is online now   Reply With Quote
Old 07-31-2013, 08:43 PM   #5
grizzzly OP
grizzzly's Avatar
Oddometer: 3,312
The injectors are under the valve cover
The fuel pumps are electric and I didn’t see a manual pump (like on the older trucks I have worked on) I couldn’t hear the pumps running.
I didn’t have any good tools with me when I was at the truck so I couldn’t break a line to see if I had fuel or could get the pressure to drop and cycle the pumps.
Old 08-01-2013, 02:47 AM   #6
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
Need a little more info, year and make/model?
I don't have much experience with newer ones, I suspect if it has electric pumps it will be self purging if low fuel were the issue. It could be junk (mainly water) in the tank that got stirred up but you should be able to crack a line before the injector pump and verify fuel flow and if there is water in it. Other than that need more info.
GreaseMonkey is offline   Reply With Quote
Old 08-01-2013, 06:38 AM   #7
grizzzly OP
grizzzly's Avatar
Oddometer: 3,312
I am going to take some wrenches with me today and see where I have fuel
someone mentioned that the fuel pick up on these are prone to breakage
95 GMC with a CAT 3116 and an auto transmission
it is the stiffest sprung truck I have ever seen with hydraulic breaks
Old 08-01-2013, 07:30 AM   #8
alfanut
Oddometer: 4
Bring a tank of air, stuff a couple rags in the fuel filler, and crack a line in the engine compartment. Blow air gently into the tank until you get flow from the cracked line. This should bleed a good portion of trapped air. Good luck.
alfanut is offline   Reply With Quote
Old 08-01-2013, 07:51 AM   #9
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,791
Starting fluid in a diesel? Is that a good idea given the compression ratio? I'm thinking that may cause more harm than good.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 08-01-2013, 11:01 AM   #10
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,475
Two (very opinionated) schools of thought on this:
One says you'll blow the intake manifold into small pieces.
The other says "hold my beer and watch this!"
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 08-01-2013, 11:10 AM   #11
victor441
victor441's Avatar
Oddometer: 897
It does work on diesels AND can severely damage them too, some coworkers did that by using too much on a diesel generator...
victor441 is offline   Reply With Quote
Old 08-01-2013, 11:15 AM   #12
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,552
It has a manual priming pump on it, you unscrew it, then pump it a thousand times.
Fire the guy that ran it out of fuel.
larryboy is online now   Reply With Quote
Old 08-01-2013, 11:37 AM   #13
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,288
Ether is not a good replacement for poor maintenance, but used cautiously can be an excellent diagnostic tool.
Since I wasn't there, it is not for me to judge what someones motives are.
Old 08-01-2013, 11:40 AM   #14
grizzzly OP
grizzzly's Avatar
Oddometer: 3,312
Took some of the fuel lines off (all lines had fuel in them) pulled the fuel pick up out of the tank (The fuel pickup was coated with a black slime )put everything back. Than pumped air into the tank until I had fuel to the injector pump. Cranked the engine for about 30 seconds and it hit a few times than finally started. It ran like crap for about 10 minutes now it is running fine
I don’t understand why it wouldn’t start last night after we fueled it
The fuel pickup was coated with a black slime so I am wondering if it didn’t have a clogged fuel line i was able to get fuel through the filter by pressurizing the tank
Old 08-01-2013, 11:47 AM   #15
grizzzly OP
grizzzly's Avatar
Oddometer: 3,312
That is very true but sometimes it will give you that little kick needed to get over that edge and run.
I have seem a few very spectacular explosions from someone using too much
Times are GMT -7.   It's 09:44 AM.
