10-03-2012, 07:19 AM
#1 |
Rank outsider
Oddometer: 30
Battery Charging etc.
In all the threads about batteries, I never found a topic specifically about this.
The manual says that if you don't use KTM's high-dolla charger, you have to dismount the battery to charge it. My 08 came with a pig-tail attached, so I'm guessing the PO did not adhere to the manual. Is it ok to just use my trickle-charger on a pigtail wired directly to the + and - terminals of the battery for charging and maintenance? Side note, I'm guessing this battery has about had it. I bought a lithium type battery for my 300 and the thing has been nails. What's the school of thought on these for the big bikes? Any specs and brands other owners have purchased would be appreciated! GW.
08 KTM 300 XCW-E 08 CRF 150f You have been weighed, you have been measured, and you have been found wanting. Come back when you're worthy. |
10-03-2012, 07:27 AM
#2 |
KOTW 2010 Finisher
Oddometer: 3,001
You can do that. Many have successfully done so for a long time. Let me just suggest moving the bike outside the garage.
Learn from my mistake, don't make it yourself. http://advrider.com/forums/showthrea...ghlight=burned
Brents347 Truckee, CA. 07 Yamaha R6 07 KTM 950 Super Enduro 04 KTM 250exc- plated two-stroke |
10-03-2012, 07:39 AM
#3 | |
Oddometer: 5,032
10-03-2012, 08:22 AM
#4 |
Oddometer: 2,144
The battery does not need to be on the charger continuously. I usually charge-up mine for an hour or two at a time while I am in the garage and if voltage drops below 12.75 or so. Once or twice a week for an hour or two is enough to keep the battery at top condition. I do that whether I use the bike daily or not since our charging systems are less than perfect.
On the other hand, if the bike is not going to move for several weeks, then removing the battery from the bike is a no brainer and not a hassle either. |
10-03-2012, 09:30 AM
#5 |
Oddometer: 443
I bought a powerlett plug in with pig tail that goes to my dash power port. No fires yet
10-03-2012, 10:10 AM
#6 | |
Contrarian
Oddometer: 1,417
If it's easy and convenient to do the more often it will get done.
Born 10,000 years too late Scientific Wild Ass Guesser:hmmmm |
10-03-2012, 10:51 AM
#7 | |
Rank outsider
Oddometer: 30
Greg
10-03-2012, 11:52 AM
#8 | |
Rank outsider
Oddometer: 30
Is there a place to get an adapter that fits that weird/small power point and also a Tender?
10-03-2012, 02:35 PM
#9 |
Oddometer: 1,320
10-03-2012, 04:18 PM
#10 |
KOTW 2010 Finisher
Oddometer: 3,001
Cause has never been determined, or at least no one bothered to tell me. Which is fine, I'm busy with a house to rebuild!
