Old 01-11-2012, 09:01 AM   #1
Gustavo.Ramos OP
Gustavo.Ramos's Avatar
Oddometer: 894
Eh? 950 noisy engine
Deaer 950 fellas,
I have a 2005.5 950 Adventure fitted with Akrapovics and since i got her, about 1 year agora i've noticed the engine is very noisy. I can hear the valves ticking and it vibrates a bit. It has been serviced in KTM dealers and all say they haven't found anything unusual.
However recently went for a few rides with mates on 950's too, 2004 and 2005's and theirs are not as noisy as mine. All fitted with akras or wings. Can hear the exhaust, the engine too, but not that ticking and vibration...
Last service it had the vales checked, new shims, but no tensioners as the mechanic said it was not required.
Don't feel the bike underpowered, but the clatter and vibration, when compared to identical bikes is buzzing me.
any hints?
690R
Old 01-11-2012, 09:43 AM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,242
Cam chains, cam chain tenshioners, oil pump... work that if your paying a shop to do is gonna get real expensive real fast, I'm afraid.
How many miles? What oil are you using?
Chuckracer screwed with this post 01-11-2012 at 10:03 AM
Chuckracer is offline   Reply With Quote
Old 01-11-2012, 12:13 PM   #3
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,133
My 2004 gets real noisy from time to time. It has since new. My friend's does too. The older bikes would sometimes loose oil pressure in the hydraulic cam chain tensioners (I am told). Makes sense to me because it eventually goes quiet with higher revs, which suggests the pressure pumps back up again. It's fairly intermittant, but on a long trip can happen a couple timer per day. It can be particularly noisy when it is hot after stopping. Starting it up again can sound like it is coming apart.
It is so noisy that riding buddies have asked me why it's so rattley!
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-11-2012, 12:31 PM   #4
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,242
Yep, mine does the exact same thing. Nothing to sweat!
Old 01-11-2012, 12:35 PM   #5
Gustavo.Ramos OP
Oddometer: 894
36.000 kms and 10W40 Motul oil.
However it had exactly the same sound when i used Motorex 10W50 or 10W60. Has been like this since i bought it 8.000 kms ago.
I'm trying to find a way to post a video with decent sound.
Forgot to mention that i also have a 990 and there is no such sound or vibration.
690R
Old 01-11-2012, 01:43 PM   #6
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,269
Same here also. I noticed it starting get rattley around 12K and now with 28K, it's still the same.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 01-11-2012, 02:37 PM   #7
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,917
I guess water pump is replaced.
Worn wp can be the reason of rattles. When oil and coolant mix they create a sludge with lower pressure in the cam chain oil tensioners.
Other problems reported in here where faulty cam chain tensioners, worn cam chain and faulty oil pump.
Cheers.
gefr is online now   Reply With Quote
Old 01-11-2012, 02:53 PM   #8
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,146
My 04 with 65K miles is noisy... Always has been.
I tend to use a 20-50w oil and that helps a bit.
But in general, the V-twin motor is noisy...
It's not a flaw, it's a feature.
Q~
Old 01-11-2012, 03:55 PM   #9
charlie264
charlie264's Avatar
Oddometer: 8,265
My 950 sounds like a bag of nails, sounds best after a new oil change but that last about a 1000 miles. Check you aren't losing coolant as Gefr say...
Old 01-11-2012, 04:13 PM   #10
Buscapé
Buscapé's Avatar
Oddometer: 21
Tired oil pressure dump valve spring. Relatively easy fix.
Pics from Blackbert's bike :
Nil volentibus arduum
Buscapé is offline   Reply With Quote
Old 01-11-2012, 04:17 PM   #11
O.C.F.RIDER
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,881
The new ones, seems to be like 2006 and up, are FAR quieter then the 2004 that I have. Friend of mine had the exact same year and model, 2004 "S", his only had 6,000mi. as opposed to my 45,000, and sounded just as rotten. My dealer (Town & Country) started paying attention to how any 950/990 he got in for service sounded after my alerting him to my, seemingly about to blow, engine noise and he found himself that all the "old" ones like mine seem to sound like a tin box full of rocks, and the "newer" ones sound all happy.
Oh well, as long as mine KEEPS making noise I'm happy!
Chris
http://www.theshining.info/
KTM 950 Adv. "S"...'06 KTM 525 EXC...
'76 MV Agusta 750 America S...'84 Honda VF1000...
'75 Kawi 900 Z1...'90 Kawi ZX11...'03 Kawi ZRX 1200...'01 VOR 400E
O.C.F.RIDER is offline   Reply With Quote
Old 01-11-2012, 10:17 PM   #12
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,465
I wear ear plugs
Seth S
Seth S is offline   Reply With Quote
Old 01-12-2012, 08:33 AM   #13
Gustavo.Ramos OP
Oddometer: 894
i'm away from home for a few days so can't do a small film with the sound.
What councerns me is the sound and vibration.
Oil is ok, not milky, so i assume nothing is wrong regarding coolant leaks that could contaminate the oil and reduce CCT effectiveness.
the water pump seems to be ok too, it has been upgraded, and i haven't noticed any unusual hight engine temperature.
I know early bikes tend to be more noisy but a few friends of mine have 2005 950's and one of them has a 2003 with approximatly the same mileage and it sounds completely different. His sounds much better, vibrates alot less and has been ridden quite hard.
It is not the 1 second start up rattle. that goes away fast. It is a constant not so light ticking.
I'm doing the oil pressure dump vale spring job anyway. Fairly easy job to do.
Regarding the ear plugs, i just love the sound of thos akras. No can do!
690R
Old 01-12-2012, 09:02 AM   #14
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,242
While you're in there make sure the clutch basket and flywheel bolts are torqued and lock tightened properly.
Refer to the Hall Of Wisdom for the deets on those items.
Old 01-12-2012, 02:14 PM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,917
One more thing to check.
Vibration could be affected from carb balancing. Worth checking this as well.
Cheers.
Times are GMT -7.   It's 10:38 AM.
