Old 01-12-2012, 03:45 PM   #16
Gustavo.Ramos OP
Gustavo.Ramos's Avatar
Oddometer: 415
Originally Posted by gefr View Post
Vibration could be affected from carb balancing. Worth checking this as well.
Cheers.
Hi,
Checked that too. Not much improvement, although i notice these carbs get out of balance fairly easy. Am i the only one noticing it?
690R & 990Adv
Old 01-12-2012, 05:49 PM   #17
jeepman256
NACHO
Oddometer: 10
same problem
Just bought a 04 with 25k and it rattles like crazy , sounds nothing like the other two 2005.5 it sets beside...I,d been wondering if the sound was normal , sounds like that,s just an older model thing
2004' KTM 950 ADVENTURE SILVER
2009' KLR 650
2005' BMW DAKAR 650
2002' HARLEY LOWRIDER
2000' YAMAHA YZ 250
jeepman256 is offline   Reply With Quote
Old 01-12-2012, 09:47 PM   #18
GZERO
GZERO's Avatar
Oddometer: 238
the first thing before anything, check the oil pump regulator, most of the problems start here.
I would recomend taking it apart (taking the clutch basket out) and pulling the cover on the pump, that way you can clean everything and see if the piston has marks and to meassure the spring. If not, just buy the cover (it comes with the regulator built in and change it.
After that, the second thing to look is the tensioners.
The third is the balance shaft to see if is properly armed ( i have seen cases in which the shaft came loose and it touched the timming chains)
GZERO is offline   Reply With Quote
Old 01-13-2012, 03:48 AM   #19
Gustavo.Ramos OP
Oddometer: 415
I think it'll be the way to go.
Let's see if i'm not getting into more trouble. getting KTM parts around here is a a time consuming experience.
thank you all.
690R & 990Adv
Old 01-13-2012, 05:29 AM   #20
O.C.F.RIDER
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,511
KTM made a ton of mods to the engine on "later" models, a lot of which seemed to be aimed at quieting the things down so so many people weren't thinking their motor was about to grenade itself.
Chris
http://www.theshining.info/
KTM 950 Adv. "S"...'06 KTM 525 EXC...
'76 MV Agusta 750 America S...'84 Honda VF1000...
'90 Kawasaki ZX11...'76 Kawasaki 900 Z1...'01 VOR 400E
O.C.F.RIDER is offline   Reply With Quote
Old 01-13-2012, 09:15 AM   #21
keener
Speed changes you.
keener's Avatar
Oddometer: 521
cam chain tensioners?
Cam chain bouncing back and fort is a commonly noticed noise in LC8. That might be what you are hearing.
Im no expert at this ... here is what I learned so far... cam chain tensioners (#600.36.003.000) are basically pushing a rail that pushes the cam chains to keep them tight and not vibrate much. It is nothing but a spring loaded cylender that has an opening at the top to let engine oil to help the spring (hydraulically assisted). There a tensioner per cylinder.
When you start up the engine it takes a few seconds, sometimes more to fill them up with oil. So you will hear the cam chain bouncing for while. This can be more sever if the bike has not been running for hours or if you turn the engine manually (moving the bike when its in gear and off, even just a bit), the next time you start up you will hear loader cam chain noise right after start. I'm told it is normal.
If the noise doesn't go away after idling for a while or reving the engine, or it comes and goes as the bike is running idle, you might want to change the tensioners.
You need to remove air box to get to them.
$48 each at ktm-parts. http://www.ktm-parts.com/mm5/merchan...de=60036003000
04 ADV 950
keener is offline   Reply With Quote
Old 01-13-2012, 11:02 AM   #22
GZERO
GZERO's Avatar
Oddometer: 238
All that is right, but since the oil pump could be loosing its pressure trought the regulator valve (hence no oil pressure to the cam chain tensioners) thats why he would check that second after the pump.
Old 01-15-2012, 10:18 AM   #23
Gustavo.Ramos OP
Oddometer: 415
Here it is a small vid.
The sound isn't great, but i think you can hear it:
http://www.youtube.com/watch?v=3CfNy...ature=youtu.be
What do you think?
690R & 990Adv
Old 01-15-2012, 08:50 PM   #24
O.C.F.RIDER
Oddometer: 4,511
If I didn't know better, I'd think I was listening to a video of my bike.
50,000mi. & still making noise!
Chris
Old 01-15-2012, 11:41 PM   #25
Sumi
Sumi's Avatar
Oddometer: 1,148
What do you think?
It's about the same as mine.. Sounds normal for me.
2005.5 950 Adventure
Old 01-16-2012, 03:16 PM   #26
Gustavo.Ramos OP
Oddometer: 415
Chris
If you and Sumi say it sounds normal than i guess she's deemed to sound like a can of nails...
I'm in bad need for a decent ride
thanks
690R & 990Adv
Old 01-16-2012, 07:07 PM   #27
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 41,631
What do you think?
Sounds just like mine; maybe even quieter. I think there may be a little more clatter from the clutch plates on the right side. Sounds good to me!
Hayduke is offline   Reply With Quote
Old 01-16-2012, 08:03 PM   #28
spafxer
spafxer's Avatar
Oddometer: 2,326
Sounds about the same as my '06 with 25,000 miles!
I did have a vibration develop in the right handle bar. I thought it was carpal tunnel in my wrist or something.....
I found the problem this weekend... Damn, if the fiber lock nut holding the handle bars hadn't fallen off on the right side and the left side was loose. Tightened back up and my hands felt great all day. Good thing I didn't kill myself.
spafxer is offline   Reply With Quote
Old 01-16-2012, 08:58 PM   #29
AdvGa
AdvGa's Avatar
Oddometer: 1,320
...i notice these carbs get out of balance fairly easy. Am i the only one noticing it?
If this is the case... try Balancing them at about 4 or 5k RPM.
Done this with mine and it has less vibration than my inline four.
AdvGa is offline   Reply With Quote
Old 02-22-2012, 12:23 PM   #30
jvg
jvg's Avatar
Oddometer: 35
Send a message via ICQ to jvg
I have seen this mentioned before (that the cover comes complete), but no part # for it.
In all part manuals i look at the cover, spring and piston have separate numbers.
Is this the correct part, i guess CPL = Complete?
60038010133 - PRESSURE PUMP HOUSING CPL. 10
/j
KTM 950 Adventure S
| NorthCape 2010 | Geiranger 2011 | South Norway 2011 | Blåhö/Trontoppen 2012 |
jvg is offline   Reply With Quote
Times are GMT -7.   It's 03:44 PM.
