Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 02-01-2012, 06:26 PM   #16
igormortis OP
igormortis's Avatar
Oddometer: 1,298
Brakes are being mulled over at the moment. I have a few solutions for a 320mm disc. I’m comparing options right now to see which is the most practical.
Steve, I may take you up on that offer of help, since you’ve cut your springs before...
I took the fork springs out today and did some approximate measurements.
Length is 505mm and the spring rate looks close to 4.2N/mm using the bathroom scale method (!).
I need to decrease travel from 300mm to the BMW’s 225mm, so 75mm needs to come off the spring.
A 430mm spring is 0.85 of the original length, so the original rate divided by 0.85 gives me the new rate...(?)
Am I right? This would give me a theoretical 4.9N/mm spring rate. Higher than the standard BMW rate (4.7 I believe) and higher again than a KTM 950 Adventure (I’ve read 4.8).
This seems like a good starting point for little to no cost, and would help me determine if I’m in the right range.
igormortis is offline   Reply With Quote
Old 02-01-2012, 06:51 PM   #17
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Yes, that is the short cut for determining spring rate. Close approximate. I also tried to get spring rate calculators to check. These came out with a slightl;y different result (higher). Standard BMW spring rate is 0.48kgs/mm.
Your thinking is the same as I applied, & I am happy with the resultant spring rate. Your nm would equate to approx 0.43/kg/mm (start) & 0.51kg/mm (finish), with the resulting spring rate slightly firmer than what you have now. Good given the expected use.
When you cut the springs, mark where you want the sping to end & come back one spring turn. That will leave enough spring so that you can bend the surplus down, to create the new flats (effectively one turn of the spring).
Heat the ends of the spring to remove the temper (propane / butane torch will do it) & that turn down, either with a pair of pliers, or by compressing against some wood. Then grind the new flats on once you are happy with the bends.
I'm on leave at present, so am happy to pop around if you want a hand.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 02-01-2012 at 07:03 PM
Box'a'bits is offline   Reply With Quote
Old 02-13-2012, 01:00 AM   #18
igormortis OP
igormortis's Avatar
Oddometer: 1,298
Iíve cut my fork springs and disassembled the fork internals. As soon as I get some spacers made up Iíll see if I can successfully re-assemble them!
In the meantime, I pulled out my perfectly good R100R muffler...
IMG_8107
...and cut it up:
IMG_0017
IMG_0019
IMG_0027
Old 02-15-2012, 10:46 PM   #19
Padmei
enamoured
Oddometer: 3,604
Coooooome on you slack bastard.
Padmei is offline   Reply With Quote
Old 02-16-2012, 02:21 AM   #20
igormortis OP
igormortis's Avatar
Oddometer: 1,298
Yeah, I know. I could show you pics of scraping paint off the house, but that wouldnít be too exciting...
Old 02-16-2012, 11:32 PM   #21
igormortis OP
igormortis's Avatar
Oddometer: 1,298
See... Progress, but not the kind you hope for in this thread.
P1010929
Old 02-16-2012, 11:44 PM   #22
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
That looks good. Want to come around & burn some paint at my place?
Old 02-20-2012, 01:39 AM   #23
advNZer?
advNZer?'s Avatar
Oddometer: 2,828
P1010929
jeepers i need to do that too how come you have lost the eaves soffit cladding?
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-20-2012, 01:45 PM   #24
igormortis OP
igormortis's Avatar
Oddometer: 1,298
Had to pull them off - rotten!
Old 02-20-2012, 04:22 PM   #25
Padmei
enamoured
Oddometer: 3,604
Nows the time to put up those outside lites - The roof space is a bugger on those old houoses & there is usually a top plate erstricting access to the soffit.
Old 03-04-2012, 10:40 PM   #26
igormortis OP
igormortis's Avatar
Oddometer: 1,298
Not much to report due to house jobs. I did get some tools for the steering head bearings though, and they work great. If anyone local wants me to loan them out, let me know. They turn a potential clusterf*ck into a 5 minute job.
Old 03-12-2012, 01:58 AM   #27
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Did you also get the 48mm seal fork seal driver?
Old 03-12-2012, 02:30 AM   #28
igormortis OP
igormortis's Avatar
Oddometer: 1,298
No, I didnít. Was gonna follow your lead on that one.
Old 03-12-2012, 02:36 AM   #29
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Hmmm. Because I need to replace the fork bushes AGAIN, I may splurge. Watch this space. Need to get Gus up & running before RRRR
Old 03-12-2012, 04:00 AM   #30
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,776
wtf?
did the missalignment of the forks with the duff axle eat the bushes?
For what its worth Proride just did a full service on my wr forks for $220 incl seals, oil etc which I thought was pretty reasonable.
These are the best days
Mark_S is offline   Reply With Quote
Times are GMT -7.   It's 09:57 PM.
