01-19-2012, 07:16 PM
#16 | |
Oddometer: 3,982
Jerry Counts |
01-20-2012, 07:31 PM
#17 | |
Oddometer: 103
But given the choice I wouldn't want a GPS that's limited to 500 points per track. Heck if there was a version of the garmin 62 that let you do more points per track I'd buy it if it wasn't too much more. I don't see why GPS manufacturers impose these track point limits. Probably hardware limited to hit price points. I'd prefer to only have to turn one track on and off instead of 20. I got the GPS as an aid to help me, not to be a hassle. |
01-20-2012, 08:56 PM
#18 |
Having a Nice Time
Oddometer: 13,918
Still limited to 10,000 total track points.
60 series: 20 X 500 max per segment (total 10,000), 1,000 waypoints, 50 routes 62 series: up to 200 segments, not sure if can exceed 500 per segment now without truncating - haven't tried it (still up to 10,000 total), 2,000 waypoints, 200 routes Disappointing that there is still a 10,000 trackpoint ceiling, especially with the ability to have 200 (versus 20) segments.
Cannonshot.net |
01-20-2012, 09:46 PM
#19 |
Oddometer: 3,982
I believe the 62 holds 200 tracks of 2,000 points each. Which there is no "Saving" required, just give an old Adtive Log a name and download it.
Jerry Counts |
01-20-2012, 10:10 PM
#20 | |
Having a Nice Time
Oddometer: 13,918
Uploading a usable file is where the limitations of segments and points manifest themselves. If I try to load more than 10,000 track points total or more than 200 track segments total I will have exceeded the upload capacity of the unit and the the file will get truncated leaving out the excessive points or segments or both. Better give Garmin a call and have them change the specs they publish for their products. 200 X 2,000 = 400,000 (40 times what they say their 10,000 track point ceiling is). Of course I could be wrong about all of this as I am relying on their published product information and not direct personal experience with the unit. ![]() (I really would like to know if they still truncate at 500 points per segment though.) ![]() Maps & Memory: Basemap: yes Preloaded maps: yes (topographic) Ability to add maps: yes Built-in memory: 500 MB Accepts data cards: microSD™ card (not included) Waypoints/favorites/locations: 2000 Routes: 200 Track log: 10,000 points, 200 saved tracks Edit: The DeLorme PN-60 has this track spec - Holds up to 10 tracks (20,000 points per track), 1,500 user-defined waypoints, and 100 routes. This is one of the reasons is was disappointing when Garmin came out with a new and expensive unit (without a good power plug arrangement) that could handle 200 separate tracks but that did not expand the 10,000 track point ceiling. The Delorme suffers from a 10 track upload constraint but has plenty of track points. The Garmin has plenty of track segment upload capacity, but lacks the track point ceiling to make it worth while.
Cannonshot.net Cannonshot screwed with this post 01-20-2012 at 10:43 PM |
01-20-2012, 10:51 PM
#21 | |
Oddometer: 3,982
Jerry Counts Countdown screwed with this post 01-20-2012 at 10:59 PM |
01-20-2012, 11:06 PM
#22 | |
Having a Nice Time
Oddometer: 13,918
I am not guessing. I am reading Garmin's specs. Why publish specs if they don't mean anything? Nowhere in the specs or the user manual does it say anything about 200 X 2,000. They do consistently note the 10,000 point limit though. ![]() But, I would appreciate it if you would conduct a test with your unit to see if when you upload a file from MapSource that has a track segment that exceeds 500 points, if the unit (still) truncates it at 500 points. This was not covered in the specs which is why I noted that I was curious to find out. Thanks Jerry, and if Garmin is wrongly reporting the 10,000 track point limit in their specifications for the unit, please let them know so they change their product literature. This limitation, and the lousy power plug set up, are the reasons I haven't upgraded to a 62.
Cannonshot.net |
01-20-2012, 11:40 PM
#23 |
Having a Nice Time
Oddometer: 13,918
Very nice comparison of units/capacities/features here:
http://gpstracklog.com/compare/garmi...mparison-chart
Cannonshot.net |
01-21-2012, 07:14 AM
#24 |
Oddometer: 68
On the 60CX your own active log track is limited to 10,000 trackpoints.
Uploading existing tracks from mapsource to the 60CX is limited to 500 trackpoints each and a max of 20 tracks. There is a workaround. If you are only interested in having one track loaded, you can rename the uploaded track to active log and that will allow you to use up to 10,000 trackpoints. I personally do not find this method very useful when I go on multiple day rides. |
01-21-2012, 07:43 AM
#25 |
Oddometer: 1,203
I often accidently try to upload tracks with more than 500 points and my 60 cx always gives me an error message saying that they are truncated. I checked once and indeed they are.
For navigation purposes filtering down to 500 points has rarely caused problems. Sometimes I will have to hunt around a few minutes for a turn, but that is the worst that happens. On my 60 the default for tracks is "on", so you don't have to worry about turning them on, but I guess you can turn them off if you want to. |
01-21-2012, 08:29 AM
#26 | |
Having a Nice Time
Oddometer: 13,918
Cannonshot.net |
01-21-2012, 08:34 AM
#27 | |
Scott Whitney
Oddometer: 2,225
I've moved on from those limitations without buying an expensive GPS. Now I convert my HUNDREDS of tracks into a map, then load the map. I can pick the color and width of each track, each track can have as many points as I want, I can create a separate map for each day with just the tracks for that day, I can turn each map on or off easily, and it leaves my track log 100% available for recordring. All this on my 76cx! http://www.gpx2img.com/ |
01-21-2012, 08:56 AM
#28 | |
Having a Nice Time
Oddometer: 13,918
A lot of us that share/publish tracks for others to download from the web and then upload and use are interested in knowing the limitations of each of the units so that we can produce a GPX file that even very basic users can easily upload and that will "fit" into their units without a lot of extra effort. For quite a while, the standard has been no more than 20 segments of no more than 500 points each. Many of us have made some adjustments for individuals who use Zumo or PN units so that the file fits the limitations of those units. I am curious as to what the track segment limit of track points is on the 62. If it is greater than the 500 we have dealt with in the past, it would be good to know for sure what the new limit is. With up to 200 segments and 10,000 points total, there is some nice flexibility in producing files that would work well with the 62. Of course, with so many 60 series in use, I guess we will be structuring most files we share within the 20 X 500 structure anyway.
Cannonshot.net |
01-21-2012, 11:00 AM
#29 | |
Oddometer: 3,982
To all the other smart guys answereing some question that was not asked (how to get more performance out of a 60) Cannonshot is trying to find out exactly what a 62 does. However llike you pointed out, the 62 is DOA. Look at a 78 just like the 76 is far better than 60. The 62/78 just don't have enough added features over 60/76 and has a couple drawbacks for me. I am watcing the Montana and waiting for them to finally finish the firmware without screwing it up and for the price to drop. I like it as it looks like the first unit that would work on both bike and car. I will ask RWAMF, I am sure he has done it.
Jerry Counts |
01-21-2012, 01:23 PM
#30 | |
Oddometer: 103
The 62 series can hold 200 tracks with 10,000 track points each. For a total of 2 million possible track points! At least that's what the brochure says. As a test I successfully loaded a track to my 62S with 14,000 track points. |
