Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 01-17-2012, 05:59 AM   #1
Mac OP
Mac's Avatar
Oddometer: 2,150
How to install MapSource without a disk, or previous installation
Step 1: Download latest version of MapSource from Garmin.
Step 2: Rename file extension to a .rar instead of .exe
Step 3: Use WinRar to extract to a folder (instead of running exe).
Step 4: Run MSmain.msi file, not Setup.exe.
Step 5: Be happy.
Note that "setup.exe" runs the check to see if you already have MapSource installed, then it executes the MSmain.msi file to install the application. By executing MSmain.msi file directly, you skip that step and just get a clean installation.
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 01-29-2012, 02:58 AM   #2
BajaRat
BajaRat's Avatar
Oddometer: 589
This worked great on my netbook when I was on a trip and needed to load MS to view tracks that were sent to me.
Thanks for the tip !
BajaRat is offline   Reply With Quote
Old 02-04-2012, 04:50 PM   #3
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Hey Mac, this info rocks m8 :)
I have been getting nagged lately, since adding some after market maps, so I un-installled and re-installed the way you describe and it works great, thanks.
Now, for some info that may help others, I had been using Mapsource, I think it was 6124, and this was fine and worked with my MAP76S. But, I have a new Montana650T arriving soon, so I thought I would install Basecamp and get used to the interface.
Well, it installed but deactivated my mapsource and to tell the truth, I am not that impressed by basecamp yet. I was a bit underwhelmed, but then after un-installing all Garmin products and using the above procedure, I then downloaded and installed Mapsource 6163 which as mentioned works fine.
I then got curious and decided to follow the same procedure using Basecamp and I can now say it was successful and I can have both programs open and running at the same time
**note, one of the glaring omissions from Basecamp is the ability to click on a drop down button to select Map Scale which is very annoying as you have to select the magnifying glass and right or left click to step through the scales**
Cheers
TravellingStrom
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 02-04-2012, 07:37 PM   #4
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,751
Cheers
TravellingStrom
You do know you can zoom with the plus and minus keys in Mapsource - maybe Basecamp too?
(Can't find the damn Basecamp manual online anywhere, but what I did find suggested the + and - works for it too)
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp screwed with this post 02-04-2012 at 07:47 PM
tbirdsp is offline   Reply With Quote
Old 02-04-2012, 11:15 PM   #5
TravellingStrom
Oddometer: 397
Thanks m8, that did work and I also found out that havering the mouse over the big BLUE triangle, turns it into a map scale and rotation tool ;)
Old 04-22-2012, 07:42 PM   #6
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
BaseCamp online information
See here: http://garmin-mapsource.wikispaces.com/BaseCamp for some BaseCamp usage information. It also says:
Where is the Manual?
Currently, the manual references on Garmin's website point to the MS manual, which will not help you with BC. There is a help file in BC, but as with most help files, it is more a reference on how to operate the program, not how to use the program. As significant progress is expected from Garmin with BC development for the On the Road applications, a manual may be a moving target today.
If someone knows something better on line, please post a link!
Note, there is also an online project management system called Basecamp (see http://basecamp.com/) so don't get confused.
-ceej
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is offline   Reply With Quote
Old 04-13-2014, 09:23 PM   #7
dougprintz
dougprintz
Oddometer: 18
Thanks Mac. I'm recovering from a crashed disk with no way to install Mapsource. I'm not going to Basecamp until I absolutely have to - you've just allowed me to stall for a little while longer.
Doug
dougprintz is offline   Reply With Quote
Old 05-16-2014, 06:37 AM   #8
Joey Jo Jo Jr. Shabadu
1 Less Car
Joey Jo Jo Jr. Shabadu's Avatar
Oddometer: 247
I too am recovering from a crashed laptop. It would appear as soon as the support for XP expired, so too did my Toshiba's will to live. Now I'm having to learn a new OS and figure out where and how to replace all my lost programs I had collected for the past 7 years. Well, this may not be the best thread for such stupid questions, but I guess I gotta ask them somewhere, so here goes:
1. Would anyone be able to walk me through the procedure to re-name a file in Windows 7? I can't find a way to view the file and its file extension.
2. Where can I learn how, or read about how, to use Win RAR? It looks like it may be pretty simple, but to me it's not intuitive and therefore I'm stuck.
Thanks.
2009 Suzuki DR-Z400S
2007 Aprilia SR50R Factory
2005 Yamaha FZ-6
Joey Jo Jo Jr. Shabadu is offline   Reply With Quote
Times are GMT -7.   It's 10:28 PM.
