01-19-2012, 03:40 PM
#46 |
Gimpy, Yet Alacritous
Oddometer: 1,722
Can't believe no one has mentioned the craptastic stock V-Strom windshield. From the original '02 DL1000 through the latest 2012 DL650, they suck, suck, suck. EVERYONE has to change the windshield to make their V-Strom safe and tolerable to ride.
Seriously, it's bad. Short or tall, your head will feel like a punching bag after a mile or two at speed. While we're at it, let's just take a moment to ponder why, after 40+ years of selling bikes in the US and Europe, NONE of the Japanese manufacturers has figured out how to build a bike with stock suspension that works if you're not an anorexic Japanese teenager.
1983 Suzuki GS850G, Cosmic Blue 2002 Suzuki Vstrom DL1000, Midnight Blue 2005 Kawasaki KLR650 - Turd II, The ReTurdening "Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease." |
01-19-2012, 03:49 PM
#47 |
Joe Lunchbox
Oddometer: 141
The way my VFR feels like the best bike ever made, except that I can't go on a trip without a rectifier in my pack and how even after a factory recall and an aftermarket charging harness I only got 30K miles out of a stator and the complexity of the v-tec valve adjustment...but all that's only ten irritating percent of the time and then it takes another ten percent of the time to forget about the problem, then I'm back to thinking it's just the greatest bike for a long time...then the stator goes...
01-19-2012, 04:54 PM
#48 | |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,097
Here's another: I had a 100cc bike with a hydraulic disk front brake in 1980. Why does Honda still provide the Nighthawk 250 with a small front drum for the US market?
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
01-19-2012, 05:59 PM
#49 | |
Oddometer: 669
Tell your Uncle not to bother with the exhaust, mounts and bags. All you need to do is remove the shocks, the swingarm will the be able to droop far enough to get the axel out (it will be REAL close to the pipe). I do it all the time on my Interstate. |
01-19-2012, 06:09 PM
#50 |
Grip and rip since 1983
Oddometer: 600
Interesting thread...I have a K1300GT that sees most of my touring duty in the good weather and this bike has/does everything you could ask for in a modern bike.
The throttle/injection flat spot is enough to piss me off. It usually occurs in first second first up and down shifts. It requires more concentration and clutch feathering than necessary and is distracting.
I coulda been an actor, but I wound up here. |
01-19-2012, 06:13 PM
#51 |
Oddometer: 600
My Husky has a spring loaded kickstand (on the left, of course) and the oil level check plug is on the right side so pull the check plug, as soon as you straighten the bike to check the oil level, the kick stand retracts so you have to hold the bike up and walk around it to put the stand back down. The seat is too high to reach over and put the stand down by hand.
01-19-2012, 06:34 PM
#52 |
bikaholic
Oddometer: 1,536
The fuel gauge on my 1050 Tiger will read empty if you turn the bike off when its below a quarter tank and turn it back on.What good is a fuel gauge like this? The headlight is also worthless on twisties at night as the pattern has no peripheral light.
01-19-2012, 09:37 PM
#53 | |
Oddometer: 80
01-19-2012, 09:46 PM
#54 |
Oddometer: 415
Vented gas cap on the DL650. The tank is black and it's often very hot here. Delicious gas fumes. Seriously?! Even KLRs have a vent hose!
Also the stock horn on every single bike I've ever ridden is full of fail.
Formerly gainfully employed, now a starving student. Go Bruins! |
01-19-2012, 10:38 PM
#55 |
neo-quixote
Oddometer: 1,048
make it yours
My '95 R1100R was so bad I hated riding it. The seat pushed me into the tank. It has rubber bumpers at the rear and I cut them down to make the seat level. Problem solved. The ABS lights flashed all the time. I wired in a relay to stop this, now the ABS works.The bars were too high and close. Changed them to Renthal lows and it has a good riding position.The catalytic converter burned my feet, so I got aftermarket exhaust parts. The OE tires were too small, I replaced them with Metzelers that calibrated my speedo. The exhaust change dropped 18 lbs. Now, the handling's neutral, but I still have no power. I'm waiting for some ADV shit to fix the fuel injection. Ohlins shocks made it ride correctly for my weight. No wonder the wheels bend, the front shock had no damping, but the fine geometry made it difficult to discern. The rear shock was oversprung, and hammered on all bumps. It's much more controlled now. So, don't give up on bikes with flaws you hate, think about it, get advice. make it yours.
willis 2000 screwed with this post 01-19-2012 at 10:55 PM Reason: repetitive |
01-19-2012, 10:48 PM
#56 | |
Oddometer: 1,978
Pete |
01-19-2012, 11:37 PM
#57 |
Oddometer: 364
The p**s-poor fuel gauges on the BMW R1200's. The strips inside to detect the fuel level just stop working eventually so your dash constantly says "FUEL!" flashing at you with a yellow warning light permanently on. Grrrrrrrrrrrrrr!
BMW R1200 GSA KTM 525EXC Six Days Racing kTM 690 Enduro R Rally |
01-19-2012, 11:50 PM
#58 |
Oddometer: 390
Harley mirrors that only let you see your elbows, and turn signal buttons that require five inch long thumbs to use.
01-20-2012, 12:40 AM
#59 |
Miserablist
Oddometer: 4,030
The seat on every moderately sporty bike designed after 1992.
Origami folded plastic tanks, that look cool to 12 year olds with a Transformer fetish but a real PITA to find a decent tank bag for. That Buells were made by Eric Buell & HD, not Kawasaki. Every teenage wannabe stuntah that owned a 90's Kwak I was interested in, and thought that an iPhone & mismatched Harbor Freight imperial allen wrenches were all you needed to be a garage moto mech. The idiotic wiring on early Victory's, so if you burned out a tail light bulb the whole bike would be dead. The price tag of a Motus R. |
01-20-2012, 04:40 AM
#60 |
Oddometer: 3
Whizzy Brakes
BMW's power-assisted, aka "whizzy" brakes. A wonderful example of an answer to a question that nobody asked. And not even a good answer!
