Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 01-20-2012, 06:08 AM   #61
Tall Man
Freelancer
Tall Man's Avatar
Oddometer: 986
Originally Posted by fastdadio View Post
Weestrom, Remove the fairing cowl to access the air filter?
It takes a bit more than just removing both cowlings.
I sometimes think that there are marriages that require less commitment than what is required to work on a V-Strom.
Tall Man is offline   Reply With Quote
Old 01-20-2012, 07:35 AM   #62
Sir Not Appearing
That's no ordinary rabbit
Sir Not Appearing's Avatar
Oddometer: 1,114
The battery placement on the Suzuki VS800 (for that matter, VS400, VS600, VS700, and VS750). Best place to put the battery? In front of the rear wheel where it is almost impossible to jump it if you get stranded and replacement is a real treat. My suggestion, buy a AGM battery so you can forget about it for 5-7 years.
Originally Posted by southwade View Post
a.k.a... bikes you like but would change this or that, etc...
i.e.
The previous Versys headlight
It may be ugly, but it does a decent job of lighting up the roadway at night compared to many other bikes.
1998 Triumph Daytona
1991 EX500
2007 Suzuki S50
Sir Not Appearing is offline   Reply With Quote
Old 01-20-2012, 08:50 AM   #63
southwade OP
ΜΟΛΩΝ ΛΑΒΕ
southwade's Avatar
Oddometer: 1,745
I bet, lol... I may be buying one soon. The bike, as a whole, is really growing on me.
Also, this thread is turning out pretty awesome, lots of good info you don't read in bike "reviews"
i haz z1000!
southwade is offline   Reply With Quote
Old 01-20-2012, 09:12 AM   #64
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 5,009
On my GTS, there are five (I think) separate fairing/cowling pieces that need to come off in order to access the airbox. Given the somewhat radical nature of the fairing and the infrequent need to inspect air filters, I don't look upon that as a terrible burden
As an early example of Yamaha's execution of fuel injection, I suppose I should also make allowances there. It does, however, have a very abrupt throttle, made all the worse by the slightly smaller-than-normal diameter of the grips. This leads to getting cramp in my hand, trying to finesse the throttle at low speeds or to maintain steady cruising speed.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 01-20-2012, 09:39 AM   #65
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,552
Do you know how to remove the whole nose assembly in 1 minute?
Uncle Pollo is offline   Reply With Quote
Old 01-20-2012, 10:33 AM   #66
Tall Man
Freelancer
Tall Man's Avatar
Oddometer: 986
Yes, I can remove the nose assembly, although I've never timed myself. I don't work in a hurried manner.
More to the point, the upper headlight shroud is the only front body component that doesn't need removed to gain access to the Strom's airbox.
Removing the fuel tank is my favorite part. Not.
Old 01-20-2012, 04:25 PM   #67
Crusty Dusty
Crusty Dusty's Avatar
Oddometer: 41
Not sure about the Wee, but on the Vee you can remove the tank and not have to take the whole front fairing apart. You have to remove the seat (of course), the small black plastic cover over the front tank bolt and the banana side covers. Everything else on the fairing is just loosened. It really helps to have a second set of hands.
Dusty
Crusty Dusty is offline   Reply With Quote
Old 01-20-2012, 05:00 PM   #68
PeterW
Oddometer: 2,794
Replacing the air filter isn't that bad once you know the tricks.
You remove that front connecting plastic (behind the triple clamp), remove the seat, and the two lower side plastics and remove the three rear bolts on the cowlings each side.
Slide a towel under the cowlings to protect the tank. Lift the rear of the tank, disconnect the fuel line and fuel pump wiring, remove the front tank bolt - get some help to splay the cowling plastics and pop the tank out backwards.
The cowlings stay in place and with the tank out it's easy.
Assembly, just (carefully) reverse the procedure.
Pete
PeterW is offline   Reply With Quote
Old 01-20-2012, 05:15 PM   #69
ttpete
Rectum Non Bustibus
Oddometer: 6,165
You'll like it! I've had mine 3 years. Try this forum. We've got all the info you'll need: www.kawasakiversys.com
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 01-20-2012, 05:15 PM   #70
ZumWohl
mongoose is gone
ZumWohl's Avatar
Oddometer: 263
I knew the Strom would take the majority of hits in a thread like this, but I've learned to love it regardless.
De-paneling isn't that big a deal...I made a template to hold the fairing screws as I take them out, so reassembly is much easier. And I'd rather have all the plastics and fuel tank off whenever I do maintenance, makes everything much easier to inspect/repair if needed.
But the easiest way to change the looks of it...buy Speedstar's headlight masks and a different windshield. The masks gets rid of the cat's-eye, and the Euro mini shield eliminates buffeting. I ride year 'round with this shield, I love it so much.
Here's the gussied-up beast on some crazy-ass road in TN, or NC maybe?
Never heard anyone complain about being shot with a .45ACP - McNeal ADV
ZumWohl screwed with this post 01-20-2012 at 05:24 PM
ZumWohl is offline   Reply With Quote
Old 01-21-2012, 09:28 AM   #71
der_saeufer
?איפה בירה
Oddometer: 694
Originally Posted by PeterW View Post
The DL650 does have a vent hose. Find yours and unblock it.
Pete
Not on the US 49-state and Canadian models. Check the diagram--there's a drain hose to drain rain water from the area around the fuel cap, but tank venting is accomplished by a vented cap.
The California model has a vapor recovery system; I should have specified my bike came from out of state.
der_saeufer is offline   Reply With Quote
Old 01-21-2012, 10:00 AM   #72
FKNBUM
Oddometer: 91
Despite being the most reliable vehicle I have ever owned, vaporlock at temps above 75 F keep me from riding the 1985 K100RT much anymore.
The stupidly tall 1st gear on the 1150GS, being able to cruse 30 in 1st might be nice in stop and go traffic, but it sucks when looking for a campsite.
Pretty much every BMW spedo/tach made. I currently own three, only the 2004 GS spedo is currently working. Currenly, I think.
I have now owned a BMW with a stock seat, I now know why every other bike I have purchased or ridden has an aftermarket saddle.
FKNBUM is offline   Reply With Quote
Old 01-21-2012, 01:59 PM   #73
Crusty Dusty
Oddometer: 41
Pete
Forgot about those....
I used to think Suzuki suspended the air filter from a string and built the bike around it. I would cuss it no end, then I saw my brother's Gold Wing. HOLY CRAP!!!! Recommended air filter change is 30,000 miles, some guys wait until 50,000, I can see why.
Old 01-21-2012, 02:47 PM   #74
Grreatdog
Grreatdog's Avatar
Oddometer: 12,585
Getting the tank off my LC4E used to aggravate me because I had to remove the two side covers first. But all of a sudden I feel much better about those extra bolts.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 01-21-2012, 03:18 PM   #75
oldtrout
oldtrout's Avatar
Oddometer: 189
Bmw
BMW turn signal switches....
Coming up two years on my GS and still stabing away at the spot where very other bike I owned had a simple little button.
Overcomplex.
Spratley. Dr. Spratley.
oldtrout is offline   Reply With Quote
Times are GMT -7.   It's 12:38 AM.
