01-22-2012, 01:58 PM
#91 |
Oddometer: 2,203
jeepers i got used to them in 1 ride...one side for right one side for left how complex is that?.I dont like the fact you have to keep putting money in the gas tank...
aka BMWST?
01-22-2012, 05:20 PM
#92 |
Career Neophyte
Oddometer: 62
Yeah, the DL1000? You forgot ugly, and...
The 3mm rear wheel shim offset thing, The throttle bodies blowing clean off the intake boots after the TPS device fails and the bike won't idle after a long highway run. Did I mention the grossly inaccurate fuel gauge due to the weak ground return that feeds the trouble-prone in-tank fuel pump assembly? And something about hub-rubbers occasionally self destructing in the rear wheel assembly? (ask me how I know) ![]() And that little rubber hose that feeds the two injectors has a nasty tendency to leak raw fuel on top of the engine once the bike is heated up and under load. (That minor leak on top of your Vee is not coolant, its gasoline. Trust me.) BTW: That pesky little hose is a $165.00 part. I won't get into saddles, wind screens, stock handlebars, front shocks, or even stock mirror removal to eliminate the heinous buffeting that every one assumes is the piss-poor windscreen. Ya know, If I didn't have a Harley, A GS500, and old Honda that consistently run like a fine clock, I might think all bikes run like a V-Strom. Not that I don't love my big Vee -Ej-
A "Commuter" not an AdvTourer. Currently Commuting On: 06 Harley XL1200C, 06 DL1000, 07 GS500F, 83 Honda XL200r beater, 2 mopeds, and a pair of sneakers. |
01-22-2012, 09:15 PM
#93 |
Oddometer: 119
__________________ aka BMWST? Sorry my flightless bird friend. I'm a geezer, so too many years on Jap(anese) motos. Three switches - Left-right- onoff ?? Mt thumb has to roll off the gas to cancel. Wiring ++++ Other than that, the finest bike I have owned. Plus 10 ! Hows your summer ? (lucky bastage ..) ![]() Cheers Cold-Trout
Provectus Oncorhynchus mykiss kamloops |
01-23-2012, 11:14 AM
#94 |
If you want to
Oddometer: 851
The instruments on F800GS. Hideous and bassackwards. Which is a shame because the rest of the bike looks quite good. BMW dumped the fugly Instruments from the R1200R hopefully they'll do the same for the f800.
01-23-2012, 11:29 AM
#95 |
If you want to
Oddometer: 851
WR250R/X
Shitty mirrors that mostly show your elbows. I expect this from a sportbike but it's inexcusable for DS/ Motard. Victory Vegpinhampots It's practically impossible to fill the tank without gas spraying out. This is a problem with the fuel pumps with holes around the end. Out in the country were the fuel nozzles don't have those holes it isn't a problem. |
01-23-2012, 11:46 AM
#96 | |
Yinzer
Oddometer: 1,203
mirrors on dual sports need to be tucked tight in with the handle bars so they don't get torn off by trees/broken off when dropping the bike/etc. for a bike that never leaves the street, it seems to me you can have them stick out as far as required to see around your elbows. |
01-23-2012, 11:56 AM
#97 |
PsyKotic Waterfowl
Oddometer: 9,967
Tilt it to the right for a little while after you turn it off and before you put it on the sidestand. This allows a lot of the oil behind the pistons to drain back into the sump so there's less oil to seep past the rings and will be a lot less smoky on startups.
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR IBA #17739 (SS1K, BBG, 50CC) http://home.comcast.net/~smithduck/BMW_Tours.htm |
01-23-2012, 12:10 PM
#98 |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,088
K- bikes may do that a lot but my airhead R80RT has chucked out smoke on start-up only once in 20,000 miles and the oilhead has never done it. I frequently park both on their sidestands.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
01-23-2012, 03:47 PM
#99 |
Gear addict
Oddometer: 574
The instruments on the F800 don't bother me too much but we could probably fill this thread entirely with some of the stupid shit on that bike in stock form. I would say top of the list would be rims made out of a tin foil like substance, a stock suspension that is a joke in the dirt, and a rear shock bolt configuration that without modification can bend the frame. Fortunately all these are fixable with time and money.
As to the WR 250 mirrors, there is a solution called Highway Dirt Bikes. Top of the line guards with mirrors you can tuck out of the way in the dirt. OP - this is a great idea for a thread by the way. Unfortunately The Perfect Line has had a serious lack of descent threads for a while. Nice job turning it back up a bit. Dan
Dan 2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install Red dirt, rocks and sand; Riding the southern UTBDR |
01-23-2012, 04:17 PM
#100 | |
ΜΟΛΩΝ ΛΑΒΕ
Oddometer: 1,202
In bike reviews online, all you ever hear is "this thing is awesome." You never hear stuff like this... the stuff only real people know. |
01-23-2012, 04:34 PM
#101 |
REMF
Oddometer: 8,546
You Husky guys with the suicide kick stands do know all you have to do is replace one bolt (or get impatient and dremel the little extended head deal on the stock one) to cure it?
Mike S. '09 Bonneville Black AMA MSTA STOC http://autos.groups.yahoo.com/group/...orcycleriders/ |
01-23-2012, 06:50 PM
#102 | |
Oddometer: 7,713
The foldable aftermarket ones I've seen are $100...for two freakin mirrors!
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
01-24-2012, 06:10 AM
#103 | |
Deputy Cultural Attaché
Successfully surviving motorcycling since 1976. |
01-24-2012, 06:43 AM
#104 |
Has Cake/Eats it Too
Oddometer: 4,157
On the BMW f650 thumper models:
- the cheesy water pump. - the fact the BMW thinks dry bearings are just as good as greased bearings - the ridiculous suspension on the stock model, which means a couple grand right off just to get it close to spec. ![]() Overall I love the bike, but frankly I expected more from the Korporation. |
01-24-2012, 10:29 AM
#105 |
Shiny = Destroyed
Oddometer: 296
