Old 01-27-2012, 10:38 AM   #121
Brooklyn Rob
Do'h!
Oddometer: 474
Originally Posted by lemieuxmc View Post
This is a learning moment right here!
That third gear thing is a real pisser, but on the other hand you can buy another DR650 for what it costs to replace a FD on your late model BMW.
You rarely get any kind of snob action from DR riders either... unless they are towing a KTM with a blown top end out of a sand wash!
The oil pump drive gear on the dr650 is made out of plastic, and guess what happens when you grind something plastic against something metal. That's right, the thing that's made out of plastic disintegrates.
Ask me how l know.
l guess that's another thing suzuki hasn't quite figured out yet either.
Brooklyn Rob is offline   Reply With Quote
Old 01-27-2012, 10:43 AM   #122
Brooklyn Rob
Do'h!
Oddometer: 474
Originally Posted by High Country Herb View Post
Instrument Cluster - Just a little bit of inclement weather causes problems. Rain causes the tachometer to go haywire for 24 - 48 hours. Hot sun causes the digital speedo to black out. Apperently, it is common in Aprilias in general.
High beam switch - When I'm wearing winter gloves, I'm constantly hitting the high beams by mistake. I'm learning to be more careful with my fingers.
Other than that, the bike is amazing!
That's an easy fix-
just get shorter fingers.
Old 01-27-2012, 03:19 PM   #123
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,213
How about this one, which applies to all but a few Euro bikes:
Crappy. Rubber. Brake. Hoses.
Why don't all bikes come with braided stainless brake lines? They can't cost that much more in large quantities than spongy rubber lines, can they?
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 01-28-2012, 11:38 AM   #124
Angry Wookie
Running On Fumes
Angry Wookie's Avatar
Location: The most wretched hive of scum and villainy aka DC
Oddometer: 241
In general, the stock seat on any bike I've ridden.
I also hate that my R1100RT doesn't have a sixth gear.
Of all the things I've lost, I miss my mind the most
Angry Wookie is offline   Reply With Quote
Old 01-29-2012, 08:09 PM   #125
kraher
kraher's Avatar
Oddometer: 131
This thread has amazing potential to finally prove once and for all that ALL bikes have a few (at least one) small flaws.
Buy the bike whose flaws annoy you the least.
08 R12GSA
08 WR250R
89 ZX-7 H1
kraher is offline   Reply With Quote
Old 01-29-2012, 09:24 PM   #126
southwade OP
ΜΟΛΩΝ ΛΑΒΕ
southwade's Avatar
Oddometer: 1,745
So far the running theme is sensitive tushies... ehem.... that is, I mean, hard seats.
i haz z1000!
southwade is offline   Reply With Quote
Old 01-30-2012, 04:17 AM   #127
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,213
The only common theme I can find here is the sensitivity of Sethsquatch's arse - harden the fuck up mate!
farqhuar is offline   Reply With Quote
Old 01-30-2012, 04:56 AM   #128
dukeman
Oddometer: 21
This has already been touched on, but my 05 f650gs with 48k is on it's fourth water pump and I know I'm not alone. It should be changed at regular intervals just as a precaution.
dukeman is offline   Reply With Quote
Old 01-31-2012, 01:51 PM   #129
Brooklyn Rob
Do'h!
Oddometer: 474
Maybe you should keep the water pump and change the bike.
Old 01-31-2012, 06:24 PM   #130
Pro_Marinero
Carbon Sasquatch
Pro_Marinero's Avatar
Oddometer: 2,090
Pre-09 husaberg jug design. I love the bike, but why incorporate the cylinder into the case requiring the halves to be split to service the piston??
Pro_Marinero is offline   Reply With Quote
Old 02-01-2012, 06:40 AM   #131
Calamity Jesus
n0ob
Calamity Jesus's Avatar
Oddometer: 246
'09 Bonneville SE
Well, I'm glad you guys covered the faux-carbs.. because I sure wasn't going to. My only issue with them is that I get a bunch of old timers coming up to me and asking what year it is, then nearly falling down when I tell them it's a new one with EFI. I really need to renew my CPR certs It's a retro-styled bike.. how would you expect them to approach EFI on a bike that's always had prominent carbs? Anything else would completely defeat the point of the bike's existence, and they can't stick with carbs forever.
Anyway, the biggest flaws of the Bonneville are that it's so damn heavy (500lbs wet), that the seat is 1/2" thick, and that the rear suspension is stiff enough to cause spine injury if you fail to dodge a pothole. Fortunately, two of those things can be fixed at which point it becomes a superb bike that's in dire need of a 6th gear.
Tiger 1050
As already mentioned.. the headlights are horrific at doing what headlights are supposed to do and the fuel gauge is crap. Further, the miles-to-empty takes over the gauge's rotating display whenever the bike thinks it has less than 50 miles, so, due to the gauge being crap, it thinks it's near empty all the time and you can't use the other info without reaching out 12" in front of the handlebars to hit the buttons on the cluster.
Calamity Jesus is offline   Reply With Quote
Old 02-01-2012, 08:12 AM   #132
Josephvman
I'm the Decider
Josephvman's Avatar
Oddometer: 3,462
The location of the ignition key on the first-generation Ducati Multistrada. It's located down in the middle of an abyss that is the area around the steering head. If you drop anything smaller than a bench vise anywhere near it, gravity will suck it into a black hole and it will travel to another dimension, the dimension where single socks, car keys, and hotel key cards live...
Also, removing the seat on that bike had the potential to ruin multiple weekends and put you in touch with feelings of primal anger that you didn't realize you had inside you...
'11 Ducati Multistrada 1200S Sport "Stormtrooper II"
'09 BMW HP2 Sport
'98 Ducati 900SS Final Edition "The old whore"
'93 Ducati 900SS "Slightly older whore"
"Gentlemen. You can't fight in here. This is the War Room!"
Josephvman is offline   Reply With Quote
Old 02-01-2012, 11:10 AM   #133
mhpr262
mhpr262's Avatar
Oddometer: 3,925
Originally Posted by dwoodward View Post
I was this arse on a motorbike...
*honk* oops *Honk* *HONK* mother fvck *HONK* G-d DAMMIT
Don't worry, the bride probably took it as a salute, the groom as a last ditch warning.
mhpr262 is offline   Reply With Quote
Old 02-02-2012, 12:52 PM   #134
nukemm
Oddometer: 114
Suzuki DRZ400S: Horrible seat, shifting weight on the seat with IMS tank causes the front of the seat to unhook from the tank, I feel like I am revving the piss out of it to keep up with traffic, thus causing the ridiculous vibrations through the pegs and the handlebars. I love this bike, but I'm also glad I only have to put up with the super slab for 15 minutes at a time!
nukemm is offline   Reply With Quote
Old 02-02-2012, 02:38 PM   #135
L.B.S.
Oddometer: 1,416
If Satan took corporeal form on Earth, he was in the shape of the seat on my 1991 DR350S.
That was the only bike I've ever owned in 40 years, that would make me think of reasons not to go for a ride.
Really interesting to see all these years later, DR seats are still right up there for being hideous!
L.B.S. is offline   Reply With Quote
Times are GMT -7.   It's 06:48 AM.
