Old 01-20-2012, 10:46 AM   #1
pjm204 OP
Oddometer: 2,012
I need help sourcing a couple nuts (pun intended)
I'm working on a fork conversion right now and need 3 stem nuts. None of them have commonly available threads. Let's see who can do the best internet search. Oh and if I knew what the stem was for, I'd already have the parts (I don't). It is for a yz450 but is aftermarket, likely Pro Taper or Ohlins.
bottom nuts (qty 2) are M30x1.25
Top nut is M26x1.25
I ordered both of these nuts from a roketta parts site but the nuts that arrived had such boogered up threads, they wouldn't fit. Thus, the search continues.
Your help is greatly appreciated.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 01-20-2012, 08:11 PM   #2
elgato gordo
KTMRFS
elgato gordo's Avatar
Oddometer: 510
M30x1.5 part number 93850A390
http://www.mcmaster.com/#catalog/118/3194/=fw9kyv
elgato gordo is offline   Reply With Quote
Old 01-21-2012, 08:19 AM   #3
pjm204 OP
Oddometer: 2,012
Originally Posted by elgato gordo View Post
See above post. I need M30x1.25
Old 01-21-2012, 01:35 PM   #4
elgato gordo
KTMRFS
Oddometer: 510
Sorry, close but no cigar.
Old 01-24-2012, 07:47 AM   #5
pjm204 OP
Oddometer: 2,012
Bump...still need this help.
Old 01-24-2012, 08:00 AM   #6
Treadless
seeking adventure
Treadless's Avatar
Oddometer: 5,359
Stop by one of your local machine shops and have them spin them up for you.
Treadless is offline   Reply With Quote
Old 01-24-2012, 04:44 PM   #7
pjm204 OP
Oddometer: 2,012
Yup, I talked to one today, he said not a problem. I'm going to send him the specs and get r done
Old 01-25-2012, 03:51 PM   #8
subybaja
subybaja's Avatar
Oddometer: 2,893
Looks like there's a Porsche transmission that uses a M30 x 1.25.
Bevel gear shaft nut M30 x 1.25 330
Shaft nut on M30 x 1.25 # 997 GT2 - GT3
...and an Aprilia scooter that uses an M26 x 1.25 rear wheel nut.
http://www.vsmotoparts.com/nut-m26x1-25
http://www.vanseggeren.nl/aprilia_3....O=Rear%20wheel
Some Roketa site, too.
Any chance chasing with a tap (or thread file) would clean up the nuts you've got enough to work?
Ask your machine shop about heat-treat on your custom ones. I'd be suspicious of a "grade 0" untreated nut.
-edit- on reread, wouldn't chasing down ProTaper or Ohlins be easier than any of this other stuff? A few emails to their techs should get if squared pretty quickly, since you have the size and pitch...
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 01-26-2012, 09:28 AM   #9
pjm204 OP
Oddometer: 2,012
Thanks for doing some searching. I would have ordered the Aprilia nut but the site wasn't from the US. As for contacting Pro-Taper and Ohlins. I keep doing it and never get an answer. I'll keep trying before I get custom ones made.
Old 01-29-2012, 08:21 AM   #10
Burke-Motorsports
Burke-Motorsports's Avatar
Oddometer: 13
PM sent! If you can tell me what Ohlins product/s use the nuts you are looking for, it would be easier for me to look up the part numbers.
Dean Burke
Burke Motorsports
www.burke-motorsports.com
Burke-Motorsports is offline   Reply With Quote
Old 01-29-2012, 06:33 PM   #11
pjm204 OP
Oddometer: 2,012
Thanks, I replied to your PM.
Old 01-30-2012, 11:56 AM   #12
pjm204 OP
Oddometer: 2,012
Come on guys, we can figure this one out together, I know it!
Old 01-30-2012, 04:31 PM   #13
subybaja
subybaja's Avatar
Oddometer: 2,893
Drop EagleMike a line...his Prevailing Torque KLR sprocket nut is 30mm. Dunno the pitch. If that dosn't work, I'd trust his custom machine work all day long.
There are a couple Aprilia nuts on ebay, but it doesn't say the size. There are some 25x1.5 Aprilia axles, so I'd do some parts-fiche digging.
link1 link2
And a Porsche trans nut HERE and HERE , HERE. Says 30mm, doesn't say pitch.
Old 01-30-2012, 05:35 PM   #14
pjm204 OP
Oddometer: 2,012
Thank you. I'm thinking the stem is either honda or KTM based on my WAG. I might just shoot my machinist buddy an email and have him make them. Getting tired of searching.
Old 01-30-2012, 05:50 PM   #15
ig_88e
Oddometer: 155
We get a lot of hardware at work from:
http://www.metricmcc.com/ and
http://www.bigbolt.net/
I always fail to find stuff on their websites, but it would be worth giving them a call. They have a lot more big stuff than McMaster.
ig_88e is offline   Reply With Quote
Times are GMT -7.   It's 11:02 PM.
