Old 01-29-2012, 04:09 PM   #46
offrdr1975
offrdr1975's Avatar
Oddometer: 113
looks great
The bike is really looking great. You are making me jealous. I have to get started on mine soon. I can't wait to see yours finished.
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 is offline   Reply With Quote
Old 01-29-2012, 04:46 PM   #47
pvangel OP
Team AARP
Oddometer: 2,467
Thanks! It's coming out great! So far I am happy with it
pvangel is offline   Reply With Quote
Old 01-29-2012, 05:26 PM   #48
GESII
Gerry with a G
GESII's Avatar
Oddometer: 110
Really looking good! I like it (and your previous builds as well)... First thread I check under 2 smokers!!!
GESII is offline   Reply With Quote
Old 01-29-2012, 06:42 PM   #49
pvangel OP
Team AARP
Oddometer: 2,467
Thanks! I don't know why but it is fun to post this stuff, I like to go back and look at it from time to time as well. I see people view it but don't know if people like it unless they say so? Glad you enjoy it!
Old 01-29-2012, 06:57 PM   #50
pvangel OP
Team AARP
Oddometer: 2,467
Of course I forgot to remove a broken bolt that holds the radiator on so I drilled it out but didn't want to use heat so I broke the first "easy out" off so drilled it bigger but still could not get it out.
I ended up going even bigger and the re- tapping the hole and the old bolt came loose inside and jammed the tap in the hole, I was able to back it in and out and eventually got it out....PIA
I'm happy with the progress this weekend, probably be able to finish it by the end of next weekend.
Old 01-30-2012, 11:41 AM   #51
CHECK_OIL
CHECK_OIL's Avatar
Oddometer: 367
Thumb Good stuff!
CHECK_OIL is offline   Reply With Quote
Old 01-30-2012, 07:24 PM   #52
pvangel OP
Team AARP
Oddometer: 2,467
Thanks C O!
Didn't have much time tonight but did hook up all the radiator hoses on, installed the chain, started the controls and lubed the cables.
New clutch lever,
Old 02-02-2012, 06:28 PM   #53
pvangel OP
Team AARP
Oddometer: 2,467
Slow going this week, friggen work gets in the way of everything.
Was able to get a few things done though,
Old 02-03-2012, 07:01 PM   #54
pvangel OP
Team AARP
Oddometer: 2,467
Bit by bit...piece by piece....getting close
Old 02-04-2012, 03:46 PM   #55
pvangel OP
Team AARP
Oddometer: 2,467
Ok, Back to work....
Bled out the brakes front and rear and freshened up the earl.
Old 02-04-2012, 03:52 PM   #56
pvangel OP
Team AARP
Oddometer: 2,467
Freshly oiled filter as well as fresh oil in the transmission.
Have to have new grips for the "new bike" feel,
Thes are the only grips that last me more than 3-4 rides, I use the air gun to put them on and it takes a couple seconds on each side.
Safety wired on,
Old 02-04-2012, 03:58 PM   #57
pvangel OP
Team AARP
Oddometer: 2,467
The best part now! Stickers!!!!
Shrouds,
Minus testing and adjustments it's FRIGGEN DONE!!!
The before pic,
Better pics to follow....I have to clean the garage now
Old 02-04-2012, 04:06 PM   #58
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
You Chipped My Frame!!!!!!!!!
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 02-04-2012, 04:13 PM   #59
pvangel OP
Team AARP
Oddometer: 2,467
Thats nothing, wait till the first ride. Those 450's like to roost you when your passin um!
Old 02-04-2012, 04:16 PM   #60
pvangel OP
Team AARP
Oddometer: 2,467
Can't wait to try it...
Times are GMT -7.   It's 07:56 PM.
