01-20-2012, 12:05 PM
#1 |
Oddometer: 344
KTMonda CR500 450sxf conversion
I've already done 2 ktm to ktm 4t hybrids: http://www.advrider.com/forums/showthread.php?t=662808
I got a good deal on a Craigs list CR5 and already had a 08 ktm roller in the garage. From the 2 other ktm hybrid builds I've seen it should almost be a bolt together build. The Honda parts will worked over as well, I just want to get the chassis done first. ![]() ![]() [/quote]pivot spacers and getting the sprocket into the correct horizontal alignment. ![]() The right rad outlet points in the wrong direction (for a 450sxf radiator) ![]() ![]() The right outlet is perfect ![]() The shock spring to pipe clearance may need some tweaking ![]() ![]() Old mounts cut out and cleaned up ![]() Re-positioned for the 500 engine and welded back in
KTM RFS/SXF hybrid http://advrider.com/forums/showthread.php?t=662808 CR500/KTM hybrid http://advrider.com/forums/showthread.php?t=757835 |
01-20-2012, 12:50 PM
#2 |
Oddometer: 4,314
Hmmm..................very interesting.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
01-21-2012, 05:49 PM
#3 |
Oddometer: 261
WOW!! I think the CR500 bike will be fantastic, I rode a Service Honda 500 awhile back and I couldn't believe the difference with the motor mounted in a new CR frame.
01-29-2012, 04:55 PM
#4 |
Oddometer: 344
The 2t (07 125sx) radiators work with no issues
![]() ![]() I'm just waiting on the carb boot and silencer to show up and I can finish the remaining fabrication
01-31-2012, 06:18 PM
#5 |
Oddometer: 344
Slightly cleaner engine, allough in the process of cleanign i noticed the crank was semi submerged in oil..
![]() crack ![]() I have no idea what this is ![]() ![]() monkeys should not have tools, the stator side seal is bottomed out as well ![]() cleaner ![]() ![]() some baking 30min @ 300 ![]() easy as Pie ![]() On the plus side the cylinder is still on the stock bore, and it looks like the case issue is just some casting flaws. now to see how a ultrasonic cleaner does
03-24-2012, 01:52 PM
#6 |
Oddometer: 344
cases directly out of the ultrasonic cleaner
before ![]() after ![]() ![]() ![]() The 2t carb boot while not perfect (the angle of the reed boot is not the same as the filter boot) it will work out. ![]() The head, cylinder and cases cleaned up ![]() ![]() ![]() ![]() ![]() ![]() The final case bushings machined and the head stay finished(cut and welded 250sxf stays) ![]() ![]() ![]() ![]() It should move a bit faster now that I have most all the parts to finish
03-24-2012, 06:02 PM
#7 |
What could go wrong?
Oddometer: 4,957
Very cool, thanks for posting, I just gotta ask though.... what happened to the stock motor?
edit, never mind I just spent quite a bit of time reading your links. This build would make an awesome timber sled bike.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd anonny screwed with this post 03-24-2012 at 06:31 PM |
03-24-2012, 07:49 PM
#8 |
Oddometer: 344
ha, yeah this it the 3rd roller I pieced together from multiple sources. If you shop around you can do it for not much money.
03-24-2012, 09:47 PM
#9 |
Oops...
Suhweet. Friend of mine had a CR500 he did up as a trail bike, it was surprisingly useable in the woods and would climb any hill ever.
As for the timbersled- I STILL don't understand why nobodies done that yet (well, i guess I've seen some versions on a CR500 but no report as to how they perform). If I ever get my 495 pieced together and if I can ever afford a timbersled, I'll let you know how they work. Don't hold your breath though, that's a lot of ifs. ![]() Can't wait to see how it turns out!
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
04-08-2012, 09:51 AM
#10 |
Learning the ropes!
Oddometer: 51
What a great build up!
Very neatly done, thank you for sharing with us! Please post an update of the work you have done thus far! Since I discovered the mechanical simplicity of two strokes, I am intrigued by the Honda CR range! Can't wait for your next post Regards, Rocket_Rookie
Two wheels good, one wheel better. '92 Honda XR600R |
04-09-2012, 08:37 AM
#11 |
Beard Bros Racing
Oddometer: 10,159
![]() BBBbbbrrraaaappppp!!!
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8"If you french fry when you shoulda pizza'd,your gona have a bad time".
04-09-2012, 06:54 PM
#12 |
Oddometer: 344
I managed to get the cases back together, The silencer changed to a 1.25" core, and a new outlet in the head.
04-10-2012, 09:17 AM
#13 |
Learning the ropes!
Oddometer: 51
That engine is really shiny..... Wow.
04-10-2012, 09:27 AM
#14 |
Oddometer: 344
especially when you compare it to how it looked a few months ago...
04-10-2012, 03:03 PM
#15 |
De Oppresso Liber
Oddometer: 30,423
That is one of the best motors every built. I will never forget my first ride on the CR500R.....80mph wheelies as easily as most bike wheelie at 30mph. And the thing never seemed to run out of arm stretching power.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
