02-11-2013, 03:37 AM
#346 | |
Oddometer: 2,720
then repeat for unknown number of times in traffic without allowing engine ample time to charge battery back up. Shorai LFX 21 measured about 6 amp hour under a 1C discharge ... this means that battery will sustain 6 amp drain for one hour. or 30 minutes under 12amp discharge. your headlights don't understand PB/EQ .. they drain real amps. my recommendations are Odyssey 925 with 26AH, unfortunately 24lb... otherwise Shorai LFX36 with about 12AH (actual) might do it .. if you charged to full before you started and your total down time not exceed 60 minutes @ 12amp drain. you'd be better off turning off bike with key, killing everything including lights during stops watch this video, which stress LFX18 battery very similar to what you described
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 02-11-2013 at 03:47 AM |
02-11-2013, 06:25 AM
#347 | |
Alps Adventurer
We tested several chargers here at our Defense labs and the Xantrex TrueCharge 2 was by far the best. We bought a slew of them. And when I say "tested", we tested all aspects of them; current, voltages, temperature compensation, fault and alarm indications, etc. They are available in various outputs. Note only the 20, 40 and 60 amp units can take a remote battery temperature sensor (most chargers put them in the charger ) and the remote panel enabling you to reduce the max current rate.These aren't toys and as a result cost a few hundred dollars. But they do handle all types of batteries: FLA, AGM, GEL, Pb-Ca. I have some pics here. From the home of the plain old low-tech flooded lead acid battery, now in its 14th year and still starting my car at -20F.
All the best, Alex Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure Euro & Alps Motorcycle Tours - Priced Right, How to go about Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein |
02-11-2013, 07:18 AM
#348 | |
Oddometer: 686
Thanx for that. I was aware of that charger and that it was rated pretty well. Finding a place that does good reviews of this type of charger is hard to find. And most of this stuff is Rebadged Reptile renderings as was noted. Do you kow of a good website for this type of battery related stuff? Car batterries as well? What did you think of that CTEK charger? Les_Garten screwed with this post 02-11-2013 at 07:48 AM |
02-11-2013, 08:32 AM
#349 | |
Alps Adventurer
Check out Battery University and the East Penn Technical Manual (AGM & Gel battery paper) For the money, its OK and no better or worse than anything else in that price range. I brought both of my 3300 Multi US models in to our lab and had a Graphtec monitor voltage and current during charging. I never did see the float mode that is advertized. It goes to 14.3V (in normal battery mode), then shuts off and restarts at 12.5V which is my prefered method of charging. When I used a manual charger, I would monitor the voltage and when fully charged, disconnect it. When it self discharged over a few months to 12.6V, I would connect the charger again. That was for a battery out-of-vehicle. I use a HP DC supply at the moment (I'm the microprocessor and charging algorithm ).
02-11-2013, 09:04 AM
#350 | |
Oddometer: 686
I have 2 HP power supplies that I was going to wire in series to give 24 vDC / 1600w to go into an iCharger or Cellpro PL-8. I was wondering about going this route versus the Xantrex you mentioned? I still have those power supplies. The Xantrex 40 and 60a models want a pretty good sized minimum bank of batteries and I can't meet that if I just hook up a PC925 without my other batteries. |
02-11-2013, 10:50 AM
#351 | |
Oddometer: 2,720
flooded PB amazingly still has it's place. when taken care of will provide excellent service life. it's not that long ago when AGM was considered new technology. price points for AGM has come down enough for AGM to become mainstream. hopefully the same will happen with LiFePO4 batteries. lithium iron phosphate batteries has one of the lowest raw materials costs of any battery. there is no shortage of iron on this planet. hopefully public's acceptance for LiFePO4 batteries will translate into higher volumes/lower costs. Battery University has always been one of the best sources for technical information on the WWW. unfortunately it's weakness is a lack of depth for the most promising of all battery chemistries. LiFePO4 or lithium iron phosphate ... called Li-phosphate in chart below. in the fast changing world of batteries ... there's always been a trade off between maximum energy density and safety. lithium cobalt hands down wins the energy density prize. but scores low on the safety side and needs elaborate safeguards to prevent lithium cobalt batteries from going into thermal runaway like on Boeing 787. LiFePO4 currently wins the compromise between energy density and safety. unfortunately corporate's rather large investments in lithium cobalt chemistries prevents/hinders it from moving forward. unfortunately costs/time for meeting Federal guidelines prevents/hinders change to much SAFER LiFePO4 batteries in critical applications like main ship batteries on Boeing 787.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 02-11-2013 at 10:59 AM |
02-11-2013, 11:34 AM
#352 | |
Alps Adventurer
As for the power supplies, as long as you are willing to do the monitoring.
02-11-2013, 11:46 AM
#353 | |
Alps Adventurer
Why would I pay twice or three times the cost of my FLA battery if I don't get twice or three times the life out of a lithium battery. Careful now, I get roughly 10 years out of a seasonal battery and 18 years out of a car battery. Starter RPM? Who cares as long as it starts which it does on the first second. Weight? Who cares; your average person could stand to shed 20+ pounds. ![]() I see GM lost one of their test facilities. Hmmmm.
02-11-2013, 07:58 PM
#354 |
Oddometer: 22
Any issues jumping a weak Shorai or other lithium battery from a regular 12 volt motorcycle battery with good cables?
02-11-2013, 09:22 PM
#355 |
mighty fine
Oddometer: 590
So what is the secret to getting 14 years from a car battery? Been using a smart charger for a little while on all my vehicles "every now and then" expecially in the winter months. Got 7 1/2 years out of one. Any thing I could do better?
worship no one. |
02-12-2013, 11:34 AM
#356 | |
Oddometer: 2,720
think voltage/current in terms of water flowing through a pipe. volts = pressure of water current = flow of water ... larger the pipe, more water flows through LiFePO4 = low internal resistance = Huge pipe PB = high internal resistance = little pipe a fully charged PB battery is 12.85v flooded PB to 13v AGM. a fully charged LiFePO4 battery is 14.6v to 12.8v at 20% condition. so very little current will flow into discharged LiFePO4 battery from a fully charged PB battery. lithium batteries has very low internal resistance and will accept a charge at about same rate as discharge. for instance if a LiFePO4 cell is rated for 28C momentary discharge... that cell will accept a charge at that rate too. which could be very bad for low LiFePO4 battery, if hooked up to another fully charged 14.6v LiFePO4 battery. most LiFePO4 cell mfg spec charge rates at .5C to 1C charge rates to allow time for cell to absorb current. this issue comes up in series/parallel battery pack configurations. when/if one cell goes bad, rest of cells in nearby parallel stack will attempt to charge up bad stack. resulting in a pack that will never reach full charge. worst case a melted down battery. which brings up one of the main advantage of LiFePO4 cells ... it's very difficult to cause a LiFePO4 battery to catch on fire ... then resulting fire will not be any where close a catastrophic, thermal runaway like lithium cobalt battery used in Boeing 787.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 02-12-2013 at 11:52 AM |
02-13-2013, 02:12 AM
#357 | |
Oddometer: 13
Ok cool, thanks heaps for sharing your thoughts and wisdom... I never related to the headlight using so much power, currently has a H1 Bulb, 55w halogen, one only, but by the time we add in tail light, stop light, ignition, indicators, and a hit on the starter motor, i can see the battery getting a hard time... That said this scenario isn't a often event, but just an extreme that got me thinking, given its summer time, and while stop start riding the other day i decided to shut her down each time i had to sit at a red, try keep the engine temp down being air cooled and all... I see the big 36 Shorai is up in the mid $300 range, so that will be more toward $500 of my money, time it gets here, so thats out... How long would you expect a BMW Gel 19ah to last, Im very suprised having just bought my bike, to find its original battery still in there and going ok... Also just started using a charger, CTEK XS3600, But have been using on motorbike mode, and now just read online i need to use the car mode, Is it a good idea to use often and leave on for extended periods, my bike seems to be out maybe once a week currently, but less when winter comes... Just a thought, How good a job does the BMW bike system do at charging the Shorai type battery, as it wasn't designed to do so... Think the listed output on my bike is 600w... Thanks for the very informative thread to... ![]() Cheers Jeremy Wanderer2012 screwed with this post 02-13-2013 at 02:23 AM Reason: Add some on... |
02-13-2013, 06:31 AM
#358 | |
Oddometer: 2,720
properly taken care of PB based batteries can last a very long time indeed. best condition to store PB battery is fully charged. AGM has the lowest self discharge rate for PB (LiFePO4 self discharge is lower yet) & tolerates overcharge abuse better than gel. which should not be charged over 14.2v-14.3v .. Gel batteries if overcharged can gas causing permanent damage. AGM can also be damaged by overcharging but it's closer to flooded PB for charging characteristics. Flooded PB are most tolerant to overcharge of all the lead acid batteries. 600 watt charging system should be plenty to support most any electrical needs on your bike. Airheads got by with under 280 watts for decades. upgrades for Airhead charging system is only 450 watts. Odyssey 925 AGM 26AH, weight 24lb vs Earth-X ETX36 at 3lb 11oz recommendations is to go with AGM unless saving weight is more important than saving $$$.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 02-13-2013 at 06:47 AM |
02-13-2013, 08:15 AM
#359 |
Oddometer: 686
Since we're talking charging here...
How about the use of the 14.7 v regulators and the PC680 or PC925 batts. Is that high output regulator too high for the AGM batts? |
02-13-2013, 01:05 PM
#360 | |
Oddometer: 2,720
for a few months during testing for Shorai LFX 21 .. determined actual AH capacity was too low for R80G/S when combined with cold weather/heated gear/short trips. a higher output voltage regulator 14.4v-14.5v was tried ... conclusion was one still needed a larger AH capacity battery. but overcharging risks increased during extended rides. switched back to OEM voltage regulator. technically LiFePO4 reaches full charge at 14.6v, so 14.5v would still be under threshold. too close to LiFePO4 limits for extended rides... this document is worth reading ... contains information specific to AGM 12v batteries. PB chemistries are well established technologies with a voluminous amount of information out there. key is knowing which set of technical information to drill in on.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 02-13-2013 at 01:15 PM |
