Old 01-25-2012, 08:36 PM   #31
captain pabst
b00n
Oddometer: 23
Originally Posted by herrhelmet View Post
Taco, do you have a running bike you could hook it up to? If it were mine, I'd charge it up that way if possible. Otherwise, yes at this point I'd put it on a trickle charger. I try to keep mine above 13.25 volts.
are those 26650 cells in your sycl batteries safe on a battery tender plus (12 volt at 1.25 amp)?
captain pabst is offline   Reply With Quote
Old 01-26-2012, 06:29 AM   #32
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,368
Yes, the 26650s can be charged up to a 2 amp rate. No need to leave it on the charger for extended periods, however. Once it gets to 14.4 volts take it off.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 01-26-2012, 10:16 AM   #33
RozzyCat
Bleeds orange
RozzyCat's Avatar
Oddometer: 531
Real world Shorai experience
Chiming in with real world experience on Shorai. I've not been successful starting my KTM990 when left out overnight below 45 degrees despite following several "warm up" procedures. I went back to the stock lead acid battery. Shorai sent me a replacement but I have not been able to test it yet.
A number of other guys/gals report no problems.
KTM 990, 300XC-W, 500EXC
RozzyCat is offline   Reply With Quote
Old 01-27-2012, 08:09 AM   #34
OaklandStrom
Oddometer: 1,612
This is good stuff.
The battery in my Wee is probably not going to make it through winter.
I'd love to take more weight off the bike, but would like to have something that is completely compatible with my battery tender (or something I never need to charge?!?) and doesn't cost a fortune.
OaklandStrom is offline   Reply With Quote
Old 02-01-2012, 02:08 PM   #35
_cy_ OP
Oddometer: 6,338
finally received my Lithium Iron Phosphate battery today... naturally couldn't wait to dive in.
rated at 3C or 60amp continuous, 10C or 200amp intermittent discharge, or plenty of amps to start any motorcycle.
first up is to charge the battery. let's see what the spec's say...
max charge rate is 3C, recommend .5C - .8C charge rate
max voltage listed 3.6v per cell x 4= 14.4V max charge
useful voltage is 11.2v to 14.4v
since my 0-40v 70 amp regulated power supply is not hooked up yet. And I don't have access to a commercial lithium Iron phosphate charger. we'll make do with a dumb 12v 60 amp charger. it's actually got several setting that allows selection of what voltage is used for current cut-off. works out very nice!
Specifications
- Nominal Voltage: 12.8V (4X 3.2 V)
- Nominal Capacity: 20 Ah
- LiFeMnPO4 chemistry
- Operation Voltage Range: 11.2 to 14.4V
- Weight: 3.0 kg or 6.6 lbs
- Dimension: 178X76X165 mm or 7.0X3.0X6.5 in
- Max Charging Current: 3C, ... .8C to .5C preferred
- Max Discharge Current: 3C (continuous) / 10C (pulsed)
- Cycle Life : >1500 (80%DOD)
- Operating Temperature: -20 to 65 C or -4 to 149 F
- Self Discharge Rate: <3% monthly
- Accessories included: jumpers, bolts or rivets, washers, split washers and cell covers
- The 4-cell pack is enclosed in a plastic box
Nominal Voltage (V) Capacity (Ah) Dimensions (mm) Weight (kg)
12.8 20 178 x 76 x 165 3.0
balancer/overcharge circuit boards
weight is 7.5lb not 6.6lb claimed
shipped voltage is 13.21v
charging at 14.4v @ 8amp... not enough amps
out comes the dumb charger... 14.3v @ 17amps ... close to desired .8C rate
monitoring temp while charging to make sure battery is not getting too hot during charge
not even warm at 17 amp charge rate
battery is getting close to fully charged ... let's stop take a few readings
barely warm
resting voltage 13.97v after 5 minutes... going down to 13.53v after an hour
finishing off charge at 14.4v @ under 1amp with HP regulated power supply. when voltage reaches 14.4v, all current will terminate by HP circuitry. normally would be using my Schulze charger, but it's dead until I send it back to Germany for repairs.
after trickle charging for a few hours ... battery finally reached 14.39V
after resting for an hour... finally a resting voltage 13.92 .. what a PITA to charge lithium iron phosphate when you don't have a charger with correct algorithm. appears voltage drops by about .5 volts after resting an hour.
_cy_ screwed with this post 02-02-2012 at 11:35 AM
Old 02-01-2012, 08:47 PM   #36
_cy_ OP
Oddometer: 6,338
balancer/overcharge protection circuits in action ... be interesting to see how much additional parasitic drain protection circuits causes. these cells bare are rated at 3% self discharge per month
with flash off so your can see LED light. green for safe, red for bleeding off voltage
right cell measures over 3.54V which triggers volts bleed down (slowly)
another cell goes over 3.54v, red LED lights to indicate volts bleedoff
_cy_ screwed with this post 02-01-2012 at 08:54 PM
Old 02-02-2012, 07:53 AM   #37
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,368
Will it start your bike?
Old 02-02-2012, 08:03 AM   #38
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,133
Those look like Sky Energy cells.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-02-2012, 01:48 PM   #39
_cy_ OP
Oddometer: 6,338
Glazed eyeballs alert ... was trying my level best to avoid technical mumbo jumbo.... but in this instance, just cannot avoid it.
in fairness to Shorai battery who chooses to state their amp hour rating in PB EQ = lead acid equivalent. Peukert law has to explained ... by the way please feel free to correct me if I'm stating this wrong and/or over simplifying.
Peukert law says as amp draw increases efficiency loss in terms of amp hours capacity decreases. Peukert loss is proportional to internal resistance of battery's cells. and no I'm not going to put up no sticking formula, charts and graphs.... yet
all lead acid batteries, which include Flooded/wet, Gel and AGM has higher internal resistance vs Li-ion cells, of which Lithium iron phosphate is but one type chemistry available. Li-ion cells has very low internal resistance (li-ion discharges at high rates). on the order of 2% to 5% Peukert losses for higher discharge rates. in other words my 20 AH lithium iron phosphate would be equal to approximately 30% increase in Amp hour capacity as compared to lead acid.
I know... clear as mud
had to fabricate two copper tabs.. note this lithium iron phosphate battery was never mean for motorcycle starting duties. just that it was accidentally the correct size and configuration needed.
top plate will be trimmed to fit copper tabs.
_cy_ screwed with this post 02-03-2012 at 02:34 AM
Old 02-02-2012, 02:55 PM   #40
_cy_ OP
Oddometer: 6,338
yes.. test battery starts R80G/S just fine. battery measured 13.31v. note test battery rated at 3C or 60amp continuous discharge. typical motorcycle starter will draw about 100 amp for a fraction of second, then draw about 70 amps for 1-3 seconds burst. then wait 30 seconds and try again if needed.
would be really surprised if a 20amp hr li-ion battery rated for 60 amp continuous ... couldn't sustain a 70 amp load for 3 seconds for several cycles.
had to try to start my Cummins turbo diesel first which it did not start (used 20ft jumper cables). heater grid ran battery down pretty good before starting G/S. note all lights are brighter due to higher system voltage.
what a pita to install a battery on G/S... rear shock has to be removed.
Is this test battery suitable for long term use... don't know ... many more tests yet to come
yanked battery back out and charging back up to try again (it's gulping down the amps!). next time with a full charge.
_cy_ screwed with this post 02-08-2012 at 09:07 AM
Old 02-02-2012, 04:06 PM   #41
_cy_ OP
Oddometer: 6,338
test battery charged to about 85% (didn't have several hours to trickle charge to full) .. reinstalled in G/S ... going for a test ride.
at first blush, the BMW gel cell battery that came out spins starter motor a bit faster. but both operates starter motor just fine at 60f degree anyways. we'll see what happens when it get cold.
all my lights are much brighter due to higher voltage at idle, instead of only seeing same voltage at higher rpm. notice my hi-tech cardboard battery cover
edit: just got back from a 50 mile night ride ... lights much brighter ... starter starting to turn over faster as battery charges up.
took an amp load reading after bike sat for about 3 hours .. garage temp 58f, engine temp 73f
measurable peak 98 amp, 78 amp continuous for 3 seconds
_cy_ screwed with this post 02-03-2012 at 02:19 AM
Old 02-03-2012, 12:55 PM   #42
_cy_ OP
Oddometer: 6,338
Snap-on Carbon pile load tester added, to replicate a motorcycle starter motor typical load of 75amp.
Old 02-04-2012, 10:16 AM   #43
_cy_ OP
Oddometer: 6,338
a bit of trivial ... this antique dry cell battery (100 yr old?) is still putting out 1.35V. probably would not sustain much if any load.
Old 02-07-2012, 07:56 PM   #44
_cy_ OP
Oddometer: 6,338
Due to flat discharge curve of Lithium iron phosphate battery. Measuring remaining charge or capacity left is tricky, but doable with a precision digital meter. useful voltage range from 13.4v to 12.86v (DOD 80%) so we get a spread of .5v that represents capacity remaining.
for those of us used to measuring lead acid batteries and older chemistry li-ion (lithium cobalt) some relearning is in order. discharge curve is no longer a straight line.
1. 14.4v fully charged
2. 14.4v to 13.4v. initial drop represents about 10% of capacity.
2. drop from 13.4v to 12.4v represents 80% of total capacity.
3. below 12.4 represents 10% of remaining capacity.
Don't drop below 12.86v (80% DOD) .. battery life (number of cycles) drops dramatically, Lithium iron phosphate cells are remarkably rugged. like all types of batteries, permanent damage will occur if allowed to discharge too low.
LiFePO4 discharge curve for one cell .. multiple by 4x for 12v LiFePO4
_cy_ screwed with this post 11-21-2013 at 10:14 AM
Old 02-09-2012, 09:28 AM   #45
_cy_ OP
Oddometer: 6,338
Li-ion packaging and why it matters...
seems an explanation is sorely needed on just what exactly is a prismatic cell vs a cylindrical cell.
li-po or lithium polymer packs have been around for sometime in the form of lithium cobalt. which has higher energy density and voltages, along with it's drawback of becoming unstable when overcharged. thermal runaway (explosion)
what relatively recent is the development of li-po packs made from lithium iron phosphate chemistry. which has a lower energy density and voltage. aside from being cheaper to mfg, it's also inherently safer. all of the lithium when fully charged is transferred the anode. so if overcharged, cell will still overheat and expand, but doesn't go into thermal runaway (explosion).
A123 was world first mfg for lithium iron phosphate batteries. cylindrical 26650 cells was the size adopted for powertools. that's 26mm x 650mm long and the most commonly available cylindrical A123 available. Nanophosphate ANR26650M1-B: The ANR26650M1-B is the latest A123 offering with 2.3ah 3.3v http://www.google.com/url?sa=t&rct=j...9Gi73A&cad=rja
so to make up a 12v motorcycle pack... it takes
4 cell 26650 A123 = 13.2v with 2.3 AH rating.
8 cell 26650 A123 = 13.2v with 4.6 AH rating
12 cell 26650 A123 = 13.2v with 6.9 AH rating
now lets move on to prismatic cells, which is the same type of battery without the steel clad construction. typically in a flat square form. but can be shaped to almost any form. like the battery inside iphone4.
so why are prismatic cell li-ion batteries technically better for motorcycle batteries?
or are cylindrical A123 batteries much better?
each motorcycle battery mfg states all the reasons why theirs are better?
that's what will be covered next ...
_cy_ screwed with this post 02-09-2012 at 09:47 AM
Times are GMT -7.   It's 11:27 PM.
