Old 05-22-2013, 01:05 PM   #541
Toaster.Tan
Toaster Rider
Toaster.Tan's Avatar
Oddometer: 159
Shorai and extreme heat conditions?
Sorry about the font/color - what reads well on my monitor I assumed would for others.... I'll stick with default settings.
Thanks for the reply/info. It appears to operate slightly BETTER at higher temps.
A comment was made from a guru on another LIST he wouldn't recommend Li for anything but track. He alluded to 'potential problems', but hadn't seen where anyone laundry listed those. Everything has a downside; I'm trying to asses the realistic risks to balance the cost. I can buy a couple three slosh for one of these.
ToasterTan
Custom Top Brace: http://www.pbase.com/toastertan/top_braces
72 R75/5 Toaster~
80 CBX-SuperSport~91 R100GS-PD~04 R1150RT
Bobber project using 1203cc Thunderbolt engine.
Toaster.Tan is offline   Reply With Quote
Old 05-22-2013, 03:21 PM   #542
_cy_ OP
Oddometer: 6,370
heat is usually not an issue for LiFePO4 use with motorcycles. main problem is marketing meets reality ... gross inflation of actual amp hour capacities.
what really counts is performance during cold weather. when temps drop, battery performance drops accordingly. at 14f capacity drops in half. hence need for specific cold start procedures with LiFePO4 to warm up battery.
small amp hour capacity is effected more by higher than normal parasitic drains. there's all sorts of reason why it's best to have a battery with OEM spec'd AH or close as possible.
if operating a motorcycle that's only used in warm weather, always leaving from a well supported home garage. one can get by with a much smaller LiFePO4 battery.
but if one is say 5 hours from any support during cold weather .. I'd want the largest LiFePO4 battery that I can stuff into available space.
any chance you could provide a link to other LiFePO4 infor source? anyone that only recommends LiFePO4 for track use has not done much testing on adventure bikes. which has some of the toughest requirements.
Old 05-22-2013, 05:04 PM   #543
Toaster.Tan
Toaster Rider
Oddometer: 159
Li battery data
I'll PM you as the person is on another LIST and don't cross-post other folks without their consent.
ToasterTan
72 R75/5 Toaster~
Old 05-29-2013, 02:53 PM   #544
DanMay
Oddometer: 49
Shorai BMS - Will it work on the Ballistic ?
I have a Shorai LFX09L2-BS12 that I use in a total loss, race bike application. I use the Shorai BMS charger to charge it. I also have a Ballistic 4 Cell EVO 2 battery that I use as a back up. I normally charge the Ballistic with a Battery Tender. After reading this thread, I used a volt meter to check the balance of the individual cells through the BMS port on each of the batteries, and it appears they have the same pin-out. Do you think it is safe to use the Shorai BMS charger to charge the Ballistic battery ?
DanMay is online now   Reply With Quote
Old 05-29-2013, 03:10 PM   #545
_cy_ OP
Oddometer: 6,370
not familiar with Shorai BMS charger, but it looks very similar to an RC charger with balance leads. normally intelligent chargers are menu driven with options to use charger with different chemistries and configurations.
if charger includes an unbalanced mode for LiFePO4 .. you can charge any LiFePO4 without balance ports. most battery mfg use standard configuration.
otherwise you need to contact Ballistic to find out how their wring configuration is done. the Shorai base battery charger will work fine if wiring confirmed to be the same. otherwise only use in unbalance mode without balance leads.
I'm using a Cellpro Powerlab 8 which charges up to 40amps along with all sorts of testing features like regenerative discharge. Cellpro has options to charge with or without balance leads.
Old 05-29-2013, 04:10 PM   #546
DanMay
Oddometer: 49
I took a shot and the Shorai BMS charger does work on the Ballistic. Since the pins were identical in voltage readings when testing the individual cells, and the adapter was identical, I took the risk and plugged the Shorai BMS into my Ballistic. It quickly charged and balanced the cells.
Had I know there were better 3rd party chargers for these batteries, I would have picked up the one you mention. Since I already have the Shorai BMS charger, I will use that.
Thanks for all the great info in this thread.
Daniel
Old 05-29-2013, 04:52 PM   #547
Dfrnt
Just pluggin' along
Dfrnt's Avatar
Oddometer: 1,016
EarthX
Have you seen their new ads touting their ability to protect from both over and under charging? Maybe I bought mine too soon....
"Roads? Where we're going we don't need roads" Doc Brown
Dfrnt is offline   Reply With Quote
Old 05-29-2013, 05:05 PM   #548
_cy_ OP
Oddometer: 6,370
nope, but this has been in the works for sometime. MOSFETS are used to isolate all current when voltage drops below 8V. All previous EarthX are equipped with internal BMS, but those are to prevent individual cells from overcharging and stay in balance.
with ability to disconnect battery when voltage drops below 8V. this feature protects LiFePo4 from parasitic drain killing your battery.
EarthX already has proven itself on 200amp load tests with flying colors. with lastest MOSFET high drain protection, it appears EarthX has advanced state of LiFePO4 battery technology for motorcycles to another level.
EarthX is proud to introduce our newest battery management system effective 4/15/13 that now includes over discharge protection in addition to cell charge balancing and over charge protection! What this means to you is if you leave your lights on, or your key in the ignition, our circuitry will disconnect at 8V so it will not damage the battery and you just have to put it on a charger to reconnect and be on your way! We are also proud to announce a new size case for the ETX24D and the ETX36D that is the exact size of the lead acid one you are replacing. If you want a compact size, you can order the ETX24C or ETX36C.
_cy_ screwed with this post 05-29-2013 at 05:35 PM
Old 05-29-2013, 10:54 PM   #549
_cy_ OP
Oddometer: 6,370
Originally Posted by RexBuck View Post
I recently returned from a 6 1/2 month trip to South America. During the trip I started to notice that the bike was having difficulty maintaining voltage at an acceptable range when it got cold and the heated gear was on. During the first part of the trip in fairly cold weather (leaving Canada in October) I had no problems.
When I got into South America and started using heated gear again, I began to notice voltage sometimes falling down to the 13.7 to 13.8v range. It would recover to adequate levels after 5 to 10 minutes of riding. As time wore on, it took less and less to put the voltage into the warning zone and longer to get it back to normal. Usually kept RPMs in the 4K range.
What I have:
  • AntiGravity 16 cell battery
  • Carried a spare stator (along with a ton of other crap on the theory that if you had a part with you, you wouldn’t need it – proved correct)
  • Voltmeter on the bike is a “Voltage Sentry” Meter from Clearwater. It is one of those single bulbs that blinks and changes color depending on voltage. It apparently was designed specifically for a Shorai battery which may account for some unusual color combinations (It’ll be replaced with a simple digital meter soon)
The extra gear on the bike that draws power:
  • · Gerbings jacket - 77 watts (with controller)
  • · Stock heated grips - 46 watts at high
  • · Denali spot lights - 20 watts
  • · Garmin GPS – less than 5 watts
So, when I was starting to notice lower voltage, this is what I figured the bike was using:
  • · Baseline 147 watts
  • · Grips – high 46 watts (Sometimes on low – no difference)
  • · Spot lights 20 watts
  • · Jacket 77 watts (although this is the maximum draw – while the controller would have been drawing more as it got cold, it was never on the absolute hottest level)
  • · High beam was not on
  • · It was cool enough and I was going fast enough that the fan was not coming on
Add that up and it looks like about 290 watts were being used which is well below the supposed output of the bike’s stator of around 370 watts
So, thoughts about what could be going on would be appreciated. Is there a component starting to fail? Am I over-thinking this and there is no problem?
I suspect I’ll be taking it to the dealer shortly as hopefully the fix will be a warranty item. Will the AntiGravity battery be a warranty problem? I could stick the OEM battery in if it would be.
Joel has not been very active lately .. so I'll try to help.
note test mule in my LiFePO4 testing thread is an R80G/S .. Joel is the F8 guy!
16 cell = 9.2 amp hour actual, 20 cell = 11.5AH actual
new style A123 are 2.5AH per cell, old style 2.3AH.
with heated gear actual amp hour comes into play in terms of reserves remaining to start next morning. especially in cold conditions.
LiFePO4 reaches full charge at 14.6V ... operating range is 13.3v to 12.85v (20%)
think water flowing in a pipe ... voltage = pressure amp/current = flow
LiFePO4 battery will charge at 13.8v, but rate of charge will be slow. at 14.2v current will be pushed into battery faster, resulting in a fully charged battery quicker.
to check what state your battery is being charged to:
after your normal ride, put bike away .. next morning before starting bike, measure resting voltage. (assuming no excess parasitic drain) note it's important to use a known to be correct meter. cheap $15 meters are fine, if it's been checked against a known meter like a Fluke.
chart below will show state of charge for your LiFePO4 battery.
if your battery shows say 13.6V after resting overnight. it's fully charged, it's probably OK.
Old 05-30-2013, 05:00 AM   #550
_cy_ OP
Oddometer: 6,370
Thanks for that _CY_
Joel gave me some advise last fall in preparation for my trip. I knew he wasn't around here as much so I just thought I'd see who jumped up.
I'm a little confused. You say operating range is 13.3v to 12.85v but it will charge slightly at 13.8v. When mine gets below 13.5v the little meter on my bike has pretty well gone solid red which I thought was pretty close to the end of the world. Was 12.85v a typo?
At what voltage does the battery start being discharged?
I checked the voltage of my battery yesterday after the bike had sat for 5 days after a 4 hour ride. Voltage was 13.6v.
Checked it again today after running it about 30 minutes yesterday and it was 13.7v
Did some tests yesterday and today and with everything off that can be turned off, the voltage climbed to 14.3v and stayed there. With everything turned on including both the jacket and grips on high, the voltage dropped down to 13.5v - 13.7v @ 4000 rpm. I didn't leave it there for a long time but the voltage seemed to be deteriorating.
So, does it make sense that the system seems to be struggling to power 290 watts worth of bike and gear?
By the way, my meter is a cheapy $50 meter. I've never checked it against a good meter but, I'm sure I have to go into town tomorrow and maybe I'll see if I can find someone to calibrate it for me.
LiFePo4 is a completely different animal than PB. but charging systems voltages designed to support PB is an almost prefect fit for LiFePO4.
to understand it's necessary to dive into mumbo jumbo of discharge curve of LiFePO4, which is shown in chart below.
all LiFePO4 12v batteries are fully charged at 14.6V ... voltage drop down to 13.3v only constitute 10% of available AH capacity.
13.3v to 12.85v represents 90% of available AH capacity .. a very flat discharge curve. hence reason why it's necessary to know if your meter is accurate.
resting voltage the next morning before starting your bike will give an accurate state of charge assessment. if you don't have time to wait overnight to measure. simply turn on your lights for a few seconds to bleed off surface charge. but it's more meaningful to know your battery has a full charge next morning before starting your bike.
if your LiFePO4 battery is reading 13.6V after sitting several days. that's an indication your parasitic drain is not excessive and your battery is fully charged.
failure mode for all permanent magnet charging systems when RR goes out .. 17v+ is delivered to your battery. if left long enough will kill your battery, PB or LiFePO4. then you will be replacing both RR and battery. catch it soon enough, your battery will be saved.
recommendation is to install a volt meter if you don't already have one. it's handy to understand your battery has 9.2AH actual capacity. this means your battery will support a 9amp load for about one hour with your charging system completely dead. so if your meter shows battery not charging for few seconds .. not a big deal, even with tiny 9.2AH reserves.
better to carry a spare RR and stator on extended trips. which means you will not need either one
_cy_ screwed with this post 05-30-2013 at 05:24 AM
Old 06-04-2013, 06:32 PM   #551
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,544
So it looks like these things might be getting idiot-proof enough for me to be interested in giving one a go next time I need a battery
One thing I don't get though, the max charge of 5A they quote? Even the modest output of my 640's charging system would be around 15A, how does that work?
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-04-2013, 08:06 PM   #552
_cy_ OP
Oddometer: 6,370
Cheers
Clint
EarthX is referring to max charge rate with a charger. lithium batteries have an extremely low internal resistance. hence reason for their excellent cranking performance to actual AH size ratio.
initial charging or bulk phase .. LiFePO4 battery will basically absorb all the amps you can throw at it. during this phase voltage is not critical... as battery charges up, amp rate battery will absorb goes down at progressively slower rates. during this phase voltage is very important. max charge is reached at 14.6v.
clear as mud ...
Old 06-08-2013, 06:20 PM   #553
plodalong
Now if we just.....
plodalong's Avatar
Oddometer: 653
Having put a Shorai 18ah in my Thruxton a couple of years ago, I treated it to no maintance other than riding the bike. Read this thread and thought that a check of the battery voltage would be a good idea. Havn't ridden it for at least 2 weeks (hey I've got another bike and it was wet last weekend). The voltage measured 13.65v with an air temp about 3c (37f). Guess there isn't much parasitic current draw on the old carby models, though I did upgrade the voltage reg/rect to a FET model which might help in both charging and leakage current. Apart from cost and low temp performance I can't see a downside to LiFeP04 batteries...yet...it might of course die tomorrow.
I used to think its great that I've developed more patience as I've got older
But now I realise I just don't give a shit.
plodalong is offline   Reply With Quote
Old 06-08-2013, 08:27 PM   #554
_cy_ OP
Oddometer: 6,370
if your Shorai LFX 18 measure 13.65v after sitting at least overnight before starting bike. that indicates your battery is in a fully charged state and your bike has low parasitic drain.
use a known to be correct meter... it's fine to use a cheap $15 meter, but check with a quality meter like Fluke to find out accurate you meter is.
use chart below to find out your state of charge after resting overnight
Old 06-08-2013, 08:58 PM   #555
plodalong
Now if we just.....
plodalong's Avatar
Oddometer: 653
I worked in a calibration centre for a few years calibrating electronic test equipment and aircraft tooling. In those years I can't recall failing a digital muiltimeter on dc ranges, ac calibration is a different story. Although I havn't checked it's calibration recently I doubt my is muiltimeter more than 10mv out.
Times are GMT -7.   It's 05:13 AM.
