Old 01-21-2012, 12:33 PM   #1
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
THE 919 TRANSALP PROJECT . . . or "The Tigress"
As I mentioned in another thread, I had test ridden several bikes, mentally recording their respective handling characteristics until one bike up and pegged my fun meter. The 1050 Tiger has torque by the ton, crazy acceleration, and totally nimble road manners with no top heaviness or sluggish steering whatsoever. This is it, I thought. Not so fast. The 2007 Tiger was not in the budget. It wasn't until I rode that first 919 that I knew this balance of power and handling I loved about the Tiger could be had for a price I could afford. The more I studied the specs, the more I realized just how similar the Tiger and the Hornet really are. So this thread is not about how much I have to modify the 919 to get what I want but how little. I began my search. Via searchtempest.com I tracked every 06 & 07 919 in the continental United States and even called some the ads after they were pulled to ask how much the bikes actually sold for. The 919's were selling for around half the going rate for a comparable Tiger. After 3 months of market research, the time was right. In other words I finally sold my old bike. Armed to the teeth with fresh market trends, I worked my list until I found a seller receptive enough and due to the distance involved engaged in some pre-haggling over the phone. I left at 4am the next morning and made the almost 5 hour trek to northern Louisiana. We jump started the bike (battery dead from sitting) I did the test ride, made my decision and then said, "ok, on the phone you said you wanted $XXXX and I wanted to pay $XXXX so why don't we meet in the middle?" He said,"I was hoping you'd say that." And we shook hands.
Here she is. She's a 2006 model with 8k on the clock and lived in the back bedroom. The new trailer queen ready for the ride home.
Now the task of turning this minimalist muscle bike into a capable adventure tourer begins.
So here's what I've been up to. First I raised the stock suspension 38mm, as much as I dared. Granted, this is an experiment. I originally planned to do a dirt bike fork swap but thought I'd try this first. I removed the fork cartridges and dropped in a pair of 5/8" impact sockets fitted with 1/2" OD steel spacers to maintain alignment. A 60mm bolt holds the assembly in place. I had to grind a little off the bolt head on the left fork leg for axle clearance. I understand I have decreased the distance between the upper and lower fork bushings but so far it's very stable.
Before and after:
I stressed over the rear too until I saw how ridiculously easy it was. I had to drill one hole to relocate the upper shock mount. Slightly changing the shock angle softened the ride a bit too.
Ken Phenix
IBA #47092
The 919 Transalp Project
KatanaBandit (sold)
smugmug pics
KEN PHENIX screwed with this post 01-22-2012 at 05:32 AM
KEN PHENIX is offline   Reply With Quote
Old 01-21-2012, 02:21 PM   #2
elgato gordo
KTMRFS
elgato gordo's Avatar
Oddometer: 510
Cool idea.
elgato gordo is offline   Reply With Quote
Old 01-21-2012, 02:50 PM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,817
I'm digging it
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-21-2012, 05:46 PM   #4
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
Next comes a little routine housekeeping: I won a windshield on ebay, I restored the factory pipes and tail section, scored tags-on Dunlop D616 rubber from a fellow inmate and decided to try the new 11,000# zzz chain by EK. Now to get rid of the #2 pine puck.
I started with a donor sidestand that appeared to be long enough. Heat (acetylene) is a wonderful thing.
I drilled holes in the back of the stand and in a washer to accommodate the Bike's rotary safety switch.
And lastly, I welded tabs to the stand and cut a piece of aluminum in an oval to make a permanent puck.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
KEN PHENIX screwed with this post 01-21-2012 at 05:52 PM
Old 01-21-2012, 06:14 PM   #5
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
Originally Posted by sailah View Post
I'm digging it
Thanks. I studied your builds too - EXCELLENT work!
This 919 is also my daily commuter so I'm trying to do the transformation with minimal down time.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Old 01-21-2012, 07:08 PM   #6
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
Of course, the stock 26"wide x 2" rise bars had to go in favor of 31" x 4" aluminum.
I was ready to pull the trigger on custom motionpro.com cables but I think I might be able to live with the rerouted and stretched to the absolute limit factory units. We'll see.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Old 01-23-2012, 03:44 PM   #7
dentvet
Oddometer: 1,375
Hey i might try the fork extender option. Are you going for a bigger wheel up front or did you just want ground clearance?
dentvet is offline   Reply With Quote
Old 01-23-2012, 06:04 PM   #8
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
So far the spacers (sockets) under the cartridges are working great. I did have to do longer brake lines. I wouldn't take the idea more than a couple of inches though. Like many of these conversions, this one was slated to get a beefy dirt bike front end and a 19" wheel if for no other reason than to give more tire choices. My plans for this machine are at most 20% established dirt roads and 80% touring but it won't see any dirt work until after I fab the crash bars to protect the tank and side covers. The fact that Conti will soon be offering the TKC80 in a 120x70x17 front and 180x55x17 rear will help too. Time will tell whether the 17" wheel will be adequate for my purpose.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
KEN PHENIX screwed with this post 01-23-2012 at 06:09 PM
Old 01-23-2012, 06:16 PM   #9
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
Here's a shot of the repositioned Tusk Raptor bars after I rigged the Moose Racing hand guards and Heat-Trollers. The 919's grips are a bit short so I left some room on the ends and made bar-end weights out of simple 7/8" shaft collars.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Old 02-13-2012, 06:24 AM   #10
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
I finally got the chance to throw the switch on the old stick welder - and that's usually a sign of a pretty good day. The plan is to adapt my old homemade Seahorse case rig to the 919.
I got off to a pretty good start.
Fast forward one week:
Back to work on the side case install. I'm trying desperately to make this rig job of a rig job not look like a rig job.
The only place to hang a bracket on the 919 is the muffler mounts inside the tail plastic. Here's what I came up with.
This made replacing the tail section a little tricky.
I needed to make new rear top case supports but found myself short on material. What to do? Oh, this'll work.
Perfect.
ADV stickers are . . . . .O N . . . T H E . . . B I K E !
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Old 02-13-2012, 02:43 PM   #11
TerraRoot
Oddometer: 61
i'd be damn proud of that piece of engineering, and the welding, and the metal reclamation
TerraRoot is offline   Reply With Quote
Old 02-15-2012, 02:31 PM   #12
Johnny5jz
Johnny5jz's Avatar
Oddometer: 44
Has the added height in suspension affected the handling characteristics of the bike at all?
2002 Honda XR650L, 2012 Suzuki Vstrom 650, 1974 Honda CB750K custom build hardtail bobber
Johnny5jz is offline   Reply With Quote
Old 02-15-2012, 05:58 PM   #13
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
Changing the rear shock angle slightly softened the ride a bit - a good thing. I have yet to test it two-up or fully loaded but there's still plenty of preload available for that. I may have actually picked up 1/2" of travel up front - even after backing way off on preload and rebound adjustments. I bought the bike largely for its lightweight feel and nimble manners - all still there. Fun meter still pegged. If anything, the bike might get a tiny bit twitchy over 85mph which is a tradeoff I can live with. I'll play with the adjustments some more before my next road trip.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Old 02-16-2012, 06:54 AM   #14
Johnny5jz
Johnny5jz's Avatar
Oddometer: 44
I am planning to build a dual sport with an old honda CB450 twin using CR 250 forks and a custom monoshock swingarm. I am a little worried about the geometry and how it will handle. I am glad to see your changes didn't affect handling too much. That makes me a little more confident.
Old 03-09-2012, 10:48 AM   #15
KEN PHENIX OP
"CERTIFIABLE"
KEN PHENIX's Avatar
Oddometer: 650
Progress is slow. Work gets in the way. Some or all of the major mods I have slated for this bike might have to wait until after the big trip next month. But those protruding top case bracket bolt heads had to go - especially before I throw a dry bag across the pillion. The only flat head cap screws I could find were barely long enough and didn't quite work. So here I go head long into the man cave short on time with limited tools. I ground about 1/4" off the spacers that go between the grab bar and the top case mounting bracket and then drilled into said bracket to countersink the bolt heads.
Now the new bolts will be long enough but the heads are still too big. Not for long . . . .
Voila! Close enough for rock 'n roll.
As always, I filed this rig job under "Desperation is the Mother of Invention."
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Times are GMT -7.   It's 10:52 AM.
