Old 04-11-2012, 01:29 PM   #151
tanneman
I'm no Adventurer
tanneman's Avatar
Oddometer: 16
First time post, so hello to everyone.
On pg 6 the proper neat solution has been posted.
tanneman is offline   Reply With Quote
Old 04-11-2012, 01:35 PM   #152
TXjames
High Sider
TXjames's Avatar
Oddometer: 732
Sorry. I forgot to update over here. I will probably start a new thread with the solution written up more formally once I finish testing.
TXjames is offline   Reply With Quote
Old 05-05-2012, 05:21 AM   #153
ceasarfelix
2009 R1200GS
ceasarfelix's Avatar
Oddometer: 29
Fuel Strip Solution
Someone could sell a lot of these things if they put together a simple unit for us novices that can be spliced in wire-to-wire
Al
2009 R1200GS
2002 K1200LT
ceasarfelix is offline   Reply With Quote
Old 05-05-2012, 05:36 AM   #154
drmajor
drmajor's Avatar
Oddometer: 457
Fuel Level
I would like to get in on the new info when you have it ready...
Does the 2k and 1m resister just fool the bus that there is fuel and thus get rid of the FUEL warning?
drmajor is offline   Reply With Quote
Old 05-10-2012, 10:58 AM   #155
kk3an
kk3an's Avatar
Oddometer: 79
I replaced a fuel level sensor in a 2009 R1200GS last evening - bran new sensor & uncalibrated. Filled the tank to 5/8, and the gauge on the bike read 5/8. Filled the tank up full and the gauge read full. Fired up the bike and idled for 10 minutes, and the gauge remained reading full, as it should.
Prior to turning the key for the first time after the sensor install & with a bone dry tank, I cleared the computer (battery cables shorted).
The bike has 39,900 miles. For a short time prior to the sensor going bad, I had been transferring fuel - while riding - successfully from an auxiliary fuel cell. Early on after the sensor failure, I didn't know if doing this "on-the-fly" transferring would have been a contributing factor, but the more I think about it, I don't believe this would have any effect on the sensor itself.
If anyone has a different feeling about that, please let me know, but I think it's just a coincidence - mainly because the first few tank transfers went just fine.
Dan
kk3an is offline   Reply With Quote
Old 05-10-2012, 11:20 AM   #156
cjack
cjack's Avatar
Oddometer: 689
Dan
I take you are saying it doesnt need the recalibrating. I believe BMW agrees and they no longer require it.
My other bike is a BMW
Jack
RA & MOA #224
cjack is offline   Reply With Quote
Old 05-10-2012, 11:22 AM   #157
cjack
cjack's Avatar
Oddometer: 689
The heater is about 35 ohms...so you are saying that the absence of heater current is acceptable?
Jack
RA & MOA #224
Old 05-10-2012, 11:36 AM   #158
kk3an
kk3an's Avatar
Oddometer: 79
In just the two rough measurements I made (5/8 and full tank), there seems to be no calibrating needed - at least in my case.
Dan
Old 05-10-2012, 12:42 PM   #159
TXjames
High Sider
TXjames's Avatar
Oddometer: 732
Yes. The 2k resistor replaces the fuel strip when its reading a full tank. The 1M resistor simply supplies the small bias voltage necessary to make the circuit work.
No. The diagram shows the heater still connected. I have spoofed the heater using a similar 1W resistor but I have not completed testing. It is possible though.
If anyone knows where I can source the male side of the 4-pin connector please let me know! I could produce a plug-and-play solution that would require no electrical knowledge and provide it for the community.
Old 05-10-2012, 10:53 PM   #160
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 519
New Software
I have had a replacement fuel strip on back order for a couple of weeks now. My dealer assumed that they are making changes to it. However, yesterday I got a call stating that BMW has developed new software to drive the fuel strips. My bike goes in next week. We'll see...
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 05-11-2012, 06:00 AM   #161
TXjames
High Sider
TXjames's Avatar
Oddometer: 732
Oooohhh, now THAT is news! Hopefully your dealer knows what they're talking about. Please keep us posted on the results.
Old 05-11-2012, 02:52 PM   #162
cjack
cjack's Avatar
Oddometer: 689
I am guessing that the software is a "no calibrate needed".
As to improving the part, those of mine that I checked, (about 5 of them),had bad connections at the wire end of the think with no damage or changes to any part of the plastic strip. If USA gas affected the epoxy covering the wire to strip connections, then I guess BMW's blaming it on the gas may be valid, but remember that the key antenna also had a bad contact issue under the epoxy or filler, so maybe it was the USA air that caused that.
I feel that they just had poor design or QC on the contact part of the wires to the strip just like the key antenna. Hopefully the next batch will be more reliable although I just figure they sold out of the latest run.
Jack
RA & MOA #224
Old 05-12-2012, 06:53 AM   #163
Dave RII
Oddometer: 8
If the fuel strip failure is due to a mechanical issue (broken contact), as mine were, then they can develop all the new software they want and the problem will continue.
Dave RII is offline   Reply With Quote
Old 05-12-2012, 07:23 AM   #164
TXjames
High Sider
TXjames's Avatar
Oddometer: 732
This is true but I was under the impression that there are theories that the calibration method may be causing problems.
Old 05-12-2012, 10:21 AM   #165
Dave RII
Oddometer: 8
I can see how a bad calibration method could cause a faulty reading on an otherwise good strip but not how it could make a good one go bad prematurely. I was present at the dealership when my first strip was replaced under warranty. Their replacement/calibration "procedure" went as follows:
1. Disconnect battery
2. Drain tank
3. Replace strip
4. Reassemble bike
5. Connect battery, turn ignition on, wait for system to boot, turn ignition off
6. Replace fuel in bike
7. Start bike
8. Hand me the keys and say "Have a good day"
Perhaps they would have done some additional calibrating if my gauge did not read correctly after the install.
Times are GMT -7.   It's 08:13 AM.
