Old 01-25-2012, 06:52 AM   #1
rudolf35 OP
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Question 1973 Norton Commando
I have a lead on a 73 850 Commando. The bike was ridden to the current owners location and the fuel drained and then it has been sitting for 12 years. The bike is kicked over (not started but just turned over) once a month so the motor spins free, not frozen. I am waiting for images but would love to know what issues, Norton specific, I might run into. I have spooled up many BMW's and other British iron but never a Norton. Any info would be of value.
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 01-25-2012, 07:22 AM   #2
Twinboy
Oddometer: 52
Talking
I may be able to help on this one! We have had a 73 Norton for 35 years so I am very familiar with it.After sitting so long all fluids will need to be changed. 20-50 in the engine, 80/90 in the transmission,and 20-50 or ATF in the primary. The Amal carbs will at least need a good cleaning and maybe resleeving of the slides depending on mileage/condition. Check the valve clearance,adjust the points or replace with an electronic ignition ,we use a Pazon.The gas petcocks will probably need replacement along with the gas lines. Replace the tires and battery and go for a ride. 73/74 Commandos are considered the best of the series and as all Brit bikes of the era will require attention to keep running well.The Commando will surprise you with its excellent handling and gutsy mid range torque that make it a delight on the twisties.The rubber mounted motor will allow hours in the saddle without vibration fatigue. Parts are readily available and reasonably priced from multiple reputable dealers.Good luck!
Twinboy is offline   Reply With Quote
Old 01-25-2012, 07:31 AM   #3
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
Spooling up
Twinboy, those are some good pointers, slide on the carbs etc. Funny you mention 20/50 - this has been my oil in every bike I have owned since I can remember.
The basic spool up is the same on most bikes it is the idiosyncrasies I am looking for; like on the BMW's it is the splines (real or imagined) and rear end main barring.
What, besides the original shop manual is a good one, Clymer?
Old 01-25-2012, 08:22 AM   #4
Twinboy
Oddometer: 52
Laugh
Yes, the Clymer manual is decent. The main issues on the Commando are the carbs wearing and ignition.Update these along with the front brake master cylinder.These bikes will leak oil from various places but they are easily solved with careful attention and some hylomar sealant applied sparingly. The isolastic rubber mounts will need proper shimming but once set and rubber buffers freshened up they will work for a long time.Check and clean all wiring connectors and look for any suspicious rubbed wires.Our Commando still has all the original electric components except bulbs.Careful attention to solid connections and routing will pay off.Have fun.
Old 01-25-2012, 08:30 AM   #5
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
Thumb Oil sealing
Great information! I fully expect to rebuild the carbs and once up and idling see where the oil spews from - had a BSA 650 Lightning many years ago and went through the same drill.
Good point on the isolastic rubber mounts. I am sure, unless treated, the rubber mounts should be well age rotted by now. The wiring, see what that looks like but I am sure the connectors will need cleaning and a good lube with dielectric grease.
Your Commando has a owner that cares about it. Some PO's need to be slapped the way the bikes are treated.
As soon as I get the images from the owner the penny might drop - hope at least.
Old 01-25-2012, 08:34 AM   #6
chasbmw
Oddometer: 2,349
does a '73 850 have a fibreglass fuel tank? My 72 POS 750 did.
If so it will need to be sealed before using any fuel with (much) ethanol in it.
Charles
Charles
1971 Commando Fastback
Old 01-25-2012, 08:37 AM   #7
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
Charles
Very good point! I know that the original tank is there but as of now it has a second one mounted. I am still waiting for the pictures so I can not answer if it is glass or not. This find is very farm fresh, still has the straw on it.
Old 01-25-2012, 08:40 AM   #8
lemieuxmc
lemieuxmc's Avatar
Oddometer: 3,360
The single Mikuni or dual flat slide carb conversions are very popular.
lemieuxmc is offline   Reply With Quote
Old 01-25-2012, 08:42 AM   #9
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
Laugh Good stuff
Thank you to all for the information. This will make the "new frontier" easier to conquer.
Old 01-25-2012, 09:54 AM   #10
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,538
73 is steel for the tank.
As for carbies, if the bike has over 10k miles they are likely loose. Stay with the amals. You can actually get new ones, much improved with better floats, forged and hard anodized slides, etc. It has been proven that few conversions can produce as much power as the good old stock Amals. If your carbs are in pretty good shape, it would be worthwhile to upgrade the slides themselves to the hard anodized forged units. That is what I'm doing to all my brit bikes now. This can extend the life of your carbs greatly and is cheaper than sleaving.
Key thing to check is the swingarm bushes. If loose, strip and replace. Do NOT try and grease them. Use the proper straight 140w gear grease in them as recommended. It won't leak out and will keep them properly lubed once rebuilt.
You will have to check the shimming on the isolastics. Not a big deal to check and or add shims to. Hopefully you have a good shop manual and parts book.
Remember........stock these were positive ground. Do not for get this!!! A good AGM battery is a god send on these old bikes.
Mine is all stock, with points and amals, and never fails to start first or second kick. Many of the guys who 'improved' their nortons with electronics and mikuni's can't say the same thing.
And lastly, it no doubt has wet sumped all the oil from the tank to the crank case. Nortons are notorius for that. Drain the crank case for sure. In normal use, if you ride it every week, you likely would not have a problem. What you DON"T want to do is assume that the oil pump will pull all the oil from the crank case and put it back in the tank. These things will drain down to the point the oil intake or feed is hi and dry. Meaning that when you start it, you are NOT pumping any oil. Not good. I always pull the tank cap off and check. If the intake screen is covered and can't be seen I'm good to go. If it's exposed, drain the crank case and put it back in the tank. Not doing that could not only ruin the motor but blow the crank seals out from excess pressure. The trick I use, that works 75% of the time to prevent wet sumping, is that when you park it, push the kickstarter down so that the pistons are at TDC. The therory is that the oil passages on the crank will be pressed tightly against the rod shells and slow down the oil bleed to the crank. It does seem to work, at least on mine.
Remember the 850's have an oil filter down under the swingarm. A great from the factory.
And...no doubt you will need to rebuild the master cylinder. A worthwhile mod at this time would be to sleeve down the master to provide better braking. Several places do this and it's worthwhile. Wish I would have done it on mine. Helps prevent Popeye arm.
Gratuitous pic of my 73 850, 4800 original miles when extracted from a barn in colorado.
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt screwed with this post 01-25-2012 at 10:03 AM
lrutt is offline   Reply With Quote
Old 01-25-2012, 10:14 AM   #11
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
Laugh Good nargle points
Irutt, now that is what I call good points! Had no clue as to the oil tank draining into the crank. That means when I change all the fluids I will also have to make sure to drain the crank.
On all of my bikes I like to go stock on the motor and from what you describe that seems to be the way to go on the 850. Points, no big deal - as long as one keeps up with them. The slides, now that is a very good pointer - keep the stock bodies and go with the new hard slides. The master cylinder will need a rebuild anyway so I might as well sleeve it to get more power to the pads.
Now all I have to do is wait on the photos and see what is in store.
rudolf35 screwed with this post 01-25-2012 at 10:20 AM
Old 01-25-2012, 12:10 PM   #12
Twinboy
Oddometer: 52
Laugh
73 Nortons had steel tanks new. Do you know if it is an Interstate with the 6 gal tank,large seat and bigger sidecovers. Or is it a Roadster with the 3 gallon tank and smaller seat and sidecovers. The Inerstate is great for longer trips and the Roadster feels lithe and lean on the backroads. It got up to 64 today so I was inspired to roll the Norton out and go for a ride in the mountains here in Western North Carolina.Remember that the shift pattern is up for 1st and down for 2-4,or down for faster.You have received some great pointers on how to check and fettle a Commando.Good times await you!
Old 01-25-2012, 12:51 PM   #13
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,678
I bought a 72 Combat last year and I'm lovin' it. Carbs were sleeved, boyer ign, trispark regualtor makes for easy starting.
I'm saving for a Lansdowne Fork conversion next.http://www.lansdowne-engineering.co.uk/three_3.html
Best site I have found for info is :
http://www.accessnorton.com/
I read all the horror stories about build quality etc........ It really comes on strong at 5000 rpm but as its 40 years old I don't thrash it ( much).
Prices are all over the place here in NZ but demand is high as they are a nice bike to ride and very cool.
Even the Combat is easy to kick start and you get used to the upside down R/H shifter....most of the time... apart from the odd oops back into 1st...
Voltaire is offline   Reply With Quote
Old 01-25-2012, 01:23 PM   #14
noman
Oddometer: 927
norton upgrades
crank bearing upgrade? 7 or 8 ball, 10 ball, superblend? much discussion here and there on the intranetz.
1976 r75/6 -- mine since 1980, thx lloyd!
1997 900ss -- modified to full sp specs
noman is offline   Reply With Quote
Old 01-25-2012, 03:40 PM   #15
lrutt
lrutt's Avatar
Oddometer: 1,538
73 will have proper superblends on the crank. Only bearing of concern might be layshaft bearing in the tranny. and it will give you a subtle warning, the dancing kickstarter.
Times are GMT -7.   It's 11:24 PM.
