Old 01-25-2012, 09:46 AM   #1
KneeDrachen OP
MORE COWBELL!!!
KneeDrachen's Avatar
Oddometer: 1,088
Ooogah horn mounted on a Ural
Good Afternoon All,
I've noticed many people have "oogah" horns mounted on their Urals. As luckw ould have it, I have one and have run into a stumbling block on installing it. The horn came with a single bolt that the head slides into a recess on the horn body. I would guess the bolt then slides into a drilled "L" bracket or something. It seems most are mounted on the sidecar struts.
What's the method to the madness? Drill a pipe clamp?
Breathe, keep breathing, I can't do this alone
KneeDrachen is offline   Reply With Quote
Old 01-25-2012, 02:49 PM   #2
ruffshod67
Oddometer: 113
I mounted mine on my leg gaurd with the single bolt.I pointed the horn down to keep help keep the weather out.
ruffshod67 is offline   Reply With Quote
Old 01-25-2012, 06:34 PM   #3
Ivan Rider
Ivan Rider's Avatar
Oddometer: 611
I've done it a couple ways. 1 you can slide a bolt in that slot and bolt it directly to the sidecar tub. or 2. you can make a L shaped bracket and bolt it to the lower end of the front upper strut.
'78 BMW R100/Ural sidecar, '99 Ural Patrol
'03 BMW R1200CLC Solo & Ural sidecar Rig
'06 Honda Big Ruckus Solo & Sidecar Rig,
'08 Ural Retro, '10 Ural ST Solo
http://www.flickr.com/photo s/ivanrider/
Ivan Rider is offline   Reply With Quote
Old 01-26-2012, 05:27 AM   #4
KneeDrachen OP
MORE COWBELL!!!
Oddometer: 1,088
Thank you for both of your replies, it's greatly appreciated!
Old 01-26-2012, 06:03 AM   #5
redflasher
Baltika Lover
Oddometer: 150
Conduit clamp to the upper fork tube between hack and bike. Pointed downward a bit for drainage.
redflasher is offline   Reply With Quote
Old 01-26-2012, 06:08 AM   #6
redflasher
Baltika Lover
Oddometer: 150
Here's a pic.
Bob in Minnesota 2006GearUP
redflasher screwed with this post 06-13-2012 at 05:36 AM
Old 02-19-2012, 09:02 PM   #7
Steppy
Steppy's Avatar
Oddometer: 89
Oogah
I mounted mine on the old indicator bracket up front.
Steppy.
"If you have a problem and you can fix it, why worry?"
"If you have a problem and you can't fix it, why worry?"
Steppy is offline   Reply With Quote
Old 02-20-2012, 11:44 AM   #8
tattoogunman
tattoogunman's Avatar
Oddometer: 583
Originally Posted by redflasher View Post
Here's a pic.
Ha! Love the sign!
tattoogunman is offline   Reply With Quote
Times are GMT -7.   It's 03:54 AM.
