Old 01-27-2012, 12:18 PM   #1
madeouttaglass OP
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,536
Ural sidecar power outlet- part two
I see that they added it around 2006. Can anyone tell me what kind of plug it is? My wife and I will be picking up a new to us 2010 and she'd like to buy an electric blanket for a long trip home. I'd like to swap out the plug before we fly out. (if necessary)
edit 3/4/2012. Need to know if it's switched or always on.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass screwed with this post 03-04-2012 at 02:37 AM
madeouttaglass is offline   Reply With Quote
Old 01-27-2012, 12:29 PM   #2
KneeDrachen
MORE COWBELL!!!
KneeDrachen's Avatar
Oddometer: 1,088
powerlet/BMW, Ural of NE carries a blanket with the plug already on the end of it, around $65 IIRC.
Breathe, keep breathing, I can't do this alone
KneeDrachen is offline   Reply With Quote
Old 01-27-2012, 12:31 PM   #3
RottVet
RottVet's Avatar
Oddometer: 322
BMW outlet
Mine is a BMW style receptacle in the tub. I still put an SAE plug-outlet direct wired to the battery for my electric (Gerbing) jacket and for the low amp charger under the driver's seat. My puppies have not required an electric blanket-not yet anyway!
"If the going is getting easier, it is probably because you are going downhill"
RottVet is offline   Reply With Quote
Old 01-27-2012, 02:45 PM   #4
ZONKR
ZONKR's Avatar
Oddometer: 524
My 2007 has a cigarette lighter type plug.
2005 R1200GS
2007 Ural Gear Up
2013 BMW F800 "Baby" GT
BMWMOA 116478
ZONKR is offline   Reply With Quote
Old 01-27-2012, 03:13 PM   #5
Ivan Rider
Ivan Rider's Avatar
Oddometer: 601
So did mine. I think IMWA switched to the BMW plug in 2008. That's what you'll find on the 2010. I've heard but have not confirmed that John Deer has the same plug for a whole lot less then BMW.
'78 BMW R100/Ural sidecar, '99 Ural Patrol
'03 BMW R1200CLC Solo & Ural sidecar Rig
'06 Honda Big Ruckus Solo & Sidecar Rig,
'08 Ural Retro, '10 Ural ST Solo
http://www.flickr.com/photo s/ivanrider/
Ivan Rider is offline   Reply With Quote
Old 01-27-2012, 04:43 PM   #6
TebKLR
TebKLR's Avatar
Oddometer: 642
My '10 GearUp sidecar has the BMW-style socket. Powerlet makes adapters to go to "standard" cigarette-lighter sockets; even a dual outlet one.
TebKLR is offline   Reply With Quote
Old 01-27-2012, 06:22 PM   #7
madeouttaglass OP
The AntiHarley
Oddometer: 3,536
Thanks to all for the replies.
Old 01-27-2012, 09:10 PM   #8
windmill
windmill's Avatar
Oddometer: 4,084
Hey Tom,
The wire that supplies the outlet in the tub is a fairly small gauge, and on the long side. It would be best if you add a plug directly to the battery for powering an electric blanket or heated gear.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 01-27-2012, 10:42 PM   #9
MojaveSidecar
MojaveSidecar's Avatar
Oddometer: 571
I was surprised to discover a cycle air pump with a cigarette (SAE?) adapter I got over a year ago and never used works great with the socket in the sidecar of my 06 GearUp.
MojaveSidecar is offline   Reply With Quote
Old 01-28-2012, 04:51 AM   #10
madeouttaglass OP
The AntiHarley
Oddometer: 3,536
Originally Posted by windmill View Post
Hey Tom,
Ah, there's a tidbit I needed. I think I'll bring my own fused triple outlet to bolt to the battery. My vest, her blanket (yet to be bought) and the GPS all need power.
Thanks again guys.
Old 02-10-2012, 07:25 AM   #11
Ivan Rider
Ivan Rider's Avatar
Oddometer: 601
Thanks again guys.
You may want to get Her an Electic Blanket. It's cheaper and covers more area. They are on sale right now at Sportsmans Guide.
http://www.sportsmansguide.com/net/c...lewk06tsgtruck
Old 02-10-2012, 11:07 AM   #12
North"wet"
Born To Meander
North"wet"'s Avatar
Oddometer: 300
Electric blanket
I bought a 12v electric blanket through Amazon.com with a variable thermostat. There were a number of models available. Mine has a U.S. cigarette lighter plug but I have a European adapter available. The missus likes the blanket.
North"wet"
Fresno, CA
2011 Ural Patrol "Meanderer"
North"wet" is offline   Reply With Quote
Old 02-10-2012, 11:53 AM   #13
RockyMtnRoadRash
Useful and decorative
RockyMtnRoadRash's Avatar
Oddometer: 500
Ditto on a 2007
-RMRR
держите мою водку и наблюдайте это!
RockyMtnRoadRash is offline   Reply With Quote
Old 03-04-2012, 02:47 AM   #14
madeouttaglass OP
The AntiHarley
Oddometer: 3,536
OK, thanks to you guys I now bought a triple cigarette outlet with a built in 5V USB outlet. I have taken it apart and soldered on a longer, heavier wire with a waterproof fuse. The ends will go directly to the battery. The outlet will be mounted in the tub. I would like to add a relay so the outlets turn off with the ignition switch. Seeing that I'd never use a BMW style outlet, I was thinking of using the factory outlet in the tub to activate the relay- assuming it turns off with the key. This way nothing in the factory wiring gets touched.
Who can tell me if the factory BMW style outlet is switched?
Again- I'm in NY and my new bike is tucked away in Washington state so I have to ask you guys. It's a 2010 Gear Up.
Thanks yet again,
Tom
Old 03-04-2012, 03:11 AM   #15
tml82
Oddometer: 14
Ural plug
The sidecar plug / fusebox are hot all the time.
tml82 is offline   Reply With Quote
Times are GMT -7.   It's 09:22 AM.
