Old 04-10-2012, 05:02 PM   #151
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,368
Woody's Tenere Wheel R&D continues...
ok folks here's the fruits of the last days labors,,as ya know,,and if ya didn't now ,,ya will,,,wasp- the amazing 'solid works' -man in my llfe,,,throws some amazing light on what i'm doing,,,like ''ya may want to take a bit off here 'cuz it's got a slight interference problem right at the edge of that radius on your adapters,'',,,ok ya get the drift,,but get this ,,SO IT WAS !!!! after matching the modified spacer and trying it out for the first time,,,that lil corner he pointed out on his solid works program was just nicking the edge of my spacers as he had predicted,,,,,i'm beginning to pay alittle more attention to what my mate ''down under blabs about
so here's my Superlite ST -II = Super tenere double-disc version with the future location of the sensor ring
with the ST spacer assy..this had to be shortened the same amount as the overall width of the oem sensor plate with spacer,,BUT,,we ran into a snag!!,,turns out that the distance from the ST oem bearing to axle was/is the same as mine..how often does that happen,,,,??? to be contd,,the wie is yelling come down for dinner,,NO !!,,, it's take me out to dinner,,i bet one or two of ya can relate to that scenario
From Woody's Tenere Wheels
trying the oem sesor plate/holder onto my hub
the difference between the front [right side unit ] and the rear[the one on left] is this ,,,they use the same casting but rear sensor mount is higrre than the front sensor mount,,,so the lower casting height is for the frontwheel and vice-versa
on the right is the std Superlite ST spacer,,to the left the modified one with the O ring groove machined in ,,just like the oem spacer used in the sensor holder
here's the inside view of sensor holder showing the 1mm removal of outer corne/edge to eliminate the interference the edge created,,NOW,,,this mod allowed the holder to seat solidly against all the inner spacers and leave .5mm/.020'' clearance between it and my hub
another view of all that's needed to gain adequate clearance...,,ya can do this at home with a hand -file
to be continued manana,,after a good nite's sleep
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 04-10-2012 at 11:01 PM
Old 04-11-2012, 10:51 AM   #152
Wasp
Supa10 pilot
Oddometer: 1,062
Looking good Woody.
I'm prolly the only one on the planet that can make head or tail of that at the moment, but it will all fall into place when onlookers see it assembled and working.
Greg.
The original WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=595933
The NEW "Long Term" WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=778809
Wasp is offline   Reply With Quote
Old 04-11-2012, 11:06 AM   #153
Wasp
Supa10 pilot
Oddometer: 1,062
Iv'e made a start on my high front guard set up.
http://www.advrider.com/forums/showp...postcount=2121
Greg.
Old 04-11-2012, 02:27 PM   #154
Built to Last
Oddometer: 3,368
here's pics of wasp-man's front fender prototype..
Greg.
here's some pics to go with those lyrics:
although I am not sure if it is something that will go into production, but just in case I do offer them, I didnt want to put anyones nose out of joint.
woody's wheel works screwed with this post 04-12-2012 at 03:54 AM
Old 04-11-2012, 04:15 PM   #155
cams
cams's Avatar
Oddometer: 141
Re'; 21" s10 front wheel
Hi woody , further to the front s10 wheel we have been discussing here. I have sent you an email, re; how to pay etc. Cheers cams.
to be old & wise ,you must first survive young & stupid.
cams is offline   Reply With Quote
Old 04-12-2012, 05:32 AM   #156
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,274
Looking good Woody.
Greg.
Yeah, I thought I understood till you said that.
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker is offline   Reply With Quote
Old 04-12-2012, 11:03 AM   #157
Built to Last
Oddometer: 3,368
hi talk with wasp-man the non abs single disc unit pictured recently may be up for grabs ,,as wel as the double disc eunit [unless steve red snagged it already,,]
i responded to your pm already..oops forgot to ask you in the pm ABS/TCS importan t?? well it changes the approach to solving ,,good news it'll all be doable,,it's been tested and all the solutions work
woody
Old 04-13-2012, 06:20 AM   #158
obe01
Wannabe Adventurer
obe01's Avatar
Oddometer: 1,269
Interested in the A60 if she is up for grabs...
woody
How much for the A60 single disc unit pictured on Wasp's S10 there Woody.
Other than my order that I have placed with yourself I would be keen on this as a back up front wheel for myself. I may need however a set of Monzter spokes to allow me to use the rim with my OEM hub.
What sort of coin are we looking at mate for the wheel???
Johnnie
SUPER TENERE'
obe01 is offline   Reply With Quote
Old 04-13-2012, 07:54 PM   #159
Built to Last
Oddometer: 3,368
Johnnie
here's the run down on that A60
since wasp-man originally speced the wheel without the need for ABS/TCS that hub does not have the updated capability for the sensor ring adapter plate..
so cost breakdown for what he does have is:
a-60 rim=$200
ss nss spoke nipple heavy duty kit= $125
superlace n true= $111
Superlite ST kit= $599
Galfer 310mm= $310
plus S&H
free T-shirt or hat
i will do something special for ya,,since it'll have some real life wear n tear
w
Old 04-14-2012, 08:41 AM   #160
Wasp
Supa10 pilot
Oddometer: 1,062
I'm getting closer with the front guard Woody...
Just gotta work on the brake lines/locations/guides, and then onto the fork leg protectors.
Really pleased with the outcome here. Not for everyone, but I dont care - It suits me... So FYYFF's
Greg.
Old 04-14-2012, 08:46 AM   #161
CBAT
occasional wanderer
CBAT's Avatar
Oddometer: 826
Bruce
2000 Suzuki DRZ400S, 2012 Yamaha Super Tenere
My Great Divide Ride 2009
Great Divide Part 2
CBAT is offline   Reply With Quote
Old 04-14-2012, 02:53 PM   #162
Built to Last
Oddometer: 3,368
sweeeeeet wasp-man
and i'm cutting up your new black double disc ABS/TCS system compatible Superlite ST-II
woodster
Old 04-15-2012, 08:32 AM   #163
Wasp
Supa10 pilot
Oddometer: 1,062
woodster
Hanging out for that mate...
This bike is really starting to feel sweater and sweater.
Greg.
Old 04-15-2012, 08:34 AM   #164
Wasp
Supa10 pilot
Oddometer: 1,062
More pics and more ride report from today with the 21" front wheel and the new high front mudguard.
http://www.advrider.com/forums/showp...postcount=2137
I AM LOVING THIS BIKE RIGHT NOW...
Greg.
Old 04-15-2012, 02:36 PM   #165
Built to Last
Oddometer: 3,368
told ya so...
Greg.
no shit
told ya so,,,that was conclusion of every one that rode it in all 3 configurations,,,and like i mentioned before the 21/18 was the sweeeetest of em all
that was with 90/90x21 and a a 130/90x18 on rear if my memory serves right
am in shop making new larger OD sensor adapter plates ,,found my camera so i'll give ya'll some more porn
woody
Times are GMT -7.   It's 05:58 PM.
