Old 04-16-2012, 07:18 AM   #166
obe01
Wannabe Adventurer
obe01's Avatar
Oddometer: 1,269
How's me order going matey...
How's me order going Woody me mate, the one Zach is putting together for us....
I advised Zach to hold off on the front hub a while back until I knew which direction we were best to go with. I told him last week to go ahead with your front Superlite ST II hub assembly with the ABS/TCS compatible mod plate. If ya keep this to a twin disc setup that would suit just fine...
I will have a bit of a think about Wasp man's A60 and let ya know mate. PM sent about this mate...
Johnnie
SUPER TENERE'
obe01 is offline   Reply With Quote
Old 04-16-2012, 09:22 AM   #167
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,385
straightening out our order..
Johnnie
zach will be back tomorrow and we'll unscramble everything,,in the meantime i'm half hour away from finalizing the sensor ring adapter
w
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 04-16-2012, 10:31 AM   #168
Wasp
Supa10 pilot
Oddometer: 1,062
w
Hey Woody...........
Greg.
The original WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=595933
The NEW "Long Term" WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=778809
Wasp is offline   Reply With Quote
Old 04-16-2012, 02:41 PM   #169
Built to Last
Oddometer: 3,385
you want pics,,,YOU GOT PICS!!!,,,
Greg.
here ya go Wasp man....
all's well that ends well,,success!!! everything fits,,end air gap within .003 '' of your and my measurements
haleluja
woody
it started with my stone-age sketch,,supplemented by wasp-man's Solid Works wizardry
here's the lay of the land,,,the object was to take the 3mm/.120'' 6061-T6 plate and convert it into an adapter that would hold the OEM sensor ring circa .06-.070'' from the pick-up mounted in the sensor holder..
here's cam's future hub[he doesn't know it yet,,but i do ! ],,, having the lip machined where the sensor adapter will rest to give us the proper clearance down the road
drilling a pilot hole for the 1/2'' drill
here's the 1/2 hole being drilled to accept a my material holder for the lathe work
that's wasp-man's new double disc hub having the step machined at the correct depth
4.444'' is the diameter that his new adapter plate needs to be machined down to in order to fit perfectly within it's new boundaries
these are the 6906 2RS bearings before and after we re-pack them with hi speed water-proof wheel bearing grease,,FYI the bearings were virtually absent of grease...
waspman's hub being preheated prior to bearing install
waspman's [left to right] sensor holder,,,sensor adapter holder,,,and the sensor ring
and below them the oem bearing and sensor holder spacers and the Superlite version of the same for the ST hub
getting ready to mount the sensor ring
Voila,,www presents to you the completed product = ABS/TCS capability that works
PS...if it needs to have a bit closer gap we can add shimming material under the sensor ring or increase gap by adding a shim under the transducer. ,,i don't have a factory spec,,just went off of Wasp-mans and my readings...ie his = .736''/18.7mm and mine=.720''/18.29mm ,,wasp-mans black hub ended up circa .726/
so folks ,,start cueing up to place an order,,,
the line forms behind:
waspman
obe1
cams
next
woody
woody's wheel works screwed with this post 04-17-2012 at 09:29 AM
Old 04-17-2012, 07:05 AM   #170
obe01
Wannabe Adventurer
obe01's Avatar
Oddometer: 1,269
Fark Yeah....Bring it on Woody....
Nice work mate...
Hey, that silver hub wouldn't be my baby would it next to Cams on the bench there with all the sensor ring templates??? How did ya go with Zach matey. Nothing in my original order changed other than holding off on that front hub until things were sorted.
Excited as a kid in a candy shop, cannot wait....
Johnnie
SUPER TENERE'
obe01 screwed with this post 04-17-2012 at 07:14 AM
Old 04-17-2012, 08:08 AM   #171
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Great work Woody!
But.... Is anyone else having trouble reading the yellow-colored font much of Woody's text is in?
Perhaps its the "Fresh" web view format I've chosen that makes the text appear yellow and so hard to read, but I've not had this issue with anyone else's posts...
ktm950se
ktm950se is offline   Reply With Quote
Old 04-17-2012, 08:10 AM   #172
cams
cams's Avatar
Oddometer: 141
tha wheel god
thank you oh god of round shiny things. seeing IS truly believing. I still need a way of paying..... I like to keep my gods happy
to be old & wise ,you must first survive young & stupid.
cams is offline   Reply With Quote
Old 04-17-2012, 08:54 AM   #173
Built to Last
Oddometer: 3,385
that's your baby if ya want to adopt it...
Nice work mate...
Johnnie
so i assume ya want
the superlite ST-II-ABS/TCS version pictured with black heavy duty spokes and gold nippleas to what size rim im n color...may i suggest the 1.85x21 excel as an all-around good choice....
holler,,zach isn't in yet
woody
Old 04-17-2012, 08:56 AM   #174
Built to Last
Oddometer: 3,385
don't worry about this god of round n shiney
we'll get er done and sounds like your name is on this one
woody
Old 04-17-2012, 09:05 AM   #175
Built to Last
Oddometer: 3,385
woody n his yellow ,,,woody and his commas etc
Originally Posted by ktm950se View Post
Great work Woody!
ktm950se
for some reason ,,my background is grey,,hence i use yellow cuz it's easier for me to read as well as h-ilite what i'm saying as opposed to what's been posted...typing is a major chore for me that's why i try to get everyone to skype me..easier for show n tell
same goes or capital letters,,,my brain works way faster than my fingers,,so,,it's kinda like stream of consciousness
like the Leon Russel song i love ya in a place where there's no space or time...
...and if my words don't come together,,,just listen to the melody cause my love is in there hiding'',,kinda like that
tell me how to change the format and i'll give it a shot...i too notice that what i often see is what you describe,,then my techies click on something and voila it pops up readable...the www.yamahasupertenere.com site is especially tough for me view
i feel your pain
woody
Old 04-17-2012, 09:06 PM   #176
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Hi Woody,
No fault on your part for the hard-to-read yellow font, its simply a result of my choosing to use the 'Fresh' option of the Quick Style Chooser to view this forum.
You can find this feature at the bottom of any page, in a drop-down menu, and you'll see one of the following words:
cRash
ShakeIt
fish
Fresh
Asylum
ADVrider 2.0
By clicking on a different option, your screen, and the color of the text, will look different. Its sometimes helpful to do this when someone has chosen a font that looks good in the styler of viewer they are using, but isn't so easy to read in the style you normally use.
ktm950se
Old 04-18-2012, 09:46 AM   #177
Wasp
Supa10 pilot
Oddometer: 1,062
Look'n DAMN fine Woody.
A lot of perspiration and passion being put into this project.
How did you manage to secure the sensor ring mount to the hub? - Press fit or bonded in some way?
Greg.
Old 04-18-2012, 11:37 AM   #178
Built to Last
Oddometer: 3,385
press fit or bonded sensor ring???
Greg.
i'm leaning toward a dab of ;JBweld' an aluminum epoxy,,simple,tuff,,theres no reason for much else,,was going to use little grub/set screws,,steel ones could throw magnetic field awry,, theres simply no load on this thing
woody
Old 04-19-2012, 02:12 AM   #179
Wasp
Supa10 pilot
Oddometer: 1,062
woody
Sounds like it would do the job - Hell, even black Sicaflex would hold it together. You ever tried to remove that shit???
They glue bus's together with Sicaflex and I dont recall ever seeing a bus cladding panel come flying off.
The screws would also work IMHO as they are off the path of the encoder ring and pick up.
Keep up the good work Woody.
Hey, iv'e been progressing with the high front guard and fork leg protectors:
http://www.advrider.com/forums/showp...1&postcount=48
Greg.
Old 04-19-2012, 09:13 AM   #180
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
Half fender
Greg.
Great work Wasp ,,, as always ...
Have done some work and here are the photos of the high front fender with its little brother half low front fender ... the only thing missing are the fork protectors in carbon which will have to be raised 30 mm.
Before ...
After ...
Cheers,
Roberto aka Thagua
'Let's go adventuring'
Thagua is offline   Reply With Quote
Times are GMT -7.   It's 10:19 AM.
